Author Topic: Cold temperature SHT31 vs 75  (Read 1497 times)
Offline ValentineWeather
« on: November 09, 2018, 08:13:57 AM »
For anyone using the SHT75 it runs .5F warmer in single digits. I'm going to keep this test going throughout winter and report on this thread as we get below zero. The Pro shield has the SHT75.... Fars and standard the SHT31.
Randy
Re: Cold temperature SHT31 vs 75
« Reply #1 on: November 09, 2018, 08:31:11 AM »
Dropped another degree now differential is .6°
Randy
« Reply #2 on: November 10, 2018, 04:39:27 AM »
Here is difference at 16° coming in at +.3. The Pro shield has the SHT75.
Only doing these comparisons at night with good wind mixture so shield difference passive vs FARS don't come into play.  Both Pro and Standard Meteo shields are passive with similar design.
Randy
Offline jgentry
« Reply #3 on: November 12, 2018, 07:39:46 PM »
Interesting. Keep us posted!
Davis Vantage Pro2 & WeatherFlow Tempest. WU: KXALJEMI2, KALJEMIS7, KFLPANAM363 & KALTHORS2. CWOP/APRS: C6353 & E6358
Offline jgentry
« Reply #4 on: November 27, 2018, 10:15:05 PM »
How is your test still coming along?
« Reply #5 on: November 28, 2018, 06:33:19 AM »
Haven't had anything colder yet. I did this test with a chest freezer before but temperature changes so fast during freezer cycle can't really trust so wanted to confirm under steadier conditions.
Randy
« Reply #6 on: December 08, 2018, 04:04:32 AM »
At zero 0° looks like the SHT75 runs full 1° warm. The SHT31 is in standard shield, SHT75 in the pro shield.
Randy
Offline jgentry
« Reply #7 on: December 18, 2018, 10:45:45 PM »
Interesting. But will say that’s within specs of the 75 if my memory serves me correctly. Does your calibrated thermometer agreeing with your 31?
« Reply #8 on: December 19, 2018, 09:33:46 AM »
The thread isn't whether the 75 is within specs but where is it compared to the 31. We have some now running the SHT75 year round even in cold climates because of the high humidity bias displayed by the Davis version of the SHT31. From what I'm seeing the 75 specs are tighter than datasheet. Example at 0F (1° vs 1.6°F) on datasheet C needs to be converted.
Yes the 31 is right with the Certified +/- .2F.
Randy
« Reply #9 on: December 19, 2018, 09:43:40 AM »
Maybe better wording is on the tighter side of specs. Because it does say (+/-).
Randy
Offline jgentry
« Reply #10 on: December 21, 2018, 07:43:05 PM »
Thanks for the info!
« Reply #11 on: February 07, 2019, 06:56:14 AM »
Haven't updated much so here is the difference at -5°F. The Pro is the SHT-75.  Good air mix this morning so no passive vs fars issues.
Randy
Offline jgentry
« Reply #12 on: February 07, 2019, 12:08:59 PM »
Interesting. Not too bad if the 31 is right in the money.
« Reply #13 on: February 08, 2019, 04:40:38 AM »
Even better news the differential spread isn't getting bigger as temperture drops, so these 75's can be used year round as long as the user puts a little - bias (1°) below zero (F).
The 75 has superior humidity when dewpoint is above 55°. Jerry's along Gulf of Mexico shows SHT75 is less prone to get high humidity saturation when humidity levels stay above 90% over extended periods of several days.
Pro shield is the sht75 sensor in image.
Randy
Offline jgentry
« Reply #14 on: February 09, 2019, 10:09:39 AM »
Good deal! I probably won’t have to worry about that because I’m in Alabama. Lol. But interesting info about humidity. I’ll say it’s overall better than the 31 but with my experience, the 75 has shown some wet bias at times. In example: Here are the currents in my area.
Davis: 40/27
Nearby ASOS 39/23
Kestrel 40/26
Will note that the ASOS DP just dropped to 23°. It was sitting at 25° along with the Kestrel not long ago.
