Author Topic: The mechanism of thermoregulation of the Earth  (Read 7732 times)
Offline Fermer05
« on: September 19, 2018, 02:02:51 AM »
1. The reason for the formation of hydrogen sulfide in the Black Sea.
2. The mechanism of flood formation.
3. The ebbs and flows - the result of the rotation of the Earth and the cycles.
4. The mechanism of formation of rogue waves.
5. The Coriolis Force on Earth and in the Universe
"The reason for the formation of hydrogen sulfide in the Black Sea."
Institute of Oceanology RAS. https://vk.com/ioran
Mixing the wind, they enrich water with oxygen only to a depth of several tens of meters of the surface of the seas and oceans, while cyclonic gyres deliver oxygen-rich water to a depth of more than 10 km. (Mariana Trench).
How does this happen?
The waters of the lakes, seas and oceans of the northern hemisphere rotate counterclockwise, and the waters of the southern hemisphere rotate clockwise, forming cyclonic gyres. https://en.m.wikipedia.org/wiki/Ocean_gyre
And everything that rotates, including the cycles, has the property of a gyroscope - to maintain the vertical position of the axis in space regardless of the rotation of the Earth.
If you look at the Earth from the side of the Sun, the gyres revolving with the Earth turn over, due to which the gyres precess, resulting in vertical movement of oceanic waters. http://goo.gl/AM5g1s
The presented theory can be easily verified by relating the oxygen content,? With the rotation speed of the cycle.
Based on the map of the depths and currents of the seas and oceans.
The higher the flow rate, the greater the oxygen content and the lower the hydrogen sulfide content. https://youtu.be/ihM1I5r_MUg https://youtu.be/X6PavdKXIE8
List of low oxygen seas.
Black Sea, eastern Mediterranean, Gulf of Mexico, Norway fjords.
As we see, gyres are involved not only in the horizontal circulation of the waters of the seas and oceans, but also in the vertical.
https://en.m.wikipedia.org/wiki/Dead_zone_(ecology)
https://www.scientificamerican.com/article/ocean-dead-zones/
The coefficient of oxygen content can be expressed mathematically by the following formula O = V / G
V - rotation speed, km / h.
G - depth of the reservoir, km.
Black Sea 0.2 / 1200 = 0.00016.
Sea of ​​Okhotsk 1/800 = 0.0012.
Vertical movement of ocean waters can be modeled using simple experience.
For this, a half-filled vessel with a rotating liquid (bucket, tumbler, mixer) must be rotated around itself (in orbit).
If the liquid in the bucket rotates to the right, then the bucket around itself (in orbit) must be rotated to the left. http://bourabai.ru/articles/black_sea.htm
Vertical and horizontal circulation is a vital fundamental law of nature, without which life in the ocean would be impossible.
During the vertical and horizontal circulation, there are also side non-vital effects of nature associated with gyres, ebbs and flows, seasonal rise in sea level, killer waves.
The speed of sea currents in real time.
http://portal.esimo.ru/portal https://www.ndbc.noaa.gov
http://fermi.jhuapl.edu/sat_ocean.html
All physical processes that occur in the ocean occur in the atmosphere, in part, and in the mantle of the earth.
"The laws of nature are universal."
Lao Tzu.
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧
The mechanism of the formation of floods.
Faculty of Geography, MSU. https://m.facebook.com/groups/328946357209747
The main cause of rotation of gyres are local winds, flowing into the seas and oceans of the river and the deflecting force of Coriolis.
And the higher the speed of the winds, the higher the rotational speed of the gyres, thereby increasing the centrifugal force of the gyres and, as a result, the water level of the seas and oceans increases.
And the lower the rotation speed of the gyres, the lower the water level of the seas and oceans.
The speed of currents along the perimeter of the seas and oceans is not the same everywhere and depends on the depth of the coast.
In the shallow part of the seas and oceans, the flow moves fast, and in the deep water part of the seas and oceans the flow moves slowly.
Seasonal increase in the water level is observed not along the entire coast of the seas and oceans, but only on those coasts where a high angular velocity of currents and, as a result, a high centrifugal force of water. (Centrifugal force F = mv2 / r).
On straight coasts where currents do not have an angular velocity, the water level does not rise.
The waters of the Gulf of Finland rotate counterclockwise, forming a cycle in the form of an ellipse.
And when the seasonal storm westerly winds and the deep Neva River unleash the gyre of more than 7 km / h, the centrifugal gyre of the gyre increases, making the water level on the east coast of the Gulf of Finland more than 3 meters.
A similar pattern of seasonal increase in water levels is observed in all lakes, seas and oceans.
The average depth of the Gulf of Finland is about 50 meters, on the east coast about 5 meters, in the west of the bay about 100 meters. For this reason, on the east coast of the Gulf of Finland, the linear and angular velocity of the currents is much higher.
As far as the depth of the coast decreases, the speed of the currents increases.
Flooding in St. Petersburg.
https://en.m.wikipedia.org/wiki/Floods_in_Saint_Petersburg
In the Gulf of Finland, the seasonal increase in water levels has two peaks; in August-September and in December-January and in time coincide with the season of westerly winds and the high water of the Neva River.
The speed of the current in the Gulf of Finland exceeds 7 km / hour, and the maximum speed of the current on Earth reaches 30 km / hour, the wind speed is more than 100 km / hour.
If the storm wind moves in the direction of the current for several days, then the speed of the current increases several times.
The speed of the current depends on the wind speed, the duration of the wind and the height of the waves.
With an increase in wave heights, the windage of the waves increases and, as a result, the angle of attack of the wind increases.
http://goo.gl/eYVTo6
http://esimo.oceanography.ru/esp2/index/index/esp_id/1/section_id/6/menu_id/1734
The waters of the North Sea rotate counterclockwise, forming a huge circulation.
And when seasonal storm winds unleash the cycle, up to 20 km / h (on the southern coast), the centrifugal force of the cycle increases, so that on the southern coast of the North Sea the water level rises more than 5 meters.
(The storm surge is more than 2.5 meters, the centrifugal surge is more than 1 meter and the tides are more than 5 meters).
North Sea Flood 1953.
https://en.m.wikipedia.org/wiki/North_Sea_flood_of_1953
https://de.m.wikipedia.org/wiki/Datei:North_Sea_Currents.svg
The waters of the Caspian Sea rotate counterclockwise, forming a circulation in the form of an ellipse.
And when the deep-flowing Volga River spins the circulation more than 10 km / h, the centrifugal power of the circulation increases, so that on the northern coast of the Caspian Sea the water level rises more than 1 meter.
Centrifugal surge is an invisible water block at the mouth of the river.
https://ru.m.wikipedia.org/wiki/%D0%97%D0%B0%D1%82%D0%BE%D1%80
The average depth of the Caspian Sea is about 200 meters, on the north coast about 5 meters, on the south coast about 500m.
For this reason, on the northern coast of the Caspian Sea, the linear and angular velocity of the currents is much higher.
In the Caspian Sea, the peak of the seasonal water level increase is observed in June-August and coincides in time with the flood of the Volga River.
During a drought over the Volga River basin, the water level in the north of the Caspian does not rise.
http://tapemark.narod.ru/more/06.png
https://bigenc.ru/geography/text/2050560
In the Bay of Bengal, in the season of monsoon winds and floods of the Ganges River, the speed of rotation increases over 10 km / h, due to which the seasonal rise in water levels exceeds 15 meters.
(The storm surge is more than 2.5 meters, the centrifugal surge is more than 1.5 meters and the tides are more than 10 meters).
Bay of Bengal flood 1970.
https://en.m.wikipedia.org/wiki/1970_Bhola_cyclone
The seasonal increase in the level of the Black Sea (up to 40 cm) is most pronounced in the southeastern part of the sea, where in summer the angular velocity of the currents along the coast reaches its maximum value.
http://tapemark.narod.ru/more/07.html
The height of the floods depends not so much on the speed and direction of the wind, but on the speed of rotation of the cycle, due to which centrifugal surge and abnormally high tides are formed.
For this reason, on different coasts with the same wind speed, the height of floods varies.
In St. Petersburg, small floods occur during the calm and with the east wind.
Storm surge of high altitude in the Northern Dvina River can be formed under the influence of the north wind.
http://tapemark.narod.ru/more/22.png
https://vestnik5.geogr.msu.ru/jour/article/view/11?locale=ru_RU
If during a storm the deep rivers that flow into the bay do not create a whirlpool or the storm wind moves against the whirlwind, then the flood does not form and is easy to predict.
The assumption that the cause of the seasonal increase in the water level can be the pressure of the atmosphere, the flow of the rivers, the temperature difference and the salinity of the water do not hold water, these factors may raise the water level by several cm, but not more.
The presented theory can be easily verified by relating the speed of the current along the coast with the level of the seas and oceans.
(Based on a map of depths and currents, seas and oceans).
https://en.m.wikipedia.org/wiki/Annual_cycle_of_sea_level_height
https://research.csiro.au/slrwavescoast/sea-level/sea-level-change/
http://www.okeanavt.ru/tainiokeana/1066mifosrednemurovne.html
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧
The ebb and flow is the result of the rotation of the Earth and the gyres.
Tides are not formed along the entire coast of the seas and oceans, but only on those coasts where there is a high speed of currents.
And the higher the speed of currents along the coast, the higher the amplitude of the tidal wave.
On those coasts where the speed of currents is 0 km / h, the amplitude of the tides is also 0 meters.
And everything that rotates, including the cycles, has the property of a gyroscope - to maintain the vertical position of the axis in space, regardless of the rotation of the Earth.
If you look at the Earth from the side of the Sun, the gyres, rotating with the Earth, turn over twice a day, thanks to which the gyres precess (sway by 1-2 degrees) and reflect a tidal wave from themselves along the entire perimeter of the gyre.
https://goo.gl/images/M4SJq8 http://goo.gl/AM5g1s
The waters of the White Sea rotate counterclockwise, forming a huge gyroscope whirlwind, which precessing reflects the tidal wave along the entire perimeter of the White Sea. A similar pattern of tides is observed in all lakes, seas and oceans.
White Sea. http://rivermaps.ru/doc/beloe/beloe-3.htm
The waters of the Mediterranean Sea rotate counterclockwise, forming tides 1015 cm high. In the Gulf of Gabes, off the coast of Tunisia, the height of the tides reaches three meters, and sometimes more, and this is considered one of the mysteries of nature. But at the same time, the whirlpool rotates in the Gulf of Gabes, precessing reflecting an additional tidal wave. https://youtu.be/wlvkrRdYNZ0
The tidal wave in the Amazon River creates a huge planetary circulation with a diameter of several thousand km., Rotating between South America and North Africa, covering the mouth of the Amazon River.
The pattern of movement of the tidal wave along the perimeter of the North Atlantic planetary circulation (according to satellite data). http://goo.gl/R1hx0H
The length of the tidal wave depends on the diameter of the rotation.
The height of the tidal wave depends on the rotation speed of the rotation, the orbital velocity of the Earth and the time of the rotation of the rotation (12 hours).
A = V1 V2 / t
Where, A is the amplitude of the tidal wave.
V1 is the rotation speed of the rotation.
V2 is the orbital velocity of the Earth.
t is the time of the rollover of the cycle (12 hours).
Table of tidal amplitude versus current velocity, on all coasts.
1 km / h - 1 meter.
5 km / h - 5 meter.
10 km / h - 10 meter.
15 km / h - 15 meter.
The amplitude of the tides also depends on the size of the cycle, the amount of water under the cycle, the distance from the coast to the cycle and on the direction of the current (north, south, west, east).
The currents that move along the equator reflect a tidal wave north and south twice a day.
And the currents that move along the meridian reflect a tidal wave west and east 1-2 times a day.
A simple experiment can be made if you rotate the globe around the axis and in orbit, entwined along the equator and meridian with a plastic hose in which the fluid moves.
By the height of the tides, you can determine the speed of the current along the coast, relying on the map of sea currents.
覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧覧
Geofak Moscow State University. https://m.facebook.com/groups/328946357209747
A huge number of tidal waves move in the seas and oceans.
When tidal waves collide with the coastline of the continents, tides are formed.
When two tidal waves collide in the open ocean, a killer wave forms.
https://en.m.wikipedia.org/wiki/Rogue_wave
The magnitude of the killer waves can be calculated using the following formula: H = T1 T2.
Where T is the kinetic energy of the tidal wave.
Experiment to the topic: The mystery of the Bermuda Triangle - killer waves https://youtu.be/4aTl9GQFKLo
As we see, killer waves are formed only in those seas where tidal waves are formed and the higher the amplitude of the tides, the higher the killer waves.
In seas where tides do not form, killer waves do not occur.
List of seas where tides and killer waves are formed, more than 50 cm high:
Irish Sea, North Sea, Barents Sea, Baffin Sea, White Sea, West Mediterranean, Bering Sea, Sea of ​​Okhotsk, Arabian Sea, Sargas Sea, Hudson Bay, Maine Bay, Alaska Bay, etc.
List of seas where tides and killer waves are formed, less than 50 cm high:
Baltic Sea, Greenland Sea, Black Sea, Sea of ​​Azov, Chukchi Sea, Kara Sea, Laptev Sea, Red Sea, Sea of ​​Marmara, Caribbean Sea, Sea of ​​Japan, Gulf of Mexico, etc.
In the season of abnormally high tides, abnormally high killer waves form.
The highest tides and killer waves are formed in the North Atlantic, in the Pacific Ocean in the Sea of ​​Okhotsk, etc.
You can conduct a simple experiment if two stones are simultaneously thrown into a bath of water. (the distance between the stones is 10 - 15 cm).
When a tidal wave collides, the emerging killer wave foams and a larger wave pulls through a smaller wave somewhat.
You can create a killer wave with a height of 0.3 meters and a duration of 0.5 seconds, if two divers at the same time jump "bomb" into the pond from a height of 2 meters. (distance between jumping 3 meters).
If, in a cup with water, hit simultaneously with two tablespoons and a "killer wave" is formed there.
The mechanism of formation of the tidal hump in the river, and killer waves in the oceans is similar and the height of the tidal hump in the river depends on the kinetic energy of the current in the river, and the kinetic energy of the tidal wave.
https://images.app.goo.gl/fNxSM5ZBGN5evNQi9
Tidal waves move in the open ocean in different directions, at speeds up to 100 km / h, they are also called solitons or Rossby waves.
Barely visible tidal waves colliding with storm waves create a killer wave and are the main cause of the wreck of ships.
https://goo.gl/images/icF4zf
The map shows the areas of the most frequent occurrence of killer waves.
In the North Atlantic, killer waves form mainly around the perimeter of the North Atlantic planetary cycle as a result of the collision of tidal waves with storm waves (three sisters).
Suloy is a throw of water on the surface of the sea.
https://ru.m.wikipedia.org/wiki/%D0%A1%D1%83%D0%BB%D0%BE%D0%B9
The hypothesis that the superposition of wind waves can be the cause of the formation of rogue waves does not stand up to criticism, since rogue waves are also formed during a calm period. (Wind waves do not form a tidal wave).
The statement that methane floating from the bottom of the ocean sharply reduces the density of water and the vessel loses buoyancy is also not true, since a decrease in the density of water cannot cause mechanical damage to ships and oil platforms.
The crews of the ships always record the impact of a huge wave, but no one has yet been able to record the methane emission.
In the North Sea, off the coast of Norway, on the Dropner oil platform on January 1, 1995, during a 12-meter storm wave, a killer wave of 25.6 meters was formed.
https://en.m.wikipedia.org/wiki/Draupner_wave
I believe the reason for this natural phenomenon is a tidal current that moves along the coast of Norway from west to east, reflecting a tidal wave from itself, both towards the coast and towards the open sea.
Also, north of the Dropner oil platform through the Pentland Firth Strait, a current moves at a speed of 16 knots from west to east, reflecting a tidal wave north and south.
https://www.equinor.com/en/what-we-do/partner-operated-fields-in-norway/draupner.html
In the North Sea, only storm and tidal waves move.
And only, the interaction of tidal and storm waves can be the cause of the formation of killer waves.
« Last Edit: September 04, 2020, 03:26:14 AM by Fermer05 »
Re: Whirlpool theory of ocean deadzones?
« Reply #1 on: December 22, 2018, 09:07:58 AM »
Interesting.
That third link https://youtu.be/ihM1I5r_MUghttps://youtu.be/X6PavdKXIE8 returns a 404 Not Found error.
Offline Fermer05
« Reply #2 on: December 22, 2018, 09:32:51 AM »
Interesting.
Thank you sent.
Criticism of the lunar theory of tides.
According to the Static Tidal Theory, the Lunar tidal wave moves from east to west following the moon, at a speed of 1600 km / h, skirting the Earth in 24 hours, flooding only the eastern shores of the continents. But after centuries it was discovered.
1. That the Lunar tidal wave floods both the western and southern and northern coasts of the continents?
2. That the speed of a tidal wave of 1600 km / h is detrimental to both continents and marine fauna?
3. That not two tidal humps function simultaneously across the globe, but more than a hundred, regardless of the location of the Moon?
4. That abnormally high tides for some reason are formed in semi-closed bays, where there is no direct access to the tidal wave. And in the bays open to the tidal wave, there are no tides at all, or are they small?
Later, the Dynamic theory of tides was proposed, which was supposed to answer all the questions posed.
According to the dynamic theory of tides, the Lunar tidal wave moves from east to west at a speed of 800 to 1600 km / h.
Crashing into the continents, part of the wave is scattered in place, and the reflected part rotates around the ocean, thanks to the Coriolis effect. Like water that spins in a cup when you slide the cup back and forth.
The only link on the Internet that reveals the "essence" of the dynamic theory of tides. http://ffden-2.phys.uaf.edu/645fall2003_web.dir/Ellie_Boyce/dynamic.htm
But the dynamic theory of tides does not answer all the questions posed.
1. What is the mechanism of tidal wave scattering in the region of collision of the tidal hump with the continent?
2. If the cup of water is moved back and forth, the water will splash out and not rotate.
3. How does the tidal current that travels along the coast create the ebb and flow?
4. While the tidal wave makes one revolution around the Earth, the Moon makes two revolutions, how is the gravitational connection between the Moon and the tidal hump carried out?
5. In order for the Lunar tidal hump to exist, a nonuniform gravitational field is necessary, and for this, the Moon must constantly be above the hump, otherwise the hump will fall apart?
6. If the Moon created the tidal hump on Earth, it would not be an ellipse but a "drop". (The force of gravity is stacked, not compensated)?
7. Tidal waves are synchronized with the diurnal rotation of the earth and lag behind by 50 minutes daily.
The moon is out of sync with the tidal waves. (There is only one moon, but there are hundreds of tidal waves on Earth)?
8. It is believed that the abnormally high "Tides of the Century" with an amplitude of 15 meters in the Gulf of Saint-Malo, France, formed during the parade of planets. Then why, in other bays of France and the northern hemisphere, during the parade of the planets, abnormally high "Tides of the century" are not formed.
Moreover, in some bays of France during the parade of the planets, abnormally low tides of the century are formed.
9. According to the lunar tide theory, the maximum tides in the northern hemisphere should occur in the summer, when the moon and sun move over the seas of the northern hemisphere.
In reality, the maximum tides in the northern hemisphere are formed - in spring and autumn, when the Moon and the Sun are in the southern hemisphere.
The record high tide in the Bay of Fundy - 21 meters - occurred on the night of October 5, 1869, when the Moon and Sun were in the southern hemisphere.
The cyclical theory of tides explains this by the fact that the speed of rotation of the gyres increases in spring and autumn.
10. How to explain the fact that in the Southwest Australia in the port of Fremantle the tides are significant for part of the year and then disappear.
Once a year, in the Northern Dvina delta, during the spring flood, the ebb and flow mysteriously disappear for several days, sometimes for a week, and this is considered one of the mysteries of nature?
11. According to the Lunar tide theory, the maximum tides are formed in the phase of the new moon and full moon, and the minimum - in the first and last quarter.
But in reality, the maximum tides are formed in the new moon phase, the minimum - in the full moon phase.
12. The modern tide table is made by trial and error, and adjusted to the lunar theory of tides.
It is quite easy to compile a tide table by trial and error, for the reason that the tide heights are almost the same every year, except for the bays into which the rivers flow.
Tide tables were compiled long before the discovery of tide theory (by trial and error).
The same tables are used today; they are updated annually based on long-term data.
13. What theory was the Chinese tidal calendar based on in 1100?
The editorial board of the journal is ready to withdraw the article if an objective critical review is written. Scientific journal "NBIKS-Science. Technologies" http://www.rusnor.org/pubs/articles/15638.htm
The rule of recall (retraction) of an article from publication
https://rasep.ru/sovet-po-etike/pravilo-otzyva-retragirovaniya-stati-ot-publikatsii
« Last Edit: August 20, 2020, 12:38:48 AM by Fermer05 »
Offline Fermer05
« Reply #3 on: January 09, 2019, 06:53:42 PM »
Criticism of the lunar theory of the tides.
According to the lunar theory of tides, in temperate zones tidal force raises the earth's crust to a height of 20 cm, and at the equator more than 50 cm.
Then why are the tides in the equatorial zone three times lower than in the temperate zones?
The maximum height of the tides in the temperate zones is:
1) Fundy Bay in North America - 18 m.
2) The mouth of the Severn River in England - 16 m.
3) Bay of Mont Saint-Michel in France - 15 m.
The maximum height of the tides in the equatorial zone is:
1) Maraca Brazil - 9 m.
2) Balboa Panama - 5 m.
3) Zanzibar Tanzania - 3.5 m.
Information about the tides in some ports of the world.
https://www.krugosvet.ru/enc/Earth_sciences/geografiya/PRILIVI_I_OTLIVI.html
The tidal cycle theory explains this discrepancy by the absence of the Coriolis force at the equator, which is necessary for the formation of cycles, cyclones and anticyclones.
https://qph.fs.quoracdn.net/main-qimg-a0730201f0f095995e9cc6c7c9875519
According to the lunar theory of tides, abnormally high tides should occur at the equator and not in the temperate zones.
Quote: 殿 half-meter lunar tidal wave , such as a mini-tsunami, rushes to the eastern coast of the continents at the equator at a supersonic speed. https://scfh.ru/lecture/prilivy-i-otlivy-v-moryakh-i-vo-vselennoy/
https://youtu.be/NqDEaFjIXPw
How to understand the fact that the amplitude of the tides in the Bay of Fundy yesterday was 6 meters, and today is 18 meters?
What changes have occurred overnight, for such a sharp jump?
We have two possible answers:
1. For a day, the force of gravity increased three times.
2. During the day, the rotation speed of the rotation has increased three times.
Record high tide in the Bay of Fundy - 21.6 meters - occurred only once in the entire history of observations, on the night of 4 to 5 October in 1869.
On the night of October 4-5 in 1869, under the influence of the Saxby Gale cyclone, a record rainfall fell over the river basins flowing into the Bay of Fundy (300 mm per day), thanks to which the waters of the Bay of Fundy poured into the Bay of Man and increased their rotation speed gyre in the Gulf of Maine three times.
During the flood of rivers flowing into the Bay of Fundy, the current speed in the north of the Gulf of Maine rises to 20 km / h, with the result that the height of the tides reaches 18 meters.
During a drought over the basins of rivers flowing into the Bay of Fundy, the amplitude of the tides does not exceed three meters.
And the most important question is why in the season of abnormally high tides in the Bay of Fundy, in other bays of the Northern Hemisphere, the amplitude of the tides does not increase?
A similar pattern of abnormally high tides (floods) is observed in all bays into which rivers flow.
Real-time animation shows how waters flowing into the Bay of Man from the Bay of Fundy form a cycle that, precessing, reflects a tidal wave toward the Bay of Fundy.
https://earth.nullschool.net/?fbclid=IwAR3fDQD_uF0xgVpETpxVzbrv2xxgzOR0UfAKIEFDHAKoC2jzE-Mpu1lIWMs#current/ocean/surface/currents/equirectangular=-65.27,44.29,3000/loc=-66.405,44.310
https://images.app.goo.gl/hAE4F7kyMQ1mhcAF9
Mezen Bay White Sea tide height reaches 10 m.
https://earth.nullschool.net/?fbclid=IwAR245zpmdxn7SmOQdJ7qF9HhRn-54AYSZIChWmA6-0A2rXyJ9y2UivmtlZA#current/ocean/surface/currents/equirectangular=42.30,67.95,3000/loc=44.019,65.946
Tides - table. http://www.prilivy.com
Why is there a high content of hydrogen sulfide in the east of the Mediterranean Sea and there are no tides?
According to the 斗unar theory of tides, a tidal wave enters the Mediterranean Sea through the Strait of Gibraltar, pulsating every 12 hours and until the east of the Mediterranean tidal wave barely reaches.
And according to the circulation theory of the tides, the flow that flows into the Mediterranean Sea spins the cycles much faster than in the east of the Mediterranean Sea. https://youtu.be/wlvkrRdYNZ0
According to the 斗unar theory of tides, a tidal wave in the Atlantic Ocean moves from east to west after the moon, and crashes into the eastern coast of South and North America.
Then, reflecting, it moves back east and flows into the throat of the Mediterranean, Baltic, White and other seas.
The pattern of tidal wave movement from the North Atlantic Ocean to Chukotka. https://www.esr.org/research/polar-tide-models/movies/?fbclid=IwAR3fB506PI_LBQcjUyDVVjtSjLNW_voHpajgMBjuTXOPK9I4aMGcdT8rFYg
The height of the tides in the west of the Mediterranean Sea reaches 1.2 meters, in the east of 15 cm.
The average depth of the Mediterranean Sea is 1500 meters, in the east 1700 meters. The maximum depth is 5000 meters.
In the Indian Ocean, a tidal wave with a height of 0.5 meters, obeying the dynamic theory of tides, moves from east to west at a speed of 800 - 1600 km / h. Crashing into the eastern coast of the island of Madagascar creates tides 1.5 meters high, and abnormally high tides up to 7 meters high, for some reason are formed in the west of the island of Madagascar.
And it should be the other way around.
Wikipedia explains this discrepancy by the reflection of waves and the fact that the Coriolis force does its job.
And the real reason for this inconsistency is the giant cycle that revolves around the island of Madagascar at a speed of up to 9 km / h, precessing, reflecting a tidal wave towards the west coast of the island of Madagascar.
https://youtu.be/jJ8aARJobXc
https://ru.m.wikipedia.org/wiki/Train_mys_Igolny
https://ru.m.wikipedia.org/wiki/Mozambique_current
Wikipedia explains the tidal physics in many languages ​​of the world, and different formulas are written in each language, and in some languages ​​there are no formulas at all.
And there are no real, digital calculations of the tidal heights of a particular bay or coast.
https://en.m.wikipedia.org/wiki/Tide
By the degree of discrepancy of a particular theory, one can judge the degree of inaccuracy of the theory.
In Wikipedia and the encyclopedia, gravitational and centrifugal forces are equally explained in all languages.
https://en.m.wikipedia.org/wiki/Gravity
https://en.m.wikipedia.org/wiki/Centrifugal_force
The modern table of tides is made by trial and error and customized to the lunar theory of tides.
According to the lunar theory of tides, maximum tides are formed in the phase of the new moon and full moon.
And according to the tidal theory of tides, the maximum tides are formed in the new moon phase and the minimum in the full moon phase.
Creating a tidal table by trial and error is quite simple, because the height of the tides is almost the same every year, with the exception of the bays into which the rivers flow.
Tide tables were compiled long before the discovery of the theory of tides (trial and error).
The same tables are used today, they are annually adjusted based on long-term data.
Based on the "lunar theory of tides", tides can be predicted for many years to come.
And based on the tidal theory of tides, it is not possible to predict the height of tides, because it is not known at what speed tomorrow the cycles will rotate.
In the Bay of Fundy, the lunar theory does not work, due to the large range of tidal amplitudes, from 6 to 18 m.
Lunar theory predicts well where there is a small range of tidal amplitudes, from 0.5 to 1 m. (There will be a small error).
Galileo called the lunar theory of the tides frivolous, a sad return to the realm of mystical nonsense, and preferred to explain the tides by the rotation of our planet.
D.G. Darwin wrote in 1911: 典here is no need to search for ancient literature for the sake of the grotesque theories of tides. However, sailors manage to measure their height and use the possibilities of the tides, not having an idea of ​​the real causes of their occurrence.
The problem with the study of tides is that researchers are hesitant to completely abandon the influence of the moon on tides. Arguing that since high tides form in the new moon, the Moon is involved in the tides, without noticing, with a dozen other inconsistencies.
But in reality, in the new moon the orbital speed of the earth is maximum, for this reason high tides are formed.
The tide table was compiled before and after the static theory of tides by trial and error, based on experience and long-term data.
At one time, the solar calendars were also compiled by trial and error, relying on experience and long-term data, being sure that the sun revolves around the earth.
The tidal cycle theory can be easily verified by relating the tidal height to the rotation speed of the cycle.
List of seas, with an average flow rate of more than 0.5 km / h and tidal heights of more than 50 cm:
Irish Sea, North Sea, Barents Sea, Baffin Sea, White Sea, Bering Sea, Sea of ​​Okhotsk, Arabian Sea, Sargas Sea, Hudson Bay, Maine Bay, Alaska Bay, etc.
List of seas, with an average flow rate of less than 0.5 km / h, and a tidal height of less than 50 cm:
https://simple.m.wikipedia.org/wiki/List_of_seas
USSR Sea http://tapemark.narod.ru/more/
« Last Edit: February 13, 2020, 03:59:20 PM by Fermer05 »
Offline Fermer05
Re: The mechanism of thermoregulation of the Earth
« Reply #4 on: February 04, 2020, 04:43:57 AM »
"The Coriolis Force on Earth and in the Universe."
Community of Russian scientists https://vk.com/rosuch
The Coriolis effect occurs when an object approaches or moves away from the axis of the Earth.
At the same time, when an object that moves on the Earth approaches or moves away from the axis of the Sun, the Coriolis Solar Force arises.
The deflecting Coriolis Solar Force, due to the axial and orbital rotation of the Earth, is much more complicated.
The course of the Volga River is constantly pressed against the western bank of the river, by the force of the Coriolis Earth.
And the Coriolis Solar Force, due to the axial and orbital rotation of the Earth, deflects the Volga River first to the west coast, then to the east, twice a day.
For this reason, winding currents form in the seas and oceans.
The aforesaid can be easily verified by rotating the globe around the axis and in orbit. Wrapped along the equator and meridian with a plastic hose in which fluid moves. http://astrogalaxy1.narod.ru/astro016.html
The Coriolis effect of the Earth does not depend on the inclination of the axis of the earth, and the Solar Coriolis force depends.
The solar Coriolis effect is involved in the formation of the moon ellipse.
When the Moon revolving around the Earth in the last quarter approaches the Sun at a speed of 1 km / s, and in the first quarter moves away from the Sun at a speed of 1 km / s, the Coriolis solar force stretches the moon's orbit along the Earth's orbit, due to which an ellipse of the Moon is formed.
When the moon is in the phase of the new moon and the full moon, the solar Coriolis effect does not affect the orbit of the moon, because in these phases the moon does not approach and does not move away from the sun.
https://youtu.be/OZIB_leg75Q
The eccentricity of the Moon's orbit can be calculated using the following formula. E = Vz / Vl = 0.0411 / 0.55 = 0.0747
Where Vz - Earth's orbital speed - 0.0411 degrees / hour.
Vl - Moon's orbital speed - 0.55 degrees / hour.
E = (Vz / Sz) / (Vl / Sl) = 0.00071 / 0.0095 = 0.0747
Where Vz is the Earth's orbital speed - 107,218 km / h.
Sz - Distance from the Sun to the Earth - 150,000,000 km.
Where Vl is the Moon's orbital speed - 3683 km / h.
Sl - Distance from the Earth to the Moon 384,000 km.
The eccentricity of the Moon's orbit varies, from 0.026 to 0.077.
Both formulas show that the average eccentricity of the Moon's orbit is 0.0747.
And the average eccentricity of the moon's orbit, obtained using radar, is 0.054.
http://www.aggregateria.com/R/radiolokatsionnaja_astronomija.html
Also, the eccentricity of the Moon's orbit can be determined by the following formula. E = Vl / Vz = 27.3 / 365.2 = 0.0747
Where Vl is the Moon's orbital angular velocity.
Vz - Orbital angular velocity of the Earth.
By dividing the orbital speed of the Moon by the eccentricity of the Moon's orbit, the Earth's orbital speed can be calculated. https://en.m.wikipedia.org/wiki/Moon
The statement that the Moon's orbit rotates and makes one revolution in 8.8 years does not correspond to reality, since the Solar Coriolis effect constantly stretches the Moon's orbit along the Earth's orbit.
https://en.m.wikipedia.org/wiki/Apsidal_precession
Based on the fact of the approach and removal of the moon from the sun, it is possible to construct. Reactionless drive. https://youtu.be/4_M-fBv5Xmc https://youtu.be/1Y7Pptwmva8
The reason for the geological activity of the planets is also the Coriolis solar force.
The side of the Earth that is at dawn, due to the daily rotation of the Earth, approaches the Sun at a speed of 1600 km / h, and the side of the Earth that is at sunset moves away from the Sun at a speed of 1600 km / h. Due to this, the Coriolis solar force stretches the Earth along the Earth's orbit, and as a result, the geological activity of planets and satellites increases. (Spinning planets heat up, similar to a flat tire in a car.)
The high geological activity of Jupiter's moon Io can be explained by the fact that the axial and orbital velocity of Io is 15 times greater than that of the Moon.
Io's orbital speed is 17 km / s, and the Moon's orbital speed is 1 km / s. Io's axial velocity is 1 revolution per 42 hours, and the moon's axial velocity is 1 revolution per month.
The distance from Jupiter to Io, the surface temperature and diameter of Io are the same as those of the Moon.
Geologically active are also Earth, Jupiter, Ceres, Enceladus, etc.
The geological activity of Venus and Mercury, due to the slow rotation, is extremely low. https://images.app.goo.gl/EC2iXou7XDLBWMB66
If Io gets closer to Jupiter, then the axial and orbital velocity of Io will increase, due to which the Solar Coriolis force can tear Io into numerous pieces, which will then be located along Io's orbit, forming a ring.
Perhaps the Shoemaker Comet, Levi 9, was torn apart by the Solar Coriolis effect as it approached Jupiter at perihelion.
At the time of the comet's rupture, the distance from Jupiter to the comet reached about 40,000 km, and the orbital speed was 60 km / s. https://en.m.wikipedia.org/wiki/Comet_Shoemaker%E2%80%93Levy_9
It is possible that the asteroid belt formed from a planet that, due to an increase in axial velocity, was torn apart by the Coriolis solar force.
https://en.m.wikipedia.org/wiki/Asteroid_belt
The coefficient of geological activity of planets depends on the diameter, axial and orbital speed of the planets.
The video shows how the Coriolis solar force is pulling the Earth and the Moon's orbit along the Earth's orbit. https://youtu.be/JgU93nrv0iA
The Earth痴 orbit is formed by the Galactic Coriolis force.
When the Earth, revolving around the Sun, approaches and moves away from the center of the galaxy at a speed of 30 km / s, the galactic Coriolis force stretches the Earth痴 orbit along the orbit of the Sun, due to which the Earth痴 orbit similar to the Lunar one should form. https://en.m.wikipedia.org/wiki/Galactic_year https://en.m.wikipedia.org/wiki/Milky_Way
But the orbits of the planets are not stretched along the orbit of the Sun, which means that the Sun does not revolve around the center of the galaxy, but is in space, in a motionless state.
The reason for the formation of the ellipse of the planets and the reason for the rotation of the orbits of the planets is in the problem of two bodies, which has not yet been solved, like the problem of three bodies.
The statement that the ellipse of the planets is formed due to the disturbance of the planets does not stand up to criticism, since Venus and Neptune move in a circular orbit. https://m.habr.com/en/post/411567/
The objects of the solar system cannot endlessly revolve around numerous centers.
The laws of celestial mechanics are not omnipotent and are limited by the task of three bodies. The Earth revolves around the Sun, the Moon revolves around the Earth, and nothing revolves around the Moon. No natural planetary satellite has a permanent or temporary satellite, because this will be the task of four bodies, which contradicts the laws of being.
In nature, there is no relationship without symbiosis, and in the center of the galaxy, the solar system does not need.
https://spaceworlds.ru/solnechnaya-sistema/orbity-planet.html
And the main question is why planetary satellites do not have satellites, and asteroids possess satellites. Despite the fact that asteroids are much smaller than planet satellites. https://en.m.wikipedia.org/wiki/Minor-planet_moon
The two satellites of Saturn, Janus and Epimetheus, move in the same orbit, and overtake each other every four years.
If these two satellites revolved around the Sun, then Janus would capture Epimetheus. https://elementy.ru/kartinka_dnya/430/Tanets_Yanusa_i_Epimeteya
Based on the foregoing, we can put forward the hypothesis of the formation of the solar system.
1. The solar system is an autonomous object of the Universe and does not revolve around the center of the "galaxy" but is in space, in a stationary state.
2. Sunlight, due to the deflecting force of the Coriolis, revolves around the solar system.
3. At the edge of the solar system, sunlight rotates against the rotation of the sun, at a speed of about 0 km / s, relative to the universe. https://images.app.goo.gl/GZMt3h1e1dH86wWN6
4. The radius of the solar system depends on the speed of light and the angular velocity of rotation of the sun. R ≈ c / ω
The speed of light ≈ 1,000,000,000 km / h.
The angular velocity of the Sun ≈ 0.0105 rad / h.
The radius of the solar system is ≈ 95,000,000,000 km.
http://universetoday-rus.com/blog/2008-07-16-10
5. I believe the stars are huge luminous balls that formed from sunlight.
6. Sunlight transforms into nebulae, stars, globular clusters, galaxies, Kuiper belt, asteroids, protoplanets, planets, which after billions of years, spinning, fall back onto the Sun. There is a cycle of solar matter in nature. Otherwise, for billions of years of its existence, the Sun has long been burned.
7. Outside the solar system, sunlight does not penetrate and it will be impossible to see the solar system from the side of the universe.
8. A planet is an object in the Solar System that has an atmosphere, daily rotation, etc. https://en.m.wikipedia.org/wiki/IAU_definition_of_planet
9. All mechanical processes that occur in the atmosphere also occur in the starry sky.
10. The hypothesis that the Moon was formed from the rings of the Earth, and Mercury is a former satellite of Venus, is within the laws of celestial mechanics.
11. In the solar system, everything is programmed and everything moves according to the strict laws of celestial mechanics, due to which randomness and chaos are not possible in the solar system.
12. The theory of the evolution of the Universe should not contradict and go beyond the laws of celestial mechanics. http://www.ponjatija.ru/node/938
Everything is relative!!!
The mechanism of rotation of cyclones, anticyclones, cycles and galaxies is one and the same. This can be verified by comparing these two pictures.
https://images.app.goo.gl/1QaUggrb6N1qQ3xF8 https://images.app.goo.gl/xozpZJsAfkq1owoX9
The galaxy is a single slowly rotating "monolith", which does not obey the law of gravity, because all stars in galaxies rotate with the same angular velocities (like a gas tank cover).
And in the solar system - the farther from the sun the planet is, the lower the orbital speed of the planet. While Neptune makes one revolution around the Sun, Mercury makes more than 500 revolutions.
The orbital speed of Mercury is 50 km / s, and Neptune is 5 km / s. https://life.ru/p/907112
Based on the foregoing, we can conclude that in the center of the galaxy is the eye of the storm, and not a black hole and dark matter. https://en.m.wikipedia.org/wiki/Eye_(cyclone) https://en.m.wikipedia.org/wiki/Galaxy_rotation_curve
Black holes leave their galaxies. https://news.rambler.ru/scitech/43938566-astronomy-pokazali-kak-chernye-dyry-pokidayut-svoi-galaktiki/ https://youtu.be/pnbJEg9r1o8
Astronomers accidentally discovered a strange star escaping from the Milky Way.
https://in-space.ru/astronomy-sluchajno-obnaruzhili-strannuyu-zvezdu-ubegayushhuyu-iz-mlechnogo-puti/ https://youtu.be/f_w6JprsXK8
The black hole spawned a unique kind of planet. https://m.lenta.ru/news/2020/04/27/hole/amp/
Own movement of stars. https://spacegid.com/zvezda-barnarda.html
Regeneration of cyclones. https://slide-share.ru/regeneraciya-anticiklonov-28872
There are no answers to the following questions:
1. In the solar system, all eight planets revolve around the sun in the same plane.
a) And the stars, rotating around the nucleus of the galaxy, form dozens of planes.
b) What force is involved in the formation of the lenticular form of the galaxy?
c) Within the laws of celestial mechanics, stars should rotate around the core of the galaxy in only one plane, similar to the planets of the solar system.
2. The statement that globular star clusters are satellites of galaxies and rotate in very elongated orbits at a speed of ≈ 200 km / s also goes beyond celestial mechanics. https://images.app.goo.gl/7HbHogMoCKWPswX18
a) If only globular star clusters revolved around the galaxy, then globular star clusters would have a disk shape. https://en.m.wikipedia.org/wiki/Galaxy
b) Will Saturn and its satellites be able to rotate around the Sun, in the form of a globular cluster?
3. In globular star clusters, there is no orbital rotation of stars.
a) Then what forces form a globular cluster of stars?
4. If globular star clusters are satellites of galaxies, then star clusters should have, rotation axis, libration, etc. https://en.m.wikipedia.org/wiki/Globular_cluster
Magma - the gateway hypothesis of earthquakes
Community of Russian Scientists.
Rotating, the crust of the Earth carries away magma, due to which dozens of magma-gorots are formed.
Magma - gates move along the equator from west to east, with variable speed, stopping at times, similar to cyclones and anticyclones.
Blocking anticyclones. http://meteoweb.ru/2018/phen20180730.php
Before the earthquake, the magma - the gate stops moving, due to which the vacuum between the magma - the gate and the Earth's crust increases, due to which the earth's crust sinks down and the magma rises up, and as a result, a collision of the earth's crust and magma occurs.
A similar natural phenomenon occurs in the seas and oceans, when a whirlpool rotates under the ice. https://images.app.goo.gl/3sRSRbVsEbWtMoVY6
Harbingers of earthquakes:
1. Before the earthquake, the magma pressure increases along the perimeter of the epicenter, and decreases in the center.
a) If the soil above the magma-gate is loose, then the soil sinks onto the magma, and if it is solid, then the magma cuts into the soil. https://bigenc.ru/geology/text/2037208
2. Above the epicenter of a future earthquake, there may be changes in geophysical fields (magnetic, electric, gravitational, etc.).
http://mari-el.gov.ru/morki/semisola/Pages/News/20190820_2.aspx
The intensity of earthquakes can be expressed by the formula A = v / h
v - speed of rotation of magma - gate.
h - the height of the earth's crust above the magma-gate.
Also, magma - gates possessing the properties of a gyroscope, precessing, reflect a tidal wave, upon collision of which killer waves are formed.
You can set up an experiment if a half-filled vessel with rotating water (bucket, jug, mixer) is rotated around itself (in orbit). If the liquid in the bucket rotates to the right, then the bucket around itself (in orbit) must be rotated to the left.
An experiment can be carried out by rotating a round vessel with a thick liquid.
Magma - gates - one of the mechanisms of the Earth's thermoregulation.
Cyclonic Magma - The gate is a magmatic vortex that throws magma upward from the center of the Earth.
Anticyclonic magma - the gate, on the contrary, draws in magma from the upper layers of magma, and sends it to the center of the Earth. https://obrazovaka.ru/geografiya/ciklon-i-anticiklon-oboznachenie-chem-otlichayutsya.html
The reason for the axial rotation of the Earth is cyclones and anticyclones, which move in the direction of the general transport of air from west to east. https://meteoinfo.ru/ugryumov/2926-ugryumov-perenos
The geological activity of the planets depends on the diameter, axial and orbital speed of the planets.
Geologically active are Earth, Jupiter, Ceres, Enceladus, Io, etc.
The geological activity of Venus and Mercury, due to the slow axial rotation, is extremely low. http://www.evgengusev.narod.ru/spb/zhirnov-2011.html
It is possible that solar activity is the result of the geological activity of the Sun. And sunspots are funnels of magma-vortexes. https://www.spaceweatherlive.com/ru/pomoshch/chto-predstavlyayut-soboy-solnechnye-pyatna.html
Due to the rotation of the Earth, centrifugal force acts on the earth's crust, but due to the orbital rotation of the Earth, the centrifugal force of the Earth oscillates, due to which the earth's crust moves. It is also possible that the volume and mass of the Earth grows over the years.
Criticism of the tectonic hypothesis of earthquakes.
1. Why do earthquakes occur both at the junction of tectonic plates and in the center of the plate?
2. The statement that the Earth's crust accumulates tectonic stress is questionable. (This can be easily verified by putting experience).
3. Vibrations from earthquakes are transmitted in the form of seismic waves over a distance of more than 10 thousand km. Then why, seismic waves do not provoke earthquakes in other regions of the Earth?
4. Tectonic plates, cannot have the properties of a spring or rubber https://youtu.be/3I_Eoo6XQ-U
5. Why the epicenter is circular and not elongated along the fault line.
Why foreshock and aftershock are not formed along the fault line.
6. The statement that the plates move due to the temperature drop in the bowels of the Earth is questionable.
a) It is also doubtful that lithospheric plates can sink into the planet's mantle and reach the depth of the outer core.
b) If the lower lithospheric plates easily sink into the Earth's mantle, then during the creeping of the plates, the lower plate should easily sink down.
7. It is believed that the depth of the gypocenter reaches 700 km, questions arise:
a) How to interact plates at such a depth, if we consider that the thickness of the continental bark is about 30 km, and the oceanic 5 km?
b) How does energy transfer mechanism from the hearth to the epicenter, at a distance of 700 km?
C) What will the epicenter area be equal, if we consider that the diameter of the epicenter depends on the distance from the hearth to the epicenter? https://en.m.wikipedia.org/wiki/Epicenter
8. You can carry out a simple experiment, if in a pool of water to move towards each other two rubber or wooden plates.
Continuation: "The mechanism of thermoregulation of the Earth."
Forum on the flagship. https://vmf.net.ru/forums/viewtopic.php?f=6&t=2328&sid=a49d602d08c50eda4f043b73838e5f8a
Forum of Nizhny Novgorod State University named after N.I. Lobachevsky.
http://forum.unn.ru/viewtopic.php?f=39&t=10331&sid=cfbc49e0cf32263eff20888ca205ab15
The opening was published in the Russian-German peer-reviewed journal 摘astern European Scientific Journal No. 3/2015. Page 64. June
Scientific journal NBIKS-Nauka.Tehnologii No. 4/2018. Page 104. (Nanotechnological Society of Russia).
French Maritime Forum. http://forummarine.forumactif.com/t9357-le-flux-et-reflux-est-le-resultat-de-la-rotation-de-la-terre
English forum. "Weather / Earth Sciences" https://www.wxforum.net/index.php?topic=35094.0
« Last Edit: March 31, 2021, 06:35:26 AM by Fermer05 »
