Author Topic: wxwuhistory.php  (Read 1127 times)
Offline 92merc
  • BismarckWeather.net
wxwuhistory.php
« on: August 27, 2018, 10:35:05 AM »
I noticed I'm getting these errors at the top of my WUnderground history page.  I'm not seeing them on one other user's website.  It's been about a week since I had tested the page.  I was out of town, so I didn't make any changes to my site that I would have messed it up.  Or at least I think so.  Any ideas?
http://www.bismarckweather.net/wxwuhistory.php
Notice: Use of undefined constant NAME - assumed 'NAME' in /home/bismarckweather/public_html/wxwuhistory.php on line 72
Offline wvdkuil
  • Wim van der kuil
Re: wxwuhistory.php
« Reply #1 on: August 27, 2018, 10:46:37 AM »
The messages are not errors but it are notices to the programmer to change the script. With a notice the script is functioning as it should. Only errors should be displayed as they can affect the correct working of a script.
For a production website the reporting level should be set lower to only display real errors.
Ask your provider why these messages are showing now and not in the past. Probably they moved you to a newer PHP version or they changed the PHP-ini.
Wim
« Last Edit: August 27, 2018, 11:20:41 AM by wvdkuil »
Offline 92merc
Re: wxwuhistory.php
« Reply #2 on: August 27, 2018, 11:39:09 AM »
I had my site at V7.0.  I flipped to 7.2.  No change.  I looked at the settings, reporting is off.  Here is that screen.
Offline 92merc
Re: wxwuhistory.php
« Reply #3 on: August 27, 2018, 03:19:08 PM »
Welp, instead of contacting GoDaddy for "support", I just threw this into the top of my PHP file XWUhistory.php
error_reporting(0); // Turn off all error reporting
Maybe not the right way.  But it works!
