Author Topic: Is there a way to get another's "Embeddable URL"?  (Read 668 times)
« on: July 16, 2018, 10:20:58 AM »
Previously with WL1, you could click on any station on the map and get the "blue sky w/clouds" old display screen. This could be added to a website, or bookmarked, etc.
Now with WL2, you only get a gray box with the data and a link to the bulletin (if you have Pro).
I cannot seem to find an equivalent way to access the "EmbeddablePage URL" for other stations (like mine: https://www.weatherlink.com/embeddablePage/show/36dd565fa0c34d82a26e2ce9c1b38abb/wide )
Is there a way to do this other than trying to get the station's owner to send you the link?
Offline graculus
Re: Is there a way to get another's "Embeddable URL"?
« Reply #1 on: July 16, 2018, 10:33:20 AM »
You can find 'em with a simple google search so a more targeted search might find what you want  ;)
« Reply #2 on: July 16, 2018, 12:24:05 PM »
Thanks for the suggestion, but the one I am looking for doesn't show up. Good idea though.
I even tried weatherlink.com/embeddablePage/show/ "Vantage Vue via WeatherLinkIP" as a search term since that is what he is using. His did not show up in the single page of hits.
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
« Reply #3 on: July 16, 2018, 12:54:14 PM »
Hey Greg, well if you know them I would go ahead and ask.  I have just started to use WL2 so just getting into it myself.
Davis Vantage Pro2, Serial Data Logger
WD 10.37S-(b60), VWS V15.00p03, Weatherlink 6.0.3,  Fling 2.35, Broadwave 2.0, Win 7 Pro 64Bit
KMICHEBO10 - CW3699 - Cheboygan, MI
Offline johnd
« Reply #4 on: July 16, 2018, 01:13:38 PM »
It's worth remembering that in the API documentation it says 'Please DO NOT distribute or share your unique API token. '. I don't see any way they can stop you but Davis are obviously not keen on encouraging it.
I think the idea is that your data is private unless you choose to publish it eg on your own website or you explicitly share it with someone ( which isn't implemented yet, except for EM, but should be available soon AIUI).
Littleport, Ely, Cambs UK
« Reply #5 on: July 18, 2018, 08:33:01 AM »
I don't quite understand what the API token has to do with the "embeddable" pages. I just generated the API token and it is different from string contained in the Bulletin URL and the embeddable links.
My Bulletin looks like this: https://www.weatherlink.com/bulletin/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx4f7a
The embeddable is like this: https://www.weatherlink.com/embeddablePage/show/xxxxxxxxxxxxxxxxxxxxxxxxxxxxx8abb/wide
Yet the API Token is like this: XXXXXXXXXXXXXXXXXXXXXXXXXXXX0B35
My point is that you were able to bookmark or use the URL from the old "Blue Sky" page as you wished, yet this new equivalent "embeddable page" seems to be a deep dark secret. I thought that we weren't supposed to be "losing anything" vis-a-vis the WL1 setup.
Offline johnd
« Reply #6 on: July 18, 2018, 09:15:52 AM »
Ah OK, must admit that I hadn't looked at them in detail and just assumed they were the same (or at least variations on the same core UUID or whatever it is). But maybe the point still stands that Davis don't appear to want to encourage their distribution.
AFAIK that's the general theme, but not sure I've seen it explicitly stated anywhere.
