1. The reason for the formation of hydrogen sulfide in the Black Sea.
2. The mechanism of flood formation.
3. The ebbs and flows - the result of the rotation of the Earth and the cycles.
4. The mechanism of formation of rogue waves.
5. Stationary model of the solar system.
6. Reactionless drive.
7. The cause of earthquakes is the explosion of water gases.
"The reason for the formation of hydrogen sulfide in the Black Sea."
Institute of Oceanology RAS.
https://vk.com/ioranMixing the wind, they enrich water with oxygen only to a depth of several tens of meters of the surface of the seas and oceans, while cyclonic gyres deliver oxygen-rich water to a depth of more than 10 km. (Mariana Trench).
How does this happen?
The waters of the lakes, seas and oceans of the northern hemisphere rotate counterclockwise, and the waters of the southern hemisphere rotate clockwise, forming cyclonic gyres.
https://en.m.wikipedia.org/wiki/Ocean_gyreAnd everything that rotates, including the cycles, has the property of a gyroscope - to maintain the vertical position of the axis in space regardless of the rotation of the Earth.
If you look at the Earth from the side of the Sun, the gyres revolving with the Earth turn over, due to which the gyres precess, resulting in vertical movement of oceanic waters.
http://goo.gl/AM5g1sThe presented theory can be easily verified by relating the oxygen content,? With the rotation speed of the cycle.
Based on the map of the depths and currents of the seas and oceans.
The higher the flow rate, the greater the oxygen content and the lower the hydrogen sulfide content.
https://youtu.be/ihM1I5r_MUg https://youtu.be/X6PavdKXIE8List of low oxygen seas.
Black Sea, eastern Mediterranean, Gulf of Mexico, Norway fjords.
As we see, gyres are involved not only in the horizontal circulation of the waters of the seas and oceans, but also in the vertical.
https://en.m.wikipedia.org/wiki/Dead_zone_(ecology)
https://www.scientificamerican.com/article/ocean-dead-zones/The coefficient of oxygen content can be expressed mathematically by the following formula O = V / G
V - rotation speed, km / h.
G - depth of the reservoir, km.
Black Sea 0.2 / 1200 = 0.00016.
Sea of Okhotsk 1/800 = 0.0012.
Vertical movement of ocean waters can be modeled using simple experience.
For this, a half-filled vessel with a rotating liquid (bucket, tumbler, mixer) must be rotated around itself (in orbit).
If the liquid in the bucket rotates to the right, then the bucket around itself (in orbit) must be rotated to the left.
http://bourabai.ru/articles/black_sea.htmVertical and horizontal circulation is a vital fundamental law of nature, without which life in the ocean would be impossible.
During the vertical and horizontal circulation, there are also side non-vital effects of nature associated with gyres, ebbs and flows, seasonal rise in sea level, killer waves.
The speed of sea currents in real time.
http://portal.esimo.ru/portal https://www.ndbc.noaa.govhttp://fermi.jhuapl.edu/sat_ocean.html All physical processes that occur in the ocean occur in the atmosphere, in part, and in the mantle of the earth.
"The laws of nature are universal."
Lao Tzu.
2. The mechanism of the formation of floods.
Faculty of Geography, MSU.
https://m.facebook.com/groups/328946357209747The waters of the lakes, seas and oceans of the northern hemisphere rotate counterclockwise, and the waters of the southern hemisphere rotate clockwise, forming cyclonic gyres.
The main cause of rotation of gyres are local winds, flowing into the seas and oceans of the river and the deflecting force of Coriolis.
https://en.m.wikipedia.org/wiki/Ocean_gyreAnd the higher the speed of the winds, the higher the rotational speed of the gyres, thereby increasing the centrifugal force of the gyres and, as a result, the water level of the seas and oceans increases.
And the lower the rotation speed of the gyres, the lower the water level of the seas and oceans.
https://youtu.be/X6PavdKXIE8The speed of currents along the perimeter of the seas and oceans is not the same everywhere and depends on the depth of the coast.
In the shallow part of the seas and oceans, the flow moves fast, and in the deep water part of the seas and oceans the flow moves slowly.
Seasonal increase in the water level is observed not along the entire coast of the seas and oceans, but only on those coasts where a high angular velocity of currents and, as a result, a high centrifugal force of water. (Centrifugal force F = mv2 / r).
On straight coasts where currents do not have an angular velocity, the water level does not rise.
The waters of the Gulf of Finland rotate counterclockwise, forming a cycle in the form of an ellipse.
And when the seasonal storm westerly winds and the deep Neva River unleash the gyre of more than 7 km / h, the centrifugal gyre of the gyre increases, making the water level on the east coast of the Gulf of Finland more than 3 meters.
A similar pattern of seasonal increase in water levels is observed in all lakes, seas and oceans.
The average depth of the Gulf of Finland is about 50 meters, on the east coast about 5 meters, in the west of the bay about 100 meters. For this reason, on the east coast of the Gulf of Finland, the linear and angular velocity of the currents is much higher.
As far as the depth of the coast decreases, the speed of the currents increases.
Flooding in St. Petersburg.
https://en.m.wikipedia.org/wiki/Floods_in_Saint_PetersburgIn the Gulf of Finland, the seasonal increase in water levels has two peaks; in August-September and in December-January and in time coincide with the season of westerly winds and the high water of the Neva River.
The speed of the current in the Gulf of Finland exceeds 7 km / hour, and the maximum speed of the current on Earth reaches 30 km / hour, the wind speed is more than 100 km / hour.
If the storm wind moves in the direction of the current for several days, then the speed of the current increases several times.
The speed of the current depends on the wind speed, the duration of the wind and the height of the waves.
With an increase in wave heights, the windage of the waves increases and, as a result, the angle of attack of the wind increases.
http://goo.gl/eYVTo6http://esimo.oceanography.ru/esp2/index/index/esp_id/1/section_id/6/menu_id/1734The waters of the North Sea rotate counterclockwise, forming a huge circulation.
And when seasonal storm winds unleash the cycle, up to 20 km / h (on the southern coast), the centrifugal force of the cycle increases, so that on the southern coast of the North Sea the water level rises more than 5 meters.
(The storm surge is more than 2.5 meters, the centrifugal surge is more than 1 meter and the tides are more than 5 meters).
North Sea Flood 1953.
https://en.m.wikipedia.org/wiki/North_Sea_flood_of_1953https://de.m.wikipedia.org/wiki/Datei:North_Sea_Currents.svgThe waters of the Caspian Sea rotate counterclockwise, forming a circulation in the form of an ellipse.
And when the deep-flowing Volga River spins the circulation more than 10 km / h, the centrifugal power of the circulation increases, so that on the northern coast of the Caspian Sea the water level rises more than 1 meter.
Centrifugal surge is an invisible water block at the mouth of the river.
https://ru.m.wikipedia.org/wiki/%D0%97%D0%B0%D1%82%D0%BE%D1%80The average depth of the Caspian Sea is about 200 meters, on the north coast about 5 meters, on the south coast about 500m.
For this reason, on the northern coast of the Caspian Sea, the linear and angular velocity of the currents is much higher.
In the Caspian Sea, the peak of the seasonal water level increase is observed in June-August and coincides in time with the flood of the Volga River.
During a drought over the Volga River basin, the water level in the north of the Caspian does not rise.
http://tapemark.narod.ru/more/06.pnghttps://bigenc.ru/geography/text/2050560In the Bay of Bengal, in the season of monsoon winds and floods of the Ganges River, the speed of rotation increases over 10 km / h, due to which the seasonal rise in water levels exceeds 15 meters.
(The storm surge is more than 2.5 meters, the centrifugal surge is more than 1.5 meters and the tides are more than 10 meters).
Bay of Bengal flood 1970.
https://en.m.wikipedia.org/wiki/1970_Bhola_cycloneThe seasonal increase in the level of the Black Sea (up to 40 cm) is most pronounced in the southeastern part of the sea, where in summer the angular velocity of the currents along the coast reaches its maximum value.
http://tapemark.narod.ru/more/07.htmlThe height of the floods depends not so much on the speed and direction of the wind, but on the speed of rotation of the cycle, due to which centrifugal surge and abnormally high tides are formed.
For this reason, on different coasts with the same wind speed, the height of floods varies.
In St. Petersburg, small floods occur during the calm and with the east wind.
Storm surge of high altitude in the Northern Dvina River can be formed under the influence of the north wind.
http://tapemark.narod.ru/more/22.pnghttps://vestnik5.geogr.msu.ru/jour/article/view/11?locale=ru_RUIf during a storm the deep rivers that flow into the bay do not create a whirlpool or the storm wind moves against the whirlwind, then the flood does not form and is easy to predict.
The assumption that the cause of the seasonal increase in the water level can be the pressure of the atmosphere, the flow of the rivers, the temperature difference and the salinity of the water do not hold water, these factors may raise the water level by several cm, but not more.
The presented theory can be easily verified by relating the speed of the current along the coast with the level of the seas and oceans.
(Based on a map of depths and currents, seas and oceans).
https://en.m.wikipedia.org/wiki/Annual_cycle_of_sea_level_heighthttps://research.csiro.au/slrwavescoast/sea-level/sea-level-change/http://www.okeanavt.ru/tainiokeana/1066mifosrednemurovne.html————————————————————————————————
3. The ebb and flow is the result of the rotation of the Earth and the gyres.
Tides are not formed along the entire coast of the seas and oceans, but only on those coasts where there is a high speed of currents.
And the higher the speed of currents along the coast, the higher the amplitude of the tidal wave.
On those coasts where the speed of currents is 0 km / h, the amplitude of the tides is also 0 meters.
https://en.m.wikipedia.org/wiki/Ocean_gyreAnd everything that rotates, including the cycles, has the property of a gyroscope - to maintain the vertical position of the axis in space, regardless of the rotation of the Earth.
If you look at the Earth from the side of the Sun, the gyres, rotating with the Earth, turn over twice a day, thanks to which the gyres precess (sway by 1-2 degrees) and reflect a tidal wave from themselves along the entire perimeter of the gyre.
https://goo.gl/images/M4SJq8 http://goo.gl/AM5g1sThe waters of the White Sea rotate counterclockwise, forming a huge gyroscope whirlwind, which precessing reflects the tidal wave along the entire perimeter of the White Sea. A similar pattern of tides is observed in all lakes, seas and oceans.
White Sea.
http://rivermaps.ru/doc/beloe/beloe-3.htmhttp://tapemark.narod.ru/more/22.pngThe waters of the Mediterranean Sea rotate counterclockwise, forming tides 10–15 cm high. In the Gulf of Gabes, off the coast of Tunisia, the height of the tides reaches three meters, and sometimes more, and this is considered one of the mysteries of nature. But at the same time, the whirlpool rotates in the Gulf of Gabes, precessing reflecting an additional tidal wave.
https://youtu.be/wlvkrRdYNZ0The tidal wave in the Amazon River creates a huge planetary circulation with a diameter of several thousand km., Rotating between South America and North Africa, covering the mouth of the Amazon River.
The pattern of movement of the tidal wave along the perimeter of the North Atlantic planetary circulation (according to satellite data).
http://goo.gl/R1hx0HThe length of the tidal wave depends on the diameter of the rotation.
The height of the tidal wave depends on the rotation speed of the rotation, the orbital velocity of the Earth and the time of the rotation of the rotation (12 hours).
A = V1 • V2 / t
Where, A is the amplitude of the tidal wave.
V1 is the rotation speed of the rotation.
V2 is the orbital velocity of the Earth.
t is the time of the rollover of the cycle (12 hours).
Table of tidal amplitude versus current velocity, on all coasts.
1 km / h - 1 meter.
5 km / h - 5 meter.
10 km / h - 10 meter.
15 km / h - 15 meter.
The amplitude of the tides also depends on the size of the cycle, the amount of water under the cycle, the distance from the coast to the cycle and on the direction of the current (north, south, west, east).
The currents that move along the equator reflect a tidal wave north and south twice a day.
And the currents that move along the meridian reflect a tidal wave west and east 1-2 times a day.
A simple experiment can be made if you rotate the globe around the axis and in orbit, entwined along the equator and meridian with a plastic hose in which the fluid moves.
By the height of the tides, you can determine the speed of the current along the coast, relying on the map of sea currents.
Geofak Moscow State University.
https://m.facebook.com/groups/328946357209747A huge number of tidal waves move in the seas and oceans.
When tidal waves collide with the coastline of the continents, tides are formed.
When two tidal waves collide in the open ocean, a killer wave forms.
https://en.m.wikipedia.org/wiki/Rogue_waveThe magnitude of the killer waves can be calculated using the following formula: H = T1 • T2.
Where T is the kinetic energy of the tidal wave.
Experiment to the topic: The mystery of the Bermuda Triangle - killer waves
https://m.youtube.com/watch?v=1TIY6ZoV-Jk&feature=youtu.beAs we see, killer waves are formed only in those seas where tidal waves are formed and the higher the amplitude of the tides, the higher the killer waves.
In seas where tides do not form, killer waves do not occur.
List of seas where tides and killer waves are formed, more than 50 cm high:
Irish Sea, North Sea, Barents Sea, Baffin Sea, White Sea, West Mediterranean, Bering Sea, Sea of Okhotsk, Arabian Sea, Sargas Sea, Hudson Bay, Maine Bay, Alaska Bay, etc.
List of seas where tides and killer waves are formed, less than 50 cm high:
Baltic Sea, Greenland Sea, Black Sea, Sea of Azov, Chukchi Sea, Kara Sea, Laptev Sea, Red Sea, Sea of Marmara, Caribbean Sea, Sea of Japan, Gulf of Mexico, etc.
In the season of abnormally high tides, abnormally high killer waves form.
The highest tides and killer waves are formed in the North Atlantic, in the Pacific Ocean in the Sea of Okhotsk, etc.
You can conduct a simple experiment if two stones are simultaneously thrown into a bath of water. (the distance between the stones is 10 - 15 cm).
When a tidal wave collides, the emerging killer wave foams and a larger wave pulls through a smaller wave somewhat.
You can create a killer wave with a height of 0.3 meters and a duration of 0.5 seconds, if two divers at the same time jump "bomb" into the pond from a height of 2 meters. (distance between jumping 3 meters).
If, in a cup with water, hit simultaneously with two tablespoons and a "killer wave" is formed there.
The mechanism of formation of the tidal hump in the river, and killer waves in the oceans is similar and the height of the tidal hump in the river depends on the kinetic energy of the current in the river, and the kinetic energy of the tidal wave.
https://images.app.goo.gl/fNxSM5ZBGN5evNQi9Tidal waves move in the open ocean in different directions, at speeds up to 100 km / h, they are also called solitons or Rossby waves.
Barely visible tidal waves colliding with storm waves create a killer wave and are the main cause of the wreck of ships.
https://goo.gl/images/icF4zfThe map shows the areas of the most frequent occurrence of killer waves.
In the North Atlantic, killer waves form mainly around the perimeter of the North Atlantic planetary cycle as a result of the collision of tidal waves with storm waves (three sisters).
Suloy is a throw of water on the surface of the sea.
https://ru.m.wikipedia.org/wiki/%D0%A1%D1%83%D0%BB%D0%BE%D0%B9 The hypothesis that the superposition of wind waves can be the cause of the formation of rogue waves does not stand up to criticism, since rogue waves are also formed during a calm period. (Wind waves do not form a tidal wave).
The statement that methane floating from the bottom of the ocean sharply reduces the density of water and the vessel loses buoyancy is also not true, since a decrease in the density of water cannot cause mechanical damage to ships and oil platforms.
The crews of the ships always record the impact of a huge wave, but no one has yet been able to record the methane emission.
In the North Sea, off the coast of Norway, on the Dropner oil platform on January 1, 1995, during a 12-meter storm wave, a killer wave of 25.6 meters was formed.
https://en.m.wikipedia.org/wiki/Draupner_wave I believe the reason for this natural phenomenon is a tidal current that moves along the coast of Norway from west to east, reflecting a tidal wave from itself, both towards the coast and towards the open sea.
Also, north of the Dropner oil platform through the Pentland Firth Strait, a current moves at a speed of 16 knots from west to east, reflecting a tidal wave north and south.
https://www.equinor.com/en/what-we-do/partner-operated-fields-in-norway/draupner.htmlhttps://en.m.wikipedia.org/wiki/North_Sea In the North Sea, only storm and tidal waves move.
And only, the interaction of tidal and storm waves can be the cause of the formation of killer waves.
Continuation: Forum of Akademgorodok Novosibirsk. The science.
https://forum.academ.club/index.php?showtopic=1235578 Forums of Nizhny Novgorod State University named after. N.I. Lobachevsky.
http://forum.unn.ru/viewtopic.php?f=39&t=10331
