Author Topic: WiFiLogger - Connect your Davis console directly to the Internet via WiFi  (Read 67673 times)
Offline WiFiLogger
« Reply #875 on: February 08, 2019, 11:00:17 AM »
@galfert thank you. You have helped me to make my device better for all WFL users.
If someone would like to update his WFL to ver 2.12.
You have to open http://WFL_IP/update
Choose firmware update and click "Update"
Firmware will be downloaded from server.
For some time (firmware time) I will let to be special web for barometer.
http://WFL_IP/bar
Offline mzac
« Reply #876 on: February 08, 2019, 11:19:32 AM »
Just updated mine:
Barometer: 29.697
Barometric Reduction Method: 2   - NOAA Bar Reduction. For VP2, this will always be 2.
User-entered Barometric Offset: 0
Barometric calibration number: 65495
Barometric Sensor Raw Reading: 29.575
Absolute Barometric Pressure: 29.575
Altimeter Setting: 29.691
Elevation in feet: 108
Calculated Altimeter: 29.691
http://WFL_IP/bar
Offline WiFiLogger
« Reply #877 on: February 08, 2019, 11:39:55 AM »
Probably I will add "Barometric Sensor Raw Reading" to JSON export file. Should help if somebody will like to recalculate barometer in own way.
Altimeter not, because there is many algorithms to calculate altimeter pressure. If someone has atmospheric pressure then can easily calculate any value.
Offline DRoberts
« Reply #878 on: February 08, 2019, 11:56:54 AM »
I am not having any luck with this link. Just get "server not found"-
Any ideas?
Offline WiFiLogger
« Reply #879 on: February 08, 2019, 12:04:12 PM »
Any ideas?
You have to have version 2.xx of firmware.
WFL_IP you need to know this number. My WFL has number 192.168.2.230
http://192.168.2.230/update
You have to know your WFL IP.
Online 92merc
  • BismarckWeather.net
« Reply #880 on: February 08, 2019, 04:26:15 PM »
Upgraded to 2.12.  BAR pages shows proper.  I may have to switch from Cumulus to WFL for CWOP uploads.  Just so it'll quit complaining about my BAR values.
Online 92merc
« Reply #881 on: February 08, 2019, 04:32:48 PM »
That brings up a question.  If I have UV and solar radiation on my VP2, is WFL automatically sending it to CWOP?
Just curious since in Cumulus MX, I have to check a box to enable that.
Offline WiFiLogger
« Reply #882 on: February 08, 2019, 04:41:31 PM »
If  Solar is not "---" then is added to CWOP export and many other.
I am trying to not make any options for users, because that will complicate WiFiLogger and become not user friendly.
I like WeatherLInk IP. It is sending all data from console to WeatherLink.com and you need to do nothing. Perfect.
WiFiLogger couldn't be make like this, but I should keep it close to it.
Offline WheatonRon
    • WUnderground
« Reply #883 on: February 11, 2019, 12:08:50 PM »
I contacted WeatherCloud support requesting what barometric pressure they desire to be uploaded to them from our pws. They stated “compensated barometric pressure”. How does this term fit into altimeter and sea level pressure? My guess is sea level pressure.
« Last Edit: February 11, 2019, 12:13:15 PM by WheatonRon »
Offline BigAlT
« Reply #884 on: February 11, 2019, 02:38:07 PM »
Any ideas?
 You need to enter the IP address of your WiFi Logger in place of WFL_IP
Davis Vantage Vue ISS & Console with WiFi Logger
Offline WiFiLogger
« Reply #885 on: February 12, 2019, 01:51:19 PM »
Ron.
Altimeter and barometric pressure in this case when we have atmosheric pressure sensore readings, both are sea level pressure reduction algorithms.
Barometer pressure is quite complicated. It takes not only elevation, but also temperature, humidity and dew point.
Altimeter needs only elevation.
There is more than one alghoritm for sea level reduction.
Please check  here: www.softwx.com
    // formulas/algorithms
      // Sea Level Pressure reduction algorithms
      TSLPAlgorithm = (
        paDavisVP,  // algorithm closely approximates SLP calculation used inside Davis Vantage Pro weather equipment console (http://www.davisnet.com/weather/)
        paUnivie,   // http://www.univie.ac.at/IMG-Wien/daquamap/Parametergencom.html
        paManBar    // from Manual of Barometry (1963)
      // Altimeter algorithms
      TAltimeterAlgorithm = (
        aaASOS,     // formula described in the ASOS training docs
        aaASOS2,    // metric formula that was likely used to derive the aaASOS formula
        aaMADIS,    // apparently the formula used by the MADIS system
        aaNOAA,     // essentially the same as aaSMT with any result differences caused by unit conversion rounding error and geometric vs. geopotential elevation
        aaWOB,      // Weather Observation Handbook (algorithm similar to aaASOS & aaASOS2 - main differences being precision of constants used)
        aaSMT       // Smithsonian Meteorological Tables (1963)
      TVapAlgorithm = (
        vaDavisVp,  // algorithm closely approximates calculation used by Davis Vantage Pro weather stations and software
        vaBuck,     // this and the remaining algorithms described at http://cires.colorado.edu/~voemel/vp.html
        vaBuck81,
        vaBolton,
        vaTetenNWS,
        vaTetenMurray,
        vaTeten
But, CWOP needs altimeter value. It has to be done.
Same problem I had on the beginning with coordinates. They use not very popular standard to describe longitude/latitude.
I hope that now WiFiLoggers will deliver proper data to CWOP.
« Reply #886 on: February 12, 2019, 02:48:09 PM »
WheatonRon,
WeatherCloud wants Sea Level Pressure. CWOP is the only online service you publish to that I've seen that requests Altimeter. That doesn't mean some people do what they want and play by their own rules. Here is a copy from their blog answering this very question. I use a Meteobridge and it has been around for years. It sends Altimeter to CWOP and it sends SLP to everything else. I publish to upwards of 9 online services. If there was a problem the Meteobridge would have changed this by now.
https://blog.weathercloud.net/?p=2220
« Last Edit: February 12, 2019, 02:57:15 PM by galfert »
WS-2000 & WS-2902A | Ecowitt GW1000 | Meteobridge (WeatherBridge)
Online PaulMy
« Reply #887 on: February 12, 2019, 05:10:04 PM »
Seems my v20 update has failed.
Followed each step in the instructions and completed 3.1 and got the message Update Correct Restarting
After a minute or so got a browser message
The connection has timed out
The server at 192.168.0.250 is taking too long to respond.
Now I can't access 192.168.0.250
Any suggestion what I should do next?
Komoka, ON  Canada
Online PaulMy
« Reply #888 on: February 12, 2019, 05:46:20 PM »
All resolved...
The update removed my previously designated IP address and I had to search through each IP until I got the WiFiLogger.
Then was able to reinstall the config and stationconfig files and that reestablished the original IP address.
All good now, except for one upload ;)
Komoka, ON  Canada
Offline jcookjr82
« Reply #889 on: February 13, 2019, 04:10:13 PM »
I keep getting -1F dew point readings kicked out to multiple weather sites (WU and PWS, for example). I think it is a glitch of the logger since it is going to more than one site. I am wondering if anyone else is having this issue? I have uploads to PWS set to once a minute and yesterday -1F was sent 6 times. See link:
https://www.pwsweather.com/archivewx.php?id=ROSEGARDEN&d=20190212&t=
Davis Vantage Vue
« Reply #890 on: February 13, 2019, 04:26:08 PM »
Probably not the logger. Most likely it is your ISS that is having temp/humidity sensor issues. Bad news is that unlike the VP2, the Vue is a complete harness part that needs the whole thing replaced. The Vue was not designed to be serviceable. I'm not saying 100% that this is your issue...but you should check you console reading and see if you see it occurring there too. If you have another data logger perhaps the one before you upgraded to the WiFi Logger then test with that.
« Last Edit: February 13, 2019, 04:28:23 PM by galfert »
« Reply #891 on: February 13, 2019, 04:31:49 PM »
Wow, it's barely a year old.
I know...tell me about it. User DRoberts that I recently helped get on CWOP also has a bad temp/humidity sensor and he was lucky to catch this before his 1 year anniversary so it was covered under warranty. So the good news for you is if you too are under the year warranty then you have recourse. Lots of credit cards also offer free 1 year extra warranty for purchases. So there is that too. I myself would be sporting a Davis if this issue had been resolved by now. VP3 can't come soon enough....fingers crossed. That does nothing for the multitude of people affected by these troublesome sensors. Davis needs to deal with this issue publicly. They gotta stop hiding behind their corporate and government clients that perhaps are not aware. Its like we the hobbyists don't matter.
« Last Edit: February 13, 2019, 04:33:43 PM by galfert »
Offline jcookjr82
« Reply #892 on: February 13, 2019, 04:33:11 PM »
I will have to play with it, I suppose. When I look at the data I stream to Weatherlink, it does not show a low of -1F, so I guess that is good. The unit was installed the first week of January 2018, so it is barely a year old.
Davis Vantage Vue
« Reply #893 on: February 13, 2019, 04:35:31 PM »
1 minute uploads to PWSweather is a bit much. I recommend dialing that down to 5 minutes or even 10 minutes so that the graphs can be meaningful. The PWSweather graphs just do not offer the level of granularity to nicely support 1 minute uploads.
Offline jcookjr82
« Reply #894 on: February 13, 2019, 04:38:20 PM »
My CWOP uploads are 10 minutes. It should be noted, my dew point readings have a two thumbs up, 100% rating, so my guess is that the -1F issue is not hurting the overall data. I guess I do not need such frequent uploads to PWS. I like my WU rapid fire. Gives me some entertainment while at work, such as right now.
Davis Vantage Vue
Online PaulMy
« Reply #895 on: February 13, 2019, 06:34:36 PM »
I am not seeing that issue http://www.pwsweather.com/obs/KOMOKA2.html
Komoka, ON  Canada
Offline jcookjr82
« Reply #896 on: February 13, 2019, 06:41:51 PM »
I went back and checked my data. The issue started on January 9. Only one day since then has there not been a -1F reading at least once during the day. Not a huge issue, but it obviously messes with the Hi/Low records.
Davis Vantage Vue
Offline WiFiLogger
« Reply #897 on: February 14, 2019, 03:17:50 AM »
I don't have this issue, but I think is because of LOOP reading function. I have change it.
Before I was using LPS, to read LOOP1 and LOOP2 in same time. But that was also problem.
Now it's LOOP command for LOOP1 and LPS for LOOP2.
From LOOP2 you have dew point and winds, like 2minAVG, 10minAVG, gust.
So I think you can have problem with LPS command.
I will check this function once more.
Offline jcookjr82
« Reply #898 on: February 14, 2019, 01:26:48 PM »
I went home and checked other upload sites. Weather Cloud does not show -1F and neither does the actual console (showed a low of 37 yesterday). AWEKAS does not show a Hi/Lo dew point reading. The issue seems to be with WU and PWS only. Thank you for looking into it.
Davis Vantage Vue
Offline chriaquilina
« Reply #899 on: February 16, 2019, 04:15:13 AM »
Dear all, I have been experiencing problems after upgrading the logger to 2.00, I am currently on 2.12. Sometimes the logger takes 12 minutes to send an update which is strange as with the old firmware data was being constantly sent to my server. I have tried two difference applications, CumulusMX and Weather Display and the problem still persisted. Wireless isn't a problem because the can see that it has a good signal from the Access Point and ping from the server is always under 2ms. Network monitors and the firewall tell me that traffic on port 22222 is flowing constantly from the wifilogger towards the server so communication is also not an issue.
This is a snapshot from Wdisplay logs:
6  2 2019  9  7 10.0  67 04.1 1025.0 11.2 13.0  66 0.0 3.8 14.6 105.8 10.0
16  2 2019  9  8 10.0  67 04.2 1025.0 11.0 13.0  24 0.0 3.8 14.6 105.8 10.0
16  2 2019  9  9 10.2  66 04.1 1025.0 10.4 13.0  96 0.0 3.8 14.6 105.8 10.2
16  2 2019  9 10 10.2  67 04.3 1024.9 9.1 17.4  73 0.0 3.8 14.6 105.8 10.2
16  2 2019  9 19 10.2  67 04.3 1024.9 10.1 11.3  40 0.0 3.8 14.6 105.8 10.2
16  2 2019  9 20 10.2  67 04.4 1024.9 9.3 10.4  17 0.0 3.8 14.6 105.8 10.2
16  2 2019  9 21 10.4  67 04.5 1025.1 9.2 10.4  71 0.0 3.8 14.6 105.8 10.4
16  2 2019  9 22 10.4  67 04.5 1025.1 8.7 21.7  28 0.0 3.8 14.6 105.8 10.4
16  2 2019  9 33 10.4  68 04.7 1025.1 8.0 7.8  54 0.0 3.8 14.6 105.8 10.4
16  2 2019  9 34 10.0  74 05.5 1025.2 7.0 7.0  60 0.0 3.8 14.6 105.8 10.0
16  2 2019  9 35 10.0  74 05.6 1025.2 6.5 12.2 101 0.0 3.8 14.6 105.8 10.0
16  2 2019  9 47 10.0  74 05.5 1025.2 7.7 16.5  55 0.0 3.8 14.6 105.8 10.0
16  2 2019  9 56 09.8  74 05.4 1025.3 9.2 11.3 103 0.0 3.8 14.6 105.8 9.8
16  2 2019  9 57 08.5  75 04.3 1025.8 6.7 10.4  49 0.0 3.8 14.6 105.8 8.5
16  2 2019  9 58 08.5  76 04.5 1025.8 6.7 7.8   5 0.0 3.8 14.6 105.8 8.5
16  2 2019  9 59 08.5  76 04.5 1025.8 4.1 9.6 137 0.0 3.8 14.6 105.8 8.5
16  2 2019 10  0 08.5  76 04.6 1025.8 6.6 10.4 124 0.0 3.8 14.6 105.8 8.5
16  2 2019 10  1 08.6  76 04.6 1025.8 8.5 10.4 107 0.0 3.8 14.6 105.8 8.6
16  2 2019 10  2 08.6  74 04.3 1025.8 7.7 8.7  22 0.0 3.8 14.6 105.8 8.6
16  2 2019 10  3 08.7  74 04.3 1025.7 6.4 9.6 360 0.0 3.8 14.6 105.8 8.7
16  2 2019 10  4 08.8  73 04.2 1025.8 6.3 9.6  57 0.0 3.8 14.6 105.8 8.8
16  2 2019 10  5 08.9  73 04.3 1025.8 6.5 8.7 119 0.0 3.8 14.6 105.8 8.9
It is currently 10:13 and the Wifilogger hasn't sent any data to the server.
Thanks in advance for your help.
