Author Topic: WiFiLogger - Connect your Davis console directly to the Internet via WiFi  (Read 77924 times)
Offline WiFiLogger
« Reply #675 on: December 25, 2018, 08:22:41 AM »
Wojciech, would it be possible for you to make a few 'appearance/cosmetic' modifications to the 'Real Time Data' screen.
I have in mind to put some more info on first page: IP address, name of device, maybe some more.
I can make different data format, but It will involve cookie mechanizm like in http://wifilogger.net/station/php/ when you click on unit it is change and saved in current web browser.
Offline DRoberts
« Reply #676 on: December 25, 2018, 02:57:34 PM »
Advice needed WifiLogger setup:
Just got my Christmas present. Have installed WifiLogger in console. Does this screen shot look complete to you? Do I need the NTP time?
Thanks so much
You have time data missing here. This data comes as EVENT in javascript. Your web browser can have disabled events, or even not used it.
Please try it on different web browser. On my computer Internet Explorer don't use EVENTS, but Chrome and Firefox work fine.
Strange, but despite the blanks where no data appears, my page on WU is complete and has no issues. Time, date, etc are all accurate on the WU page. I guess it is a non issue and why worry.
I thank  you for your reply. This is my link:
https://www.wunderground.com/weather/us/ks/phillipsburg/KKSPHILL2
I do not have a webpage; future endeavor?
Offline Lars_Olsson
« Reply #677 on: December 25, 2018, 04:33:01 PM »
Hi Wojtek.
Tried to sign up and send data to WOW but it doesn't seem to work....
This is the debug.
Undergroud 5
Renew RTD
Renew HiLows
Client response time: 401
success
ARCHIWUM EXPORT. Int: 5
22:15:26 25-12-2018
22:15:26 25-12-2018
Command connected
220 Welcome to One.com FTP.
331 User "user" OK. Password required
530 Login authentication failed
FTP Fail
221 Goodbye.
FTP Fail: Command disconnected
WOW 9
Renew RTD
HTTP/1.1 400 Bad Request
Cache-Control: private
Content-Length: 11
Content-Type: text/html
Server: Microsoft-IIS/10.0
X-AspNetMvc-Version: 5.2
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Date: Tue, 25 Dec 2018 21:18:10 GMT
Connection: clo
Bad Request
Undergroud 5
Renew RTD
Renew HiLows
Client response time: 400
success
Custom FTP 11
Command connected
230 OK. Current restricted directory is /
215 UNIX Type: L8
200 TYPE is now ASCII
250 OK. Current directory is /log
200 TYPE is now 8-bit binary
227 Entering Passive Mode (46,30,211,100,214,28).
FTPPasv: Data port: 54812
FTPPasv: Data connected
150 Accepted data connection
FTP Writing
Data disconnected
226-File successfully transferred
226 0.341 seconds (measured here), 9.89 Kbytes per second
213 3458
200 Zzz...
« Last Edit: December 26, 2018, 06:18:24 AM by Lars_Olsson »
Offline R_o_B
    • Tzouhalem-Maple Bay Weather
« Reply #678 on: December 25, 2018, 10:55:03 PM »
Wojciech, I have never thought of making the display of the WiFiLogger available to any one other than myself, the person who owns the console where the WiFiLogger has been installed. Thus, I do not understand why you would need to go through the trouble of creating/reading cookies when all the default parameters (ie: temperatures, wind speeds, barometric pressures, rainfall and ET) should all be set within the 'Weather Station Settings' screen - why would I make the display of the WiFiLogger available to any one else and risking challenging hackers when the same weather data is available on my website!  :mad:
I really like your 'Real Time Data' display (other than the time/date display  ;)) but I do not care very much if some of the parameters (ie: temperatures, wind speeds, barometric pressures, rainfall and ET) can be changed from Imperial to Metric - why would there be a need to change from one measuring system to another (could you please explain your ideas/thoughts for such a need)?  :?
R_o_B
eMail: weather@tzweather.org
Offline WiFiLogger
« Reply #679 on: December 27, 2018, 04:56:57 AM »
Hi Wojtek.
This is the debug.
I will check this when I will return to my desktop. I can't examine this now.
Offline WiFiLogger
« Reply #680 on: December 27, 2018, 05:02:17 AM »
Please unpack and upload this HTML to your WiFiLogger. Then go to http://HTTP://YOUR_WFL_IP/edit, select index.html
on the top (almost) you will find variables:
    var DateSeparator = ".";
    var dateFormat = 0;
    // 0 - MM/DD/YYYY
    // 1 - DD/MM/YYYY
    // 2 - YYYY/MM/DD
    var timeFormat = 0;
    // 0 - 24h
    // 1 - local
Change what you need and click save (top bar)
« Last Edit: December 29, 2018, 03:04:55 PM by WiFiLogger »
Offline WiFiLogger
« Reply #681 on: December 27, 2018, 06:14:33 AM »
You mean wifilogger.net? Yes, this is long story. I have bought page, but never get it. I am not an artist to make it by my own, but I think I will have to.
Offline R_o_B
« Reply #682 on: December 27, 2018, 07:03:59 AM »
Please unpack and upload this HTML to your WiFiLogger...
Wojciech, the modification works perfectly. Thank you.  :-)
I feel somewhat sorry that you needed to add so much new code in order to process those new settings.  :oops:
R_o_B
Offline DRoberts
« Reply #683 on: December 27, 2018, 11:00:39 AM »
WiFiLogger, thanks for your "invention" and making it possible for low tech people like me to put their data on the net. Mine is working just great!
Offline WiFiLogger
« Reply #684 on: December 27, 2018, 12:27:56 PM »
You have just helped to improve my product. Why do you feel bad with it?
Offline WiFiLogger
« Reply #685 on: December 27, 2018, 01:13:58 PM »
Hi Wojtek.
This is the debug.
Lars I have checked WOW. It is working. WOW can't be uploaded to often, but that is not your case.
typical debug:
WOW 15
Renew RTD
Client response time: 950
to often:
WOW 5
Client response time: 850
The custom error module does not recognize this error.
Please check once more
ID should looks like this: 2566e7c4-3e6b-e811-9ccb-1233f459g2da
PIN you can define on WOW website.
Offline Lars_Olsson
« Reply #686 on: December 28, 2018, 02:10:30 AM »
Hi Wojtek.
This is the debug.
typical debug:
WOW 15
Renew RTD
to often:
WOW 5
Put in the data in cumulus to see if something was wrong, and it works fine. But still not working from logger.
Don't know why the logger wont do it.
Cheers.
Offline WiFiLogger
« Reply #687 on: December 28, 2018, 02:17:25 AM »
Cheers.
Which station do you have? What set of sensors?
Offline Lars_Olsson
« Reply #688 on: December 28, 2018, 02:48:05 AM »
Cheers.
Davis vantage vue.
Wind, temp, hum, winddir.
Offline rockncola
« Reply #689 on: December 28, 2018, 10:29:55 AM »
My WifiLogger arrived today from weatherstations.co.uk and I couldn't be happier. Very easy to set up and now working perfectly.
For anyone with the Vue, the instruction manual does say your Vue should make 4 beeps on reboot to indicate the device is plugged in and working properly, but my Vue has always only made 3 beeps, both with WifiLogger and also with Belfryboy's logger. So, if there's anyone with a Vue who's wondering why you're only getting 3 beeps, it may not be anything to worry about since mine has never made the full 4 beeps and works fine.
edit: Okay, so with that said, there is something I'd like to ask; how do I access previous days' data plus highs and lows using WifiLogger's web interface, just like I can using the console or other software? Or, is that not possible yet? I feel like the web interface needs a lot more customisation overall but I have faith that will eventually come.
« Last Edit: December 28, 2018, 02:02:45 PM by rockncola »
Offline gbothwell
« Reply #690 on: December 28, 2018, 05:45:22 PM »
Does anyone know if it is possible to update vantage Vue firmware via WiFi Logger?
Offline WiFiLogger
« Reply #691 on: December 29, 2018, 10:14:59 AM »
No problem with that, but you have to turn on AUTO PAUSE in SYSTEM menu and Davis upgrade software won't find automatically your WiFiLogger. You have to retype IP address of WFL by your own.
Offline Lars_Olsson
« Reply #692 on: December 29, 2018, 10:34:30 AM »
What is the latest sw?
Offline WiFiLogger
« Reply #693 on: December 29, 2018, 10:58:29 AM »
1.24 - no new options, just some problems resolved.
Offline gbothwell
« Reply #694 on: December 29, 2018, 11:17:50 AM »
Fantastic, Thank you.
Offline gbothwell
« Reply #695 on: December 29, 2018, 11:51:05 AM »
when changing to local time, the time zone is off... but 24hr time it is correct.
Offline rockncola
« Reply #696 on: December 29, 2018, 02:24:30 PM »
Will there eventually be an option to view previous days' recorded data?
Offline WiFiLogger
« Reply #697 on: December 29, 2018, 03:08:18 PM »
Yes. My fault. Javascript has quite problem with time display.
I have change this file now is:
    var timeFormat = 0;
    // 0 - 24h
    // 1 - 12 AM/PM
Time format is in console memory. I will change it in future to do this job automatically from the console settings.
Offline WiFiLogger
« Reply #698 on: December 29, 2018, 03:09:25 PM »
I have concept how to do this, but I can't make it in one week :(
Offline gbothwell
« Reply #699 on: December 29, 2018, 06:45:52 PM »
    var timeFormat = 0;
    // 0 - 24h
    // 1 - 12 AM/PM
This is working great now. Thank You
