Author Topic: WiFiLogger - Connect your Davis console directly to the Internet via WiFi  (Read 73777 times)
Hey Wojtek.
Have a question.
Today at 2:15 the wifi logger had a high heat index of 122F.
Weatherlink software at 2:15 showed a high heat index of 115F.
Does the wifi logger show different highs because it samples data every few seconds.
Or the does the Weatherlink software show a different value because it's taking an average of my 10 minute archive.
Cumulus also showed a high heat index of 115F
Offline WheatonRon
    • WUnderground
Hey Wojtek.
Have a question.
I will let Wojtek give the official answer but it appears with my WiFi Loggers it is taking whatever the Davis console displays and not making a separate calculation.
Hey Wojtek.
Have a question.
The logger merely reports the news, it doesn't make it. So, I'm guessing you saw a "live" 122F on WL but a 115F average due to you enabling the archive average feature on WL.
You can enable an archive average in WL?
Oh, I figured that's what you had already done. Anyway, yes, go into WL "setup" and select "temp humidity cali", you'll see the box to check mark there.
Found it but the option to average over the archive period is not enabled.
Back to square 1.
Back to square 1.
So when you say the logger shows 122F, what does that mean?
The live feed from the logger that shows the current data.
Vantage Pro™,Vantage Pro 2™Firmware : 1.90, Sep 29 2009
18:41:21 07.04.2019
 UnitsCurrentToday's HighsToday's Lows
Inside Temp[°F]79.278.914:4475.80:13
Outside Temp[°F]74.595.114:1974.316:09
Heat Index[°F]78.0122.014:18
THW Index[°F]---
Wind Chill[°F]75.0  74.016:06
Inside Hum[%]525910:194916:37
Outside Hum[%]94967:316114:20
Dew Point[°F]73.0/72.782.014:1971.015:33
Current Wind Speed[mph]0.014.015:30
Current Wind Direction  319NW
2 min Avg Wind Speed[mph]0.0
10 min Avg Wind Speed[mph]0.3
10 min Wind Gust[mph]3.0
Wind Gust Direction  315NW
Barometer[in]30.01630.04112:1429.9662:59
Bar Trend   Rising Slowly
Rain Rate[in]0.003.9715:37
   DailyStormMonthYear1Hour24 H
Rain[in]0.480.560.6020.980.010.48
ET[in]0.00 0.000.00
Sunrise:6:34Sunset:20:30Batt:
Don't know if this would help but I see you're using 1.90 firmware, that's 10 years old and improvements have been made to heat indexes since. Select "Software/Firmware" first, then go from there.
https://www.davisinstruments.com/resources/weather-monitoring/#support
I'll check it out but I had it refurbished about 2 or 3 years ago. I assumed they updated that at the time, or this unit was an older model  that couldn't be updated.
Yeah, make damn sure you don't put something on there that doesn't belong, you may brick it.
Offline WiFiLogger
I don't know how Cumulus, but WeatherLink is taking only LOOP1 data.
Heat index, dew point, avg 2 min wind, 10 min gust etc. are in LOOP2.
WeatherLink is calculating those from LOOP1.
But this value (high day HEAT index)comes not from LOOP1, or LOOP2, it comes from HiLow.
I don't created this value.Hi/Lows are in console as a part of current data.
Average temp in archive memory should not change this value.
WiFilogger still can have minor problems with units calculation, but temp in F is not calculated, so this value is raw from cosnole.
Offline PaulMy
I think Cumulus 1 uses Loop1, but CumulusMX uses Loop2 by default and it can be turned off.
Enjoy,
Offline rockncola
Is 2.09 still the latest version? Just making sure I haven't missed out on any updates.
Offline 92merc
  • BismarckWeather.net
I have 2.24.  So it's at least that.
Davis VP2, Cumulus, WeatherDisplay, Blitzortung, Bloomsky, Saratoga Scripts, NOAA Stream via PI
Offline BigAlT
Just updated and got 2.24.
Davis Vantage Vue ISS & Console with WiFi Logger
Davis Vantage Pro2 Console with Meteobridge Nano SD
Davis Weather Envoy with USB Logger connected to RPi 3B+ running WEEWX
WeatherFlow Smart Weather Station
Offline MatteoPV
I'm at 2.16 as a firmware for the wifilogger. Here we talk about 2.24, is there any news?
Offline BigAlT
The current update on the US server was 2.24 yesterday when I did my latest update.
Offline MatteoPV
Can I update quietly without losing my settings ??? However I do not see an official communication of the new relise
Offline davidmc36
  • Morewood Ontario Canada
    • IONOTTAW14
I did 2.23 and it never lost a thing.
Offline MatteoPV
I prefer to wait for the official news with the latest news on the relise
Offline WiFiLogger
I have put 2.24 on server to test Windy.com.
It is not finished yet. So nothing interesting to brag about.
You can turn on Windy.com, but you don't have access to your station, because you don't know your ID.
I have to make function to download your ID from Windy.com.
Also I have to make registration form, where you will be able to set info about your station. Latitude, longitude comes from Logger, but station name, temp sensor high, wind sensor high is custom.
I have access to all loggers working with Windy.com. May I publish links to those station here?
Also in 2.24:
- working GLOBE emails for schools.
- new set of libraries for ESP8266 chip. Like any update should fix some problems and make some new.
- some software mistakes repairs
2.25 will be better, because I have rebuild custome HTTP export and I have made PHP script to catch data.
wflexp.json will be avaible, but new set of files was made.
1- registration - info about console and logger
2 - real time data json, can be exported every 3 sec.
3 - hilows json, can be exported every 3 minutes.
4- logger data json, package of 5 logger entries in json format
This data is saved to 4 SQL tables. Working grate, but probably I will need to rebuild this, because MySQL has minor fault.
With this function, I have made same functionality like WL.COM has. This is a backyard of data presentation, but I had to start with something.
Offline MatteoPV
Great. I await a final version before updating
Offline redlynr
just curious, with the wflexp.json, is it possible to create an Alexa skill that references this?  Theoretically I’d think this should be easy, but I’m just a hack and have no idea how to do this.
Offline DRoberts
I use a WiFi Logger and Verizon just replaced our Wifi (JetPack) today.
I no longer have connection to Weather Underground and am unable to bring up my Real Time Data screen.
Limited tech understanding here. Is the new JetPack (wifi) likely the culprit and what could I  do to fix it if so?
