Author Topic: Curly's Wx Story script  (Read 23340 times)
Offline tmabell
    • Mishawaka Weather
Re: Curly's Wx Story script
« Reply #150 on: July 28, 2020, 09:50:52 PM »
We know the script works because as you stated, it works on my server here.  Check your server's error logs.  When your script is viewed from the outside I get this (using Chromes Developer Tools) "Failed to load resource: the server responded with a status of 500 (Internal Server Error)"
Hopefully, the server's error log will provide a clue.
« Reply #151 on: July 28, 2020, 10:37:08 PM »
I will get ahold of IT and see if they can do anything. I do know there are no images in any folder.
« Reply #152 on: August 01, 2020, 07:17:16 PM »
There has to be an issue with server.
So I was able to iframe the weather story page to focus on the story part and not see the rest of the page.
Offline the beteljuice
  • the beteljuice
    • test site
« Reply #153 on: August 01, 2020, 08:38:01 PM »
Try putting this at the top of the script and see what comes back ..
ini_set('display_startup_errors',1);
ini_set('display_errors',1);
error_reporting(-1);
error_reporting(E_ALL);
Offline rrrick8
    • Vermilion weather
« Reply #154 on: December 06, 2020, 12:36:43 PM »
Does someone have the newest WxStory_inc.php v2.24 script they could share?
For some reason, ever since I upgraded my VPS server, I only get the main story pics no Alternate pics. The written text comes thru fine but none of the alternate pics. They are not being produced into the wscache folder.
This occurs on every site I try. I need to compare my script to a working one to see if I changed something along the way.
CWOP-CW9931 KILDANVI5
Offline CamarilloWX
  • CamarilloWX
    • Camarillo Weather
« Reply #155 on: December 06, 2020, 03:04:42 PM »
Reply #14 in this thread has a link to v2.25
Eric
Offline rrrick8
    • Vermilion weather
« Reply #156 on: December 06, 2020, 05:48:30 PM »
Thanks Eric for the link. I had definitely missed that.
Applied the couple of changes and now all working fine
« Last Edit: December 17, 2020, 09:39:39 AM by rrrick8 »
Offline K6GKM
  • CamWX.com
    • CamWX
« Reply #157 on: December 06, 2020, 08:29:14 PM »
Not sure how I'd missed this wonderful tool until now.  I'll be using this as an include on a page with other data, but I know for a fact my local WFO doesn't generate a weather story daily.  I'm not too fond of an image placeholder if there's no current weather story...  I don't suppose anyone out there has a mod to suppress the weather story code entirely if there's no current images?
If not, no worries...
Grant
Grant Miles
Camarillo, CA, USA
Owner/Admin - CamWX.com
SKYWARN Spotter
Station Hardware: Davis Vantage Pro2 Plus w/ 24hr FARS
Station Software: Weather Display, Weather Message, FWI Calculator, StartWatch, with social media & messaging automation using Make.com, Twilio, and Brevo.
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« Reply #158 on: December 07, 2020, 11:56:38 AM »
Hi All,
I have not used this script as it does not include Hawaii and Alaska.
Hope maybe one day we could be included?
Aloha.
--Stan Y.
  Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline tmabell
    • Mishawaka Weather
« Reply #159 on: December 07, 2020, 12:06:28 PM »
The NWS offices in Alaska and Hawaii do not make the Weather Story available so they cannot be included in the script.
Offline Silversword
  • --Stan Y.
« Reply #160 on: December 07, 2020, 12:35:27 PM »
Thanks for the reply tmabell.  That is what I would have thought but maybe one of these days they will have one, so we will be able to be added to this script.
Aloha,
--Stan Y.
   Maui, Hawaii
« Last Edit: December 07, 2020, 01:29:48 PM by Silversword »
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline rrrick8
    • Vermilion weather
« Reply #161 on: December 07, 2020, 01:11:28 PM »
Never say never. Took a long time for Eastern Region to use it.
Offline mchlwvr614
« Reply #162 on: December 17, 2020, 09:27:06 AM »
Wasn't sure if I should add to this thread or create a new one.  Anyways... I thought I had this script working but it looks like the cached images are randomly created as empty files, zero bytes.  Any ideas on what to look for?  Thank you
http://weavernet.dyndns.org/etnwx/wxStory.php
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« Reply #163 on: December 18, 2020, 05:45:30 PM »
I tried v2.25 and the stories wont show up. My cache directory looks good. Got the permissions set to 775.
https://www.northbendweather.com/wxstory.php
My local NWS does publish stories almost everyday. https://www.weather.gov/sew/
Any ideas? Running php 7.2
Software: WeatherDisplay
Offline Otis
  • (aka Paul)
    • Lake Huron Weather
« Reply #164 on: December 18, 2020, 06:25:25 PM »
No idea but interesting.  I can see the image when viewed with my site/page.  Yours has the text just not the image, strange.  Will be interested in the answer.  Wish I could help.
UPDATE: just went to add the link from my site and the Seattle Wx Story is gone, just like that.
CW3699
Offline mkutche
    • GosportWx.com
« Reply #165 on: December 19, 2020, 09:50:22 AM »
same the only story that shows up for me is KIND. for now I just $useallwfos     = false;
update none seem to work now..
« Last Edit: December 19, 2020, 11:21:19 AM by mkutche »
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #166 on: December 19, 2020, 12:06:39 PM »
ya idk what's going on how to fix it i even went back to 2.24 and it still doesn't work, when it use to.
Mike K.
Gosport, Indiana
Offline tmabell
    • Mishawaka Weather
« Reply #167 on: December 19, 2020, 12:47:09 PM »
Ver 2.25 has been tweaked a few times to address these issues.  Try my version which has been updated and is currently working.
Offline mkutche
    • GosportWx.com
« Reply #168 on: December 19, 2020, 01:24:18 PM »
I can see other Story pics but IND .. maybe i need to clear my wscache folder as shows the files but for the pic its wsimg_ind_Tab2FileL.png?1978e7d7654242cfc1bcc4de6247.1e4
edit: update your file worked! and cleared my wscache too thanks :)
« Last Edit: December 19, 2020, 01:28:08 PM by mkutche »
Mike K.
Gosport, Indiana
  • Mark
« Reply #169 on: December 19, 2020, 01:53:44 PM »
Your file worked for me too. Thanks.
Offline tmabell
    • Mishawaka Weather
« Reply #170 on: December 19, 2020, 02:41:00 PM »
I'm thinking that with the tweaks I mentioned that perhaps we should refer to this as Ver 2.25b?  Maybe Ken has thoughts on giving it the once over and an upgraded version number so as to keep confusion to a minimum.  \:D/
« Reply #171 on: March 04, 2021, 11:55:58 AM »
mine is not loading.   anyone else having issues?
https://bsmweather.org/weatherstory.php
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #172 on: March 04, 2021, 12:03:21 PM »
All dead but 2 in ND and one in MN for the past 2 days.  It looks like the NWS has abandoned it, but time will tell.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline rrrick8
    • Vermilion weather
« Reply #173 on: March 04, 2021, 12:33:18 PM »
It's not posting on the CWA's websites but it is there, or at least part of it is. At least is for ILX and some others I checked.. I just right clicked the Wxstory icon on their website home page and opened image in new tab.
Hopefully just a momentary hiatus.
« Reply #174 on: March 04, 2021, 08:25:47 PM »
Guessing it is a "Its not you" problem.   Headlines are updating. Not pics.
Oh well
