Author Topic: Another VP2 ultrasonic anemometer option  (Read 5563 times)
Offline spweather
    • Sand Point Weather
Re: Another VP2 ultrasonic anemometer option
« Reply #25 on: September 19, 2018, 07:39:43 PM »
Thanks dendrite.
Also, where are you planning on getting your 40 ft mast? That's what I need, the 30 ft previously mentioned is not high enough for me.
Dennis
Regards,
Dennis
Davis Wireless Vantage Pro2 Plus w/24hr FARS, Boltek/NexStorm/StormVue NGX/MicroLDN TOA, Porcupine Labs LR4/Fluke 414D Laser Rangefinder for measuring snow depth, WL, WD
Offline dendrite
« Reply #26 on: September 19, 2018, 08:15:02 PM »
Thanks dendrite.
Dennis
I'm going to try one of those Channel Master 40ft telescoping ones that require guying. I have a 20 footer guyed to my garage roof now. People around me think I'm crazy, but if we can go higher then we go higher...because that's what we do. ;)
Offline spweather
« Reply #27 on: September 21, 2018, 11:10:05 AM »
Thanks again dendrite.
Dennis
Regards,
Dennis
Offline brett c
« Reply #28 on: October 02, 2018, 04:43:21 AM »
Just saw this thread, is there a full spec sheet of the heated ultrasonic anemometer? I see there's a tech "sheet" on the link given, but nothing much more than that. derrrr.... Just saw the two attached files on the first post!
Does the Davis ISS and Console capture and report in decimal-place speeds? As this unit reports 0.1m/s which is on the bounds of 0.22mph. The anemometer that comes with the David Pro2+ seems to only report in full mph values, nothing in decimal places.
« Last Edit: October 02, 2018, 04:46:25 AM by brett c »
Offline dendrite
« Reply #29 on: October 04, 2018, 02:10:59 PM »
Give me some time to test it out for confirmation (AC-DC adapter comes in on Sunday), but I believe you're limited to 1mph resolution using any anemometer on the Davis. I'm not sure if you could get more resolution using a Meteohub since it contacts directly with the ISS, but my hunch is it won't work. This is made to match the pulse output of the Davis cup anemometer
Offline brett c
« Reply #30 on: October 05, 2018, 08:25:23 AM »
Not a problem, i anxiously await your findings. :)
Online johnd
« Reply #31 on: October 05, 2018, 08:31:46 AM »
Pretty sure that you're limited to integer mph values. Someone who knows the format of the ISS data better than me would be able to confirm but AFAIK wind speed data is transmitted from the ISS (or eg 6332) as a single byte and therefore there's an overriding limitation of integer speed values, ie 0-255mph!
Littleport, Ely, Cambs UK
Offline rdsman
« Reply #32 on: October 05, 2018, 08:50:34 AM »
You are correct...
Ray
Offline brett c
« Reply #33 on: October 05, 2018, 12:33:11 PM »
So with that said, even with the higher resolution value of the anemometer wind speed/direction, the ISS to console is the limiting factor in this? I assume that no matter what I do, the decimal stops at the ISS? If so, that's quite the bummer!
Offline dendrite
« Reply #34 on: October 14, 2018, 07:27:54 PM »
Hey everyone. Sorry it has taken so long for me to test this out. We have some progress though...
Today I took down the telescopic mast and Davis anemometer. I've decided to forego the 40ft mast for now as the new/additional guy wires and roof mounts will be time consuming. I'm going to use the same 20ft telescopic mast I have now and use a mast to mast mounting kit to attach the two together.
https://www.amazon.com/gp/product/B003EAY89M
I'll mount the ultrasonic onto another small mast to get an additional 2-4ft of height. In the meantime I've mounted the anemometer onto a 4ft U-post, powered it up, and hooked it up to the Davis to see what I'd get.
Initially everything was great. I had a couple of hours of data with very good response. Since there's no moving parts there's no starting threshold so it was rare to see the console show 0mph. The 1-min sustained speeds are running about 50% of the 1-min gusts which is impressive considering it's only 4ft off the ground with trees and buildings in the vicinity.
My only problem is that I had 2 periods during the afternoon where I was recording winds of 50-100+ mph. There was a poor connection along the data line somewhere. After the first time, I unhooked everything (data and power connections) and then reconnected everything and the data came back fine. I left it alone the rest of the evening to burn wood in the fire pit and noticed a bit ago that more faulty high wind speed readings occurred for about 15-20mins. This time they came and went on their own. I opened up the anemometer transmitter and the plug was still firmly connected into the wind socket. When connected, there is still some wiggle room in there for the plug to slightly pull in and out. It's been reading well for a little over an hour now. So I'll keep my eye on it. I'll probably get it installed this weekend when I have a little extra help over here for lifting the mast back into the tripod on the roof.
Here's the link to my readings on MW...
https://mesowest.utah.edu/cgi-bin/droman/meso_base_dyn.cgi?stn=C7324&time=GMT
Offline dendrite
« Reply #35 on: October 14, 2018, 08:00:38 PM »
Just noticed I'm getting bad readings again with spikes in the 20-30mph range. Then it goes back to the correct 0-3mph.
Offline dendrite
« Reply #36 on: October 14, 2018, 08:03:45 PM »
Here's some recent data. All times are EST. Scroll to the bottom for the recent obs and the bad data.
10/14/18  6:14p   44.6   44.6   44.5    82   39.4   2.0   SSW   0.03   5.0   SSW   44.6   44.4   44.4   41.6  30.164  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    44.0      0     23    1    100.0    1
10/14/18  6:15p   44.5   44.6   44.5    82   39.3   2.0   SSW   0.03   3.0   SSW   44.5   44.3   44.3   41.5  30.166  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    44.0      0     24    1    100.0    1
10/14/18  6:16p   44.5   44.6   44.5    80   38.7   2.0   SSW   0.03   3.0     S   44.5   44.3   44.3   41.5  30.166  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     22    1     95.7    1
10/14/18  6:17p   44.6   44.6   44.5    79   38.5   1.0   SSW   0.02   3.0   SSW   44.6   44.4   44.4   41.6  30.166  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     23    1    100.0    1
10/14/18  6:18p   44.5   44.5   44.5    82   39.3   2.0     S   0.03   3.0     S   44.5   44.3   44.3   41.5  30.166  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     24    1    100.0    1
10/14/18  6:19p   44.6   44.6   44.5    81   39.1   1.0     S   0.02   2.0     S   44.6   44.4   44.4   41.6  30.166  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     23    1    100.0    1
10/14/18  6:20p   44.5   44.6   44.5    81   39.0   2.0   SSE   0.03   3.0     S   44.5   44.3   44.3   41.5  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     24    1    100.0    1
10/14/18  6:21p   44.5   44.5   44.5    83   39.7   2.0     S   0.03   5.0     S   44.5   44.4   44.4   41.6  30.168  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     23    1    100.0    1
10/14/18  6:22p   44.5   44.5   44.4    82   39.3   2.0     S   0.03   4.0     S   44.5   44.3   44.3   41.5  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     24    1    100.0    1
10/14/18  6:23p   44.5   44.5   44.4    83   39.7   2.0     S   0.03   4.0     S   44.5   44.4   44.4   41.6  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     23    1    100.0    1
10/14/18  6:24p   44.4   44.5   44.4    84   39.9   2.0     S   0.03   4.0     S   44.4   44.3   44.3   41.5  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    44.0      0     23    1    100.0    1
10/14/18  6:25p   44.3   44.4   44.3    83   39.5   2.0   SSE   0.03   5.0   SSE   44.3   44.2   44.2   41.4  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     24    1    100.0    1
10/14/18  6:26p   44.1   44.3   44.1    84   39.6   2.0   SSE   0.03   3.0   SSE   44.1   44.0   44.0   41.2  30.168  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     22    1     95.7    1
10/14/18  6:27p   44.0   44.0   43.9    80   38.2   2.0   SSE   0.03   4.0   SSE   44.0   43.8   43.8   41.0  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     24    1    100.0    1
10/14/18  6:28p   44.2   44.2   44.0    79   38.1   2.0   SSE   0.03   5.0   SSE   44.2   44.0   44.0   41.2  30.168  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     23    1    100.0    1
10/14/18  6:29p   44.2   44.2   44.2    77   37.4   2.0   SSE   0.03   4.0   SSE   44.2   43.9   43.9   41.0  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     23    1    100.0    1
10/14/18  6:30p   44.2   44.2   44.2    77   37.4   2.0   SSE   0.03   3.0   SSE   44.2   43.9   43.9   41.0  30.167  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.014   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     24    1    100.0    1
10/14/18  6:31p   44.0   44.2   44.0    79   37.9   1.0   SSE   0.02   2.0   SSE   44.0   43.8   43.8   40.9  30.168  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     23    1    100.0    1
10/14/18  6:32p   43.9   44.0   43.8    81   38.4   0.0   ---   0.00   0.0   ---   43.9   43.7   43.7   40.9  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     24    1    100.0    1
10/14/18  6:33p   43.8   43.9   43.8    82   38.7   0.0   ---   0.00   0.0   ---   43.8   43.6   43.6   40.8  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     23    1    100.0    1
10/14/18  6:34p   43.9   43.9   43.8    83   39.1   1.0     S   0.02   3.0   SSW   43.9   43.8   43.8   41.0  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     24    1    100.0    1
10/14/18  6:35p   43.8   44.0   43.8    84   39.3   1.0     N   0.02   3.0     N   43.8   43.7   43.7   40.9  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    43.0      0     23    1    100.0    1
10/14/18  6:36p   43.6   43.8   43.6    83   38.8   1.0   WSW   0.02   4.0     N   43.6   43.4   43.4   40.6  30.174  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:37p   43.5   43.6   43.5    83   38.7   0.0   ESE   0.00   3.0   ESE   43.5   43.3   43.3   40.5  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:38p   43.4   43.5   43.4    83   38.6   0.0   ---   0.00   0.0   ---   43.4   43.2   43.2   40.4  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:39p   43.3   43.4   43.3    84   38.8   0.0   ---   0.00   0.0   ---   43.3   43.2   43.2   40.4  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:40p   43.1   43.3   43.1    84   38.6   0.0    SW   0.00   2.0   WSW   43.1   43.0   43.0   40.2  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:41p   42.9   43.2   42.9    85   38.7   0.0    SE   0.00   1.0    SE   42.9   42.8   42.8   40.0  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:42p   42.9   43.0   42.9    85   38.7   1.0    SE   0.02   3.0    SE   42.9   42.8   42.8   40.0  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:43p   42.9   42.9   42.9    86   39.0   0.0   ---   0.00   0.0   ---   42.9   42.8   42.8   40.0  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     22    1     95.7    1
10/14/18  6:44p   43.0   43.0   42.9    86   39.1   0.0   ---   0.00   0.0   ---   43.0   42.9   42.9   40.1  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:45p   43.1   43.1   43.0    85   38.9   0.0   SSE   0.00   3.0   SSE   43.1   43.0   43.0   40.2  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:46p   43.1   43.3   43.1    87   39.5   1.0   SSE   0.02   4.0     N   43.1   43.0   43.0   40.2  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:47p   43.3   43.3   43.3    85   39.1   1.0     S   0.02   6.0     S   43.3   43.2   43.2   40.4  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:48p   43.2   43.2   43.0    86   39.3   1.0     N   0.02   3.0     N   43.2   43.1   43.1   40.3  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:49p   43.3   43.3   43.2    85   39.1   1.0   SSE   0.02   2.0   SSE   43.3   43.2   43.2   40.4  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:50p   43.3   43.4   43.3    85   39.1   1.0   SSE   0.02   3.0     S   43.3   43.2   43.2   40.4  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:51p   43.3   43.4   43.3    85   39.1   2.0   SSE   0.03   4.0     S   43.3   43.2   43.2   40.4  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:52p   43.2   43.3   43.2    85   39.0   2.0     S   0.03   3.0     S   43.2   43.1   43.1   40.3  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:53p   43.1   43.2   43.1    84   38.6   2.0     S   0.03   4.0     S   43.1   43.0   43.0   40.2  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:54p   43.1   43.1   43.1    83   38.3   2.0     S   0.03   3.0     S   43.1   42.9   42.9   40.1  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:55p   43.0   43.0   42.9    84   38.5   2.0     S   0.03   3.0     N   43.0   42.9   42.9   40.1  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:56p   42.7   42.9   42.7    84   38.2   1.0     S   0.02   3.0   SSE   42.7   42.5   42.5   39.7  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.015   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:57p   42.4   42.6   42.4    85   38.2   1.0   SSE   0.02   3.0     N   42.4   42.2   42.2   39.4  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  6:58p   42.4   42.4   42.3    85   38.2   1.0   SSE   0.02   4.0    SW   42.4   42.2   42.2   39.4  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    42.0      0     24    1    100.0    1
10/14/18  6:59p   42.3   42.4   42.3    85   38.1   6.0     N   0.10  22.0   NNW   38.5   42.1   38.3   35.5  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    42.0      0     23    1    100.0    1
10/14/18  7:00p   42.1   42.3   42.1    85   37.9  14.0     N   0.23  29.0     N   34.5   41.9   34.3   32.1  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.001    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:01p   41.8   42.1   41.8    86   37.9   0.0    SE   0.00   1.0    SE   41.8   41.6   41.6   38.7  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:02p   41.7   41.8   41.7    87   38.1   0.0   ---   0.00   0.0   ---   41.7   41.6   41.6   38.8  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:03p   41.6   41.8   41.6    87   38.0   0.0   ---   0.00   0.0   ---   41.6   41.5   41.5   38.7  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    41.0      0     24    1    100.0    1
10/14/18  7:04p   41.2   41.6   41.2    87   37.6   0.0    SE   0.00   1.0    SE   41.2   41.0   41.0   38.1  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:05p   41.3   41.3   41.2    88   38.0   0.0   SSE   0.00   1.0   SSE   41.3   41.2   41.2   38.4  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
« Last Edit: October 14, 2018, 08:06:18 PM by dendrite »
Offline dendrite
« Reply #37 on: October 14, 2018, 08:12:20 PM »
And there it goes again after a brief period back to normal. Maybe Stefan or someone else has some ideas.
« Last Edit: October 14, 2018, 08:41:33 PM by dendrite »
Offline dendrite
« Reply #38 on: October 14, 2018, 09:12:31 PM »
This is weird. It seems to be happening every ~11 minutes or so.
10/14/18  7:06p   41.3   41.4   41.3    88   38.0   0.0   ---   0.00   0.0   ---   41.3   41.2   41.2   38.4  30.166  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:07p   41.4   41.4   41.3    88   38.1   0.0     N   0.00   1.0     N   41.4   41.3   41.3   38.5  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:08p   41.3   41.4   41.3    88   38.0   1.0   SSE   0.02   3.0     S   41.3   41.2   41.2   38.4  30.168  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:09p   41.2   41.3   41.2    88   37.9   0.0     N   0.00   3.0   NNE   41.2   41.1   41.1   38.2  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:10p   41.5   41.5   41.2    89   38.5  12.0     N   0.20  32.0     N   34.6   41.4   34.5   32.2  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:11p   41.5   41.5   41.5    88   38.2  14.0     N   0.23  29.0     N   33.8   41.4   33.7   31.5  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.1    65   58.7   71.0  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:12p   41.5   41.6   41.5    87   37.9   4.0   SSE   0.07  14.0   ESE   39.1   41.4   39.0   36.1  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:13p   41.5   41.5   41.5    88   38.2   2.0   SSE   0.03   3.0   SSE   41.5   41.4   41.4   38.6  30.168  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:14p   41.7   41.7   41.5    86   37.8   2.0   SSE   0.03   3.0   SSE   41.7   41.5   41.5   38.6  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:15p   41.4   41.7   41.4    86   37.5   2.0   SSE   0.03   3.0   SSE   41.3   41.2   41.1   38.2  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    41.0      0     24    1    100.0    1
10/14/18  7:16p   41.4   41.4   41.3    88   38.1   2.0   SSE   0.03   3.0     S   41.3   41.3   41.2   38.4  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    40.0      0     22    1     95.7    1
10/14/18  7:17p   41.3   41.5   41.3    86   37.4   2.0    SE   0.03   3.0    SE   41.2   41.1   41.0   38.1  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:18p   41.3   41.3   41.3    86   37.4   2.0    SE   0.03   4.0   SSE   41.2   41.1   41.0   38.1  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:19p   41.5   41.5   41.3    87   37.9   2.0    SE   0.03   4.0    SE   41.5   41.4   41.4   38.5  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:20p   41.5   41.5   41.5    86   37.6   2.0     S   0.03   3.0     S   41.5   41.3   41.3   38.4  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    41.0      0     24    1    100.0    1
10/14/18  7:21p   41.6   41.6   41.5    85   37.4   1.0   ESE   0.02   3.0     E   41.6   41.4   41.4   38.5  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:22p   41.5   41.6   41.5    87   37.9   3.0    SE   0.05  19.0     N   40.1   41.4   40.0   37.1  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    41.0      0     23    1    100.0    1
10/14/18  7:23p   41.5   41.5   41.5    87   37.9  21.0     N   0.35  33.0     N   32.0   41.4   31.9   30.1  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    41.0      0     24    1    100.0    1
10/14/18  7:24p   41.4   41.5   41.4    87   37.8  11.0     N   0.18  19.0     N   34.8   41.3   34.7   32.2  30.169  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:25p   41.3   41.4   41.2    87   37.7   2.0    SE   0.03   6.0     S   41.2   41.2   41.1   38.2  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:26p   41.3   41.3   41.2    87   37.7   0.0    SE   0.00   2.0    SE   41.3   41.2   41.2   38.3  30.170  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.016   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:27p   41.1   41.3   41.1    87   37.5   0.0   ---   0.00   0.0   ---   41.1   40.9   40.9   38.0  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:28p   41.0   41.2   41.0    88   37.7   0.0    SE   0.00   1.0     E   41.0   40.9   40.9   38.0  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:29p   41.0   41.0   40.9    88   37.7   0.0     N   0.00   2.0     N   41.0   40.9   40.9   38.0  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:30p   41.1   41.1   41.0    87   37.5   0.0     S   0.00   2.0     S   41.1   40.9   40.9   38.0  30.173  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:31p   41.1   41.1   41.0    87   37.5   0.0     S   0.00   3.0     S   41.1   40.9   40.9   38.0  30.173  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:32p   41.1   41.1   41.0    88   37.8   0.0    SE   0.00   2.0   SSE   41.1   41.0   41.0   38.1  30.174  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:33p   41.1   41.1   41.0    88   37.8   1.0     N   0.02  10.0    NE   41.1   41.0   41.0   38.1  30.173  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:34p   41.1   41.2   41.1    87   37.5  14.0     N   0.23  25.0     N   33.4   40.9   33.2   31.0  30.173  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:35p   41.0   41.0   41.0    88   37.7  14.0     N   0.23  23.0     N   33.3   40.9   33.2   31.0  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:36p   41.0   41.0   41.0    88   37.7  10.0     S   0.17  32.0     S   34.8   40.9   34.7   32.1  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     21    1     91.3    1
10/14/18  7:37p   40.9   41.0   40.9    88   37.6   1.0     S   0.02   2.0     S   40.9   40.8   40.8   37.9  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    65   59.0   71.5  11.85  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:38p   41.0   41.0   40.9    89   38.0   2.0   SSE   0.03   3.0   SSE   40.9   40.9   40.8   38.0  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:39p   41.1   41.1   41.0    89   38.1   2.0   SSE   0.03   3.0   SSE   41.0   41.0   40.9   38.1  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    65   58.8   71.2  11.85  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:40p   41.1   41.1   41.1    89   38.1   2.0     S   0.03   3.0     S   41.0   41.0   40.9   38.1  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:41p   41.0   41.1   41.0    89   38.0   1.0     S   0.02   3.0     S   41.0   40.9   40.9   38.1  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:42p   41.0   41.0   40.9    89   38.0   1.0     S   0.02   3.0     S   41.0   40.9   40.9   38.1  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:43p   41.0   41.0   40.9    89   38.0   1.0     S   0.02   2.0     S   41.0   40.9   40.9   38.1  30.171  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:44p   41.1   41.1   41.0    89   38.1   1.0   SSE   0.02   3.0   SSE   41.1   41.0   41.0   38.2  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:45p   41.0   41.0   41.0    89   38.0   2.0     N   0.03  15.0   NNW   40.9   40.9   40.8   38.0  30.173  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    66   59.4   71.6  12.12  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:46p   41.1   41.1   41.0    89   38.1  17.0     N   0.28  30.0    SW   32.5   41.0   32.4   30.4  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    66   59.4   71.6  12.12  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:47p   41.0   41.0   41.0    89   38.0  13.0   NNE   0.22  27.0     N   33.6   40.9   33.5   31.3  30.173  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    66   59.4   71.6  12.12  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:48p   40.9   41.0   40.9    89   37.9   2.0   SSE   0.03   3.0   SSE   40.8   40.8   40.7   37.8  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.4    66   59.4   71.6  12.12  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:49p   40.9   40.9   40.9    88   37.6   3.0     S   0.05   4.0     S   39.4   40.8   39.3   36.4  30.172  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:50p   40.8   40.9   40.8    88   37.5   2.0     S   0.03   4.0     S   40.7   40.7   40.6   37.7  30.173  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:51p   40.8   40.8   40.7    89   37.8   2.0     S   0.03   4.0     S   40.7   40.7   40.6   37.7  30.175  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:52p   40.7   40.8   40.7    89   37.7   3.0     S   0.05   4.0     S   39.2   40.6   39.1   36.2  30.176  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:53p   40.7   40.7   40.6    89   37.7   3.0     S   0.05   4.0     S   39.2   40.6   39.1   36.2  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:54p   40.7   40.7   40.7    89   37.7   3.0     S   0.05   4.0     S   39.2   40.6   39.1   36.2  30.178  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:55p   40.5   40.7   40.5    89   37.5   2.0     S   0.03   4.0   SSE   40.3   40.4   40.2   37.3  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:56p   40.3   40.4   40.3    89   37.3   5.0     S   0.08  30.0     N   36.8   40.2   36.7   33.8  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  7:57p   40.3   40.3   40.2    90   37.6  17.0     N   0.28  27.0   NNW   31.6   40.2   31.5   29.5  30.176  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:58p   40.5   40.5   40.4    89   37.5  12.0     N   0.20  19.0    SW   33.4   40.4   33.3   30.9  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.2    66   59.3   71.3  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  7:59p   40.6   40.6   40.5    89   37.6   2.0     S   0.03   5.0     S   40.5   40.5   40.4   37.5  30.176  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    66   59.2   71.1  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  8:00p   40.5   40.6   40.5    89   37.5   2.0     S   0.03   3.0     S   40.3   40.4   40.2   37.3  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    66   59.2   71.1  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  8:01p   40.5   40.6   40.5    88   37.2   2.0     S   0.03   3.0     S   40.3   40.4   40.2   37.3  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    66   59.2   71.1  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  8:02p   40.4   40.6   40.4    88   37.1   2.0     S   0.03   3.0     S   40.2   40.3   40.1   37.2  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    66   59.2   71.1  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  8:03p   40.3   40.4   40.3    89   37.3   2.0     S   0.03   3.0     S   40.1   40.2   40.0   37.1  30.177  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    66   59.2   71.1  12.13  .0741    0.000    ---    55.0    40.0      0     24    1    100.0    1
10/14/18  8:04p   40.4   40.4   40.4    89   37.4   2.0     S   0.03   3.0     S   40.2   40.3   40.1   37.2  30.176  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    66   59.2   71.1  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  8:05p   40.3   40.4   40.3    89   37.3   0.0     S   0.00   1.0     S   40.3   40.2   40.2   37.3  30.176  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   71.1    66   59.2   71.1  12.13  .0741    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  8:06p   40.2   40.2   40.1    89   37.2   0.0   ---   0.00   0.0   ---   40.2   40.1   40.1   37.2  30.178  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   70.9    66   59.0   70.9  12.13  .0742    0.000    ---    55.0    40.0      0     23    1    100.0    1
10/14/18  8:07p   40.1   40.2   40.1    89   37.1   8.0     N   0.13  25.0     N   34.7   40.0   34.6   31.9  30.180  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   70.9    66   59.0   70.9  12.13  .0742    0.000    ---    55.0    39.0      0     22    1     95.7    1
10/14/18  8:08p   40.0   40.1   40.0    90   37.3  20.0     N   0.33  33.0    NW   30.5   39.9   30.4   28.5  30.179  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   70.9    66   59.0   70.9  12.13  .0742    0.000    ---    55.0    39.0      0     23    1    100.0    1
10/14/18  8:09p   40.2   40.2   40.1    90   37.5  17.0     N   0.28  28.0   NNE   31.5   40.1   31.4   29.4  30.179  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   70.9    66   59.0   70.9  12.13  .0742    0.000    ---    55.0    39.0      0     23    1    100.0    1
10/14/18  8:10p   40.1   40.2   40.1    90   37.4   6.0     S   0.10  18.0     N   35.9   40.0   35.8   32.9  30.180  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.017   0.000   70.9    66   59.0   70.9  12.13  .0742    0.000    ---    55.0    39.0      0     23    1    100.0    1
Offline dendrite
« Reply #39 on: October 14, 2018, 11:04:52 PM »
Getting worse now. I'm going to have to shut it down for the night.
10/14/18  9:40p   38.2   38.2   38.1    94   36.6  68.0     N   1.13  90.0   SSE   21.3   38.2   21.3   20.2  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     20    1     87.0    1
10/14/18  9:41p   38.1   38.2   38.0    94   36.5 122.0   SSE   2.03 136.0   SSE   17.4   38.1   17.4   16.3  30.195  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     19    1     82.6    1
10/14/18  9:42p   38.1   38.1   38.0    95   36.8 135.0   SSE   2.25 135.0   SSE   16.8   38.1   16.8   15.7  30.195  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     22    1     95.7    1
10/14/18  9:43p   38.1   38.2   38.1    95   36.8 135.0   SSE   2.25 135.0   SSE   16.8   38.1   16.8   15.7  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     23    1    100.0    1
10/14/18  9:44p   38.1   38.1   38.1    95   36.8 134.0   SSE   2.23 135.0   SSE   16.8   38.1   16.8   15.7  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     22    1     95.7    1
10/14/18  9:45p   37.8   38.1   37.8    94   36.2 134.0   SSE   2.23 135.0   SSE   16.3   37.8   16.3   15.2  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     23    1    100.0    1
10/14/18  9:46p   37.6   37.7   37.6    95   36.3 105.0   SSE   1.75 135.0   SSE   17.7   37.6   17.7   16.6  30.196  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     19    1     82.6    1
10/14/18  9:47p   37.7   37.7   37.6    95   36.4  95.0   SSE   1.58 136.0   SSE   18.5   37.7   18.5   17.4  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     21    1     91.3    1
10/14/18  9:48p   37.7   37.7   37.6    95   36.4  66.0     N   1.10  78.0    NW   20.8   37.7   20.8   19.7  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     20    1     87.0    1
10/14/18  9:49p   37.9   37.9   37.7    95   36.6  76.0     N   1.27  83.0     W   20.2   37.9   20.2   19.1  30.196  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     22    1     95.7    1
10/14/18  9:50p   37.9   37.9   37.8    95   36.6  21.0     N   0.35  81.0   ESE   27.5   37.9   27.5   25.7  30.195  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     21    1     91.3    1
10/14/18  9:51p   37.9   37.9   37.9    95   36.6   0.0   ---   0.00   0.0   ---   37.9   37.9   37.9   35.0  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     20    1     87.0    1
10/14/18  9:52p   37.9   37.9   37.9    94   36.3  72.0   NNE   1.20  85.0   NNE   20.5   37.9   20.5   19.4  30.194  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     24    1    100.0    1
10/14/18  9:53p   37.7   37.9   37.7    94   36.1  78.0     N   1.30  84.0     N   19.7   37.7   19.7   18.6  30.195  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     22    1     95.7    1
10/14/18  9:54p   37.8   37.8   37.7    94   36.2  79.0   NNE   1.32 100.0     E   19.8   37.8   19.8   18.7  30.196  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     24    1    100.0    1
10/14/18  9:55p   37.7   37.8   37.7    95   36.4  77.0   SSE   1.28  98.0     S   19.8   37.7   19.8   18.7  30.196  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     21    1     91.3    1
10/14/18  9:56p   37.7   37.7   37.6    95   36.4  77.0     S   1.28  93.0     S   19.8   37.7   19.8   18.7  30.197  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     23    1    100.0    1
10/14/18  9:57p   37.6   37.7   37.6    95   36.3  30.0   SSE   0.50  89.0   SSE   25.2   37.6   25.2   23.7  30.196  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     23    1    100.0    1
10/14/18  9:58p   37.5   37.6   37.5    95   36.2  81.0   SSE   1.35 135.0   ESE   19.2   37.5   19.2   18.1  30.195  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     23    1    100.0    1
10/14/18  9:59p   37.8   37.8   37.6    95   36.5  46.0    SE   0.77 135.0   ESE   23.1   37.8   23.1   22.0  30.197  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     19    1     82.6    1
10/14/18 10:00p   37.9   37.9   37.8    95   36.6  13.0   SSE   0.22  86.0   SSE   29.8   37.9   29.8   27.5  30.198  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.019   0.000   71.1    66   59.2   71.1  12.13  .0742    0.000    ---    55.0    37.0      0     19    1     82.6    1
Offline dendrite
« Reply #40 on: October 15, 2018, 12:01:26 AM »
It seems to be aligning with some missed packets from the ISS. I have no idea what could be causing the interference.
Offline dendrite
« Reply #41 on: October 15, 2018, 08:03:51 AM »
I powered it up again this morning after giving it a good 6 hours of rest and it looked like the eyewall of Hurricane Michael the entire 20 minutes it ran. I shut it down again and will play with it more this afternoon after work.
10/15/18  4:59a   31.6   31.6   31.5    98   31.1   0.0   ---   0.00   0.0   ---   31.6   31.6   31.6   28.6  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.4    65   58.1   70.2  11.85  .0742    0.000    ---    53.0    31.0      0     24    1    100.0    1
10/15/18  5:00a   31.5   31.6   31.5    98   31.0   4.0     N   0.07  76.0    SE   27.5   31.5   27.5   24.5  30.159  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.4    65   58.1   70.2  11.85  .0742    0.000    ---    53.0    31.0      0     20    1     87.0    1
10/15/18  5:01a   31.6   31.6   31.5    98   31.1  78.0   SSE   1.30  89.0     S   10.7   31.6   10.7    9.5  30.159  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.4    65   58.1   70.2  11.85  .0742    0.000    ---    53.0    31.0      0     16    1     69.6    1
10/15/18  5:02a   31.7   31.7   31.6    98   31.2  74.0     N   1.23  90.0     S   11.2   31.7   11.2   10.0  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.4    65   58.1   70.2  11.85  .0742    0.000    ---    53.0    31.0      0     21    1     91.3    1
10/15/18  5:03a   31.6   31.7   31.6    98   31.1  75.0     N   1.25 117.0     S   11.0   31.6   11.0    9.8  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.4    65   58.1   70.2  11.85  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:04a   31.6   31.6   31.6    98   31.1  75.0     N   1.25  81.0     N   11.0   31.6   11.0    9.8  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.4    65   58.1   70.2  11.85  .0742    0.000    ---    53.0    31.0      0     24    1    100.0    1
10/15/18  5:05a   31.6   31.6   31.6    98   31.1  73.0     N   1.22  86.0   ENE   11.2   31.6   11.2   10.0  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     22    1     95.7    1
10/15/18  5:06a   31.6   31.6   31.6    98   31.1  76.0     N   1.27  89.0   SSW   10.9   31.6   10.9    9.7  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:07a   31.6   31.6   31.6    98   31.1  75.0    NE   1.25  84.0   SSE   11.0   31.6   11.0    9.8  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:08a   31.7   31.7   31.6    98   31.2  71.0     N   1.18  87.0     N   11.5   31.7   11.5   10.3  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:09a   31.7   31.8   31.7    98   31.2  75.0     N   1.25 104.0   ESE   11.1   31.7   11.1    9.9  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     24    1    100.0    1
10/15/18  5:10a   31.6   31.7   31.6    98   31.1  76.0     N   1.27  88.0     N   10.9   31.6   10.9    9.7  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     22    1     95.7    1
10/15/18  5:11a   31.6   31.6   31.6    98   31.1  72.0     N   1.20  90.0     N   11.3   31.6   11.3   10.1  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:12a   31.6   31.6   31.5    98   31.1  74.0     N   1.23  83.0     W   11.1   31.6   11.1    9.9  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    65   57.9   69.9  11.85  .0743    0.000    ---    53.0    31.0      0     22    1     95.7    1
10/15/18  5:13a   31.7   31.7   31.6    98   31.2  73.0     N   1.22  83.0    NE   11.3   31.7   11.3   10.1  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:14a   31.7   31.7   31.7    98   31.2  73.0     N   1.22  79.0    NE   11.3   31.7   11.3   10.1  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     24    1    100.0    1
10/15/18  5:15a   31.6   31.6   31.6    98   31.1  75.0     N   1.25  83.0     N   11.0   31.6   11.0    9.8  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:16a   31.6   31.6   31.5    98   31.1  75.0     N   1.25  91.0     N   11.0   31.6   11.0    9.8  30.161  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     22    1     95.7    1
10/15/18  5:17a   31.6   31.6   31.6    98   31.1  75.0     E   1.25 134.0     N   11.0   31.6   11.0    9.8  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:18a   31.6   31.6   31.6    98   31.1  76.0     N   1.27  91.0     N   10.9   31.6   10.9    9.7  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     24    1    100.0    1
10/15/18  5:19a   31.7   31.7   31.6    98   31.2  78.0     N   1.30 114.0   WNW   10.9   31.7   10.9    9.7  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:20a   31.6   31.7   31.6    98   31.1  77.0     N   1.28  87.0     S   10.8   31.6   10.8    9.6  30.159  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     23    1    100.0    1
10/15/18  5:21a   31.6   31.6   31.5    98   31.1  77.0     N   1.28  92.0     N   10.8   31.6   10.8    9.6  30.160  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     24    1    100.0    1
10/15/18  5:22a   31.7   31.7   31.7    98   31.2  55.0     N   0.92  87.0     N   13.3   31.7   13.3   12.1  30.158  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2    66   58.3   70.0  12.15  .0743    0.000    ---    53.0    31.0      0     21    1     91.3    1
10/15/18  5:23a   31.6   31.7   31.6    98   31.1   0.0   ---   0.00   0.0   ---   31.6   31.6   31.6   28.6  30.158  0.00  0.00     0     0.00      0     0.0  0.00   0.0   0.023   0.000   70.2
Offline dendrite
« Reply #42 on: October 15, 2018, 12:03:30 PM »
Had the Mrs. plug it in to try it during the day and had the same result. My packet reception from the anemometer transmitter dropped from a steady 100% to 80-90% once it was powered up. So there definitely seems to be some sort of interference between the transmitter and anemometer. The overseas Davis stations use a different frequency, correct? Maybe Hongyuv didn't account for the frequency used on the US versions? I dunno...just brainstorming here. You can see the obs with wind data here and the ISS reception percentage is the 2nd to the last value if you scroll all the way to the right.
10/15/18 10:37a   38.9   38.9   38.8    97   38.1   0.0   ---   0.00   0.0   ---   38.9   39.0   39.0   37.9  30.071  0.00  0.16    49     0.07     49     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    39.0     15     23    1    100.0    1
10/15/18 10:38a   39.1   39.1   38.9    97   38.3   0.0   ---   0.00   0.0   ---   39.1   39.2   39.2   38.3  30.069  0.00  0.14    53     0.08     53     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    39.0     15     23    1    100.0    1
10/15/18 10:39a   39.1   39.1   39.1    97   38.3   0.0   ---   0.00   0.0   ---   39.1   39.2   39.2   38.7  30.067  0.01  0.14    70     0.10     70     0.5  0.00   0.5   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    39.0     15     23    1    100.0    1
10/15/18 10:40a   38.9   39.0   38.9    97   38.1   0.0   ---   0.00   0.0   ---   38.9   39.0   39.0   38.7  30.065  0.00  0.14    76     0.11     76     0.5  0.00   0.5   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    39.0     15     23    1    100.0    1
10/15/18 10:41a   38.9   39.0   38.9    97   38.1   0.0   ---   0.00   0.0   ---   38.9   39.0   39.0   38.5  30.063  0.00  0.14    68     0.10     72     0.5  0.00   0.5   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    39.0     15     24    1    100.0    1
10/15/18 10:42a   38.9   39.0   38.9    97   38.1   0.0   ---   0.00   0.0   ---   38.9   39.0   39.0   38.3  30.063  0.00  0.14    60     0.09     60     0.0  0.00   0.0   0.018   0.000   69.6    66   57.7   69.5  12.15  .0741    0.000    200    53.0    40.0     15     23    1    100.0    1
10/15/18 10:43a   38.8   38.9   38.8    97   38.0   0.0   ---   0.00   0.0   ---   38.8   38.9   38.9   38.0  30.062  0.01  0.14    56     0.08     56     0.0  0.00   0.0   0.018   0.000   69.6    66   57.7   69.5  12.15  .0741    0.000    200    53.0    39.0     15     23    1    100.0    1
10/15/18 10:44a   38.9   39.0   38.9    97   38.1   0.0   ---   0.00   0.0   ---   38.9   39.0   39.0   38.1  30.061  0.00  0.14    54     0.08     54     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    39.0     15     23    1    100.0    1
10/15/18 10:45a   39.1   39.1   38.9    97   38.3   0.0   ---   0.00   0.0   ---   39.1   39.2   39.2   38.3  30.061  0.00  0.14    53     0.08     53     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    39.0     15     23    1    100.0    1
10/15/18 10:46a   39.1   39.1   39.0    97   38.3   0.0   ---   0.00   0.0   ---   39.1   39.2   39.2   38.2  30.061  0.00  0.14    51     0.07     51     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     24    1    100.0    1
10/15/18 10:47a   39.3   39.3   39.1    97   38.5   0.0   ---   0.00   0.0   ---   39.3   39.4   39.4   38.3  30.060  0.00  0.13    49     0.07     49     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     23    1    100.0    1
10/15/18 10:48a   39.4   39.4   39.3    97   38.6   0.0   ---   0.00   0.0   ---   39.4   39.5   39.5   38.4  30.059  0.00  0.10    47     0.07     47     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     24    1    100.0    1
10/15/18 10:49a   39.6   39.6   39.3    97   38.8   0.0   ---   0.00   0.0   ---   39.6   39.7   39.7   38.5  30.059  0.00  0.09    46     0.07     46     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     23    1    100.0    1
10/15/18 10:50a   39.6   39.6   39.5    97   38.8   0.0   ---   0.00   0.0   ---   39.6   39.7   39.7   38.5  30.058  0.00  0.08    44     0.06     44     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     23    1    100.0    1
10/15/18 10:51a   39.7   39.7   39.6    98   39.2   0.0   ---   0.00   0.0   ---   39.7   39.8   39.8   38.6  30.057  0.00  0.07    44     0.06     44     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     24    1    100.0    1
10/15/18 10:52a   39.5   39.6   39.5    98   39.0   0.0   ---   0.00   0.0   ---   39.5   39.6   39.6   38.4  30.056  0.01  0.07    44     0.06     44     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     23    1    100.0    1
10/15/18 10:53a   39.5   39.5   39.4    98   39.0   9.0     N   0.15  82.0     S   33.5   39.6   33.6   32.4  30.056  0.00  0.07    42     0.06     42     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0742    0.000    200    53.0    40.0     15     19    1     82.6    1
10/15/18 10:54a   39.5   39.5   39.5    98   39.0  75.0     N   1.25  94.0     S   22.7   39.6   22.8   22.3  30.055  0.00  0.07    46     0.07     46     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0741    0.000    200    53.0    40.0     15     20    1     87.0    1
10/15/18 10:55a   39.6   39.7   39.5    98   39.1  75.0     N   1.25  81.0   SSW   22.8   39.7   22.9   22.6  30.053  0.00  0.07    58     0.08     58     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0741    0.000    200    53.0    40.0     15     21    1     91.3    1
10/15/18 10:56a   39.6   39.7   39.6    98   39.1  76.0   NNE   1.27  84.0    SW   22.7   39.7   22.8   22.4  30.052  0.00  0.07    56     0.08     56     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0741    0.000    200    53.0    40.0     15     24    1    100.0    1
10/15/18 10:57a   39.7   39.7   39.5    98   39.2  77.0   NNE   1.28  95.0    SE   22.8   39.8   22.9   22.5  30.050  0.00  0.07    53     0.08     53     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0741    0.000    200    53.0    40.0     15     20    1     87.0    1
10/15/18 10:58a   39.6   39.7   39.6    98   39.1 108.0   SSE   1.80 135.0   SSE   20.5   39.7   20.6   20.2  30.049  0.00  0.07    47     0.07     47     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0741    0.000    200    53.0    40.0     15     20    1     87.0    1
10/15/18 10:59a   39.7   39.7   39.7    98   39.2   6.0   SSE   0.10 135.0   SSE   35.4   39.8   35.5   34.3  30.048  0.00  0.07    44     0.06     44     0.0  0.00   0.0   0.018   0.000   69.4    66   57.5   69.3  12.15  .0741    0.000    200    53.0    40.0     15     21    1     91.3    1
Offline dendrite
« Reply #43 on: October 15, 2018, 12:16:59 PM »
From the ISS specs...
Wireless Communications
Transmit/Receive Frequency. . . . . . . . . . . . . . . . . . .
US Models: 902-928 MHz FHSS
Overseas Models: 868.0 - 868.6 MHz FHSS
Do you know what the ultrasonic uses Stefan?
Offline vreihen
  • El Niņo chaser
  • K2BIG
« Reply #44 on: October 15, 2018, 04:14:49 PM »
I thought that the ultrasonic was wired to the ISS?
Is it being powered by the ISS, or an external power supply?  Could this be an under-voltage from the ultrasonic drawing too much power from the ISS?  Ground loop if one or more AC transformers are in use?????
Offline dendrite
« Reply #45 on: October 15, 2018, 05:53:28 PM »
It's supposed to be powered externally. I'm using 12VDC. I forgot my meter at work, but the power supply I bought came as a 2 pack and I've had similar results with each. The cord to the ISS has the typical 4 wires connected into the RJ11 connector. I'm not sure what that power wire leads to on the anemometer side though.
Offline dendrite
« Reply #46 on: October 17, 2018, 08:20:20 PM »
Okay...maybe someone with more electrical and ISS knowledge can help me out here. ;)
First of all, I've been in frequent correspondence with Stefan on this issue and he has been providing terrific customer service. They're willing to ship me another ultrasonic sensor free of charge if mine is faulty. So I have 100% trust with him right now despite the problems.
Now, I'm noticing that I'm getting good data during the day when the sun is shining on the transmitter solar panel. When the shade sets in the data starts to go awry. I get a minute or two of bad data every 10 or so minutes and it picks up in duration throughout the evening until all of the readings are faulty. On Monday we had fog, mist, and drizzle the entire days with low solar radiation and the bad readings happened all day. Today the data was fine all afternoon until the shadows set in.
Again, this sensor runs on external 12VDC power and performs fine with solar radiation hitting the transmitter panel. What could be happening after the solar is lost? I should add that this is happening on two different transmitters too.
I'm assuming something is happening when the power source for the ISS shifts from the solar panel to the supercap. I considered snipping off the supercap from my older transmitter just for kicks and let it run off the solar and battery only, but I'm not sure if it would work with just the battery either. I want a long term solution too that won't cause me to drain through batteries.
Anyone have any ideas?
« Last Edit: October 17, 2018, 08:22:24 PM by dendrite »
Offline vreihen
  • El Niņo chaser
  • K2BIG
« Reply #47 on: October 17, 2018, 08:41:50 PM »
Power the ISS from wall power?????
Offline dendrite
« Reply #48 on: October 17, 2018, 09:33:04 PM »
Good thinking. Looks like it uses 5V. Will I fry it with a 12VDC adapter?
Offline dendrite
« Reply #49 on: October 17, 2018, 10:01:16 PM »
I found a 2.4VDC adapter lying around that fit into the ISS connector and no luck. Still bad data.
