On new style dashboard, the map does not load properly - bottom is truncated. [I am using Chrome]
Using CTRL + Refresh fixes the truncation issue (suggesting the WU software is passing incorrect caching instructions), but the the hyperlink to Wundermap uses space that could be otherwise better uitlised by the map. Perhaps this hyperlink could be moved outside the map container altogether, or at least moved to the bottom right hand corner underneath the (C)Mapbox notation, with the actual map data underlaid (like it is with the Mapbox notation).
Edit: Shortly afterwards, CTRL + Refresh fails to fix the truncation issue - WU Team perhaps working on this as I type?
Then a little while later, after restarting my browser, the map loads fine the first time, but thereafter will only display the truncated map and CTRL + Refresh will not resolve the issue
And yet a little bit later, my dashboard, in all permutations of browser navigation, is showing a truncated map which does not resolve with CTRL + Refresh. [Now I am really confused].
WU Team must be working this issue as I type, or else I have a Chrome gremlin - now back to situation outlined at start of this post.
