Author Topic: Video Review Request for WI-FI Weather Sensor Series [No purchase needed]  (Read 2949 times)
Offline Glenn
I'm currently running it on a large indoor tropical. I had already had Chirp! sensors in play, so it was easy to calibrate my watering point with the soil sensor (28% on the ecowitt sensor). It's very good and quite in sync with the Chirp! units.
I've got a set of sensors here for my small conifer nursery, and I am just getting ready to set them up. Will report back when that's done.
Thanks halifax! Keep us posted. I'm curious on the range. One of our gardens is a bit away from the house. Curious how these do with a low wifi signal.
Range is probably like most other Fine Offset devices. 300 ft advertised direct line of sight but about 100 ft real world with walls and windows. The sensor itself does not use WiFi. It is RF (radio frequency) one way broadcast to the console. Then the console connects to your WiFi.
Thank you! Good info there. Sounds like it may work for our location. I'll have to look into getting one and a console.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline hazardc
First thanks to Lucy and Ecowitt
I will post a video soon, promising and very COOL products!!!!
University of Toledo
GLOBE/GISAG Lab
Offline Lucy
 [tup]Thank you!
We're looking forward to that~~ :-P :-P
Ecowitt Weather Instruments at: http://www.ecowitt.com/
FB: @ecowittsupport
Twitter: https://twitter.com/ecowittweather
Email: support@ecowitt.com
