Author Topic: Curly's Wx Story script  (Read 23680 times)
Offline rrrick8
    • Vermilion weather
Re: Curly's Wx Story script
« Reply #100 on: December 30, 2017, 07:56:19 AM »
Don, I ran just your wxStory_inc.php without the template and everything was normal on 15 sites I tested.
Your problem is use withing the template, which I don't use so can't help you with that.
Again, though... it appears your WxStory is running fine.
Severe Weather Manager-Vermilion County EMA
CWOP-CW9931 KILDANVI5
Offline W3DRM
    • Emmett Weather
« Reply #101 on: December 30, 2017, 07:03:51 PM »
John, rrrick8,
I have attached two screen captures showing what I am seeing for both Reno and Grand Junction, CO. I see many other sites with similar results. For some reason, some of the sites display in a very wide format.
--- RIPE Atlas Probe - 32849
Offline rrrick8
    • Vermilion weather
« Reply #102 on: December 30, 2017, 09:04:44 PM »
Like I said above... if you run just the script wxStory_inc.php  it all looks good.
So I believe the script is fine it's just something askew with your placement in the template which I don't use so I can't help you on that one.
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #103 on: December 31, 2017, 11:18:41 AM »
Don, as Rick said it seems not to be in Curly's script. I ran my site script and selected Reno and it looks just fine (attached). I was unable to find the problem as well. Sorry.
W7JKG
Offline wvdkuil
  • Wim van der kuil
« Reply #104 on: December 31, 2017, 11:33:57 AM »
John, rrrick8,
Your http://www.carsonvalleyweather.com/wxStory_inc.php is fine. All html is clear and correct for all cities, without or with text..
But your wxstory.php has an extra line of code
<!-- end of menubar -->
<div id="main-copy">
<pre>
  <table border="0" cellspacing="0" cellpadding="0" style="width: 700px; margin: 20px auto 0px auto;">
 <tr>
  <td style="text-align:center;"><a href="http://www.weather.gov/rev/" onclick="window.open(this.href,'_blank');return false;" title="Click to view this forecast office" style="text-decoration: none; color: inherit;"><span style="font-size:20px; letter-spacing:2px;"><b><span style="color:#0061AC;">WEATHER STORY</span><br />Reno<br /><span style="font-size:60%; vertical-align: text-top;">Weather Forecast Office</span></b></span></a></td>
 </tr>
</table>
You should find that '<pre>' and remove it. That will take care of the very wide page, which only occurs when there is text below the map. That text will be as wide as the longest line, because of that '<pre>'. You can see that all bottom text is displayed in a monospaced courier font and without line-breaks.
We can not check your php script online, so if you can not find that <pre> , post the script here with the .txt extension.
Wim
« Last Edit: December 31, 2017, 11:47:16 AM by wvdkuil »
Offline W3DRM
    • Emmett Weather
« Reply #105 on: December 31, 2017, 12:52:18 PM »
John, rrrick8,
   <pre>
 <tr>
 </tr>
</table>
Wim
Wim, you are a genius! =D&gt;  That was the problem. Since I was incorporating this code into my Saratoga template, I had simply taken the code and included the <pre>...</pre> in my wxstory.php and that is what was causing the issue with screen width.
Thank you very much for the assistance. I have included the code section from my wxstory.php that I am now using to include the wxStory_inc.php, for Saratoga template users.
<body>
<?php
include("header.php");
include("menubar.php");
  <?php include("wxStory_inc.php"); ?>
<><!-- end main-copy -->
<?php
include("footer.php");
# End of Page
Offline tmabell
    • Mishawaka Weather
« Reply #106 on: February 28, 2018, 04:26:51 PM »
I think this script is another casualty of the changes made yesterday by the NWS.  There are no images showing as of today.  Any thoughts on what needs to be changed?
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #107 on: February 28, 2018, 07:32:39 PM »
I just checked it this morning and it was working.  Now it's not displaying the graphics.
Yecchhh! :-(
Regards, Jerry Wilkins
gwwilk@gmail.com
« Reply #108 on: February 28, 2018, 07:36:01 PM »
I'd try changing
(in_array($wswfo, $hpwxs)) ? $wxsurl =  'http://www.weather.gov/'.$wswfo.'/' : $wxsurl = 'http://www.weather.gov/'.$wswfo.'/weatherstory';
to
(in_array($wswfo, $hpwxs)) ? $wxsurl =  'https://www.weather.gov/'.$wswfo.'/' : $wxsurl = 'https://www.weather.gov/'.$wswfo.'/weatherstory';
and make sure you have
$useCURL        = true;               // true=get data by cURL method  false=stream data
Offline gwwilk
« Reply #109 on: February 28, 2018, 07:41:19 PM »
Thanks, but no joy, Ken.  Still no images.  I tried  to place 'oax' in the https array, but that didn't work either.
Curly's code is more than a bit difficult for me to unwind.  I've given it a shot but now I'm not even seeing new images show up in my '/wscache' directory.
gwwilk@gmail.com
Offline jgillett
« Reply #110 on: February 28, 2018, 08:07:58 PM »
Not every city displays graphics on a regular or daily basis. PSR is a good example. Yesterday there was info about a coming rainstorm and a large graphic to go along with it. Today it says, "Phoenix does not have the Weather Story." Well they do, but when they want. I pushed a lot of green buttons on the map today. Pretty much the same wording along with a lot of other text items below the map.
« Last Edit: February 28, 2018, 08:11:17 PM by jgillett »
W7JKG
Offline mkutche
    • GosportWx.com
« Reply #111 on: February 28, 2018, 08:39:26 PM »
none of mine are working either.. i applied the fix that ken suggested but nothing. http://www.gosportwx.com/wxstory.php?i=ind
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Offline W3DRM
    • Emmett Weather
« Reply #112 on: March 01, 2018, 11:01:49 AM »
Worked fine for me two days ago (2/27) but now all I get is the text with a broken image symbol displayed. Just when I need it most as we have the season's largest storm coming-in right now...  ](*,)
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
« Reply #113 on: March 01, 2018, 11:09:30 AM »
It seems that the NWS used to accept query strings without a "?" such as http://www.weather.gov/images/arx/wxstory/Tab2FileL.png e73c9f3d342158b6aa283cb30e80054 but no longer does.  Perhaps Ken and his regex wizardry will be able to come up with a better fix, but this seems to be doing it for me:
replace
function GetDataByCurl($url)    {
  global $noted;                                                          // set global
with
  $url = str_replace("png ", "png?", $url);    // added 3/1/18
and
function getWSBystream($url) {
  global $noted;
with
  global $noted;
- Jim
Online 92merc
  • BismarckWeather.net
« Reply #114 on: March 01, 2018, 11:19:29 AM »
That update worked for me as well.
Offline gwwilk
« Reply #115 on: March 01, 2018, 12:45:02 PM »
Thanks, Jim! \:D/ =D&gt; \:D/ Works great!
gwwilk@gmail.com
Offline W3DRM
    • Emmett Weather
« Reply #116 on: March 02, 2018, 10:21:46 AM »
Jerry  - I notice the map does not change when you select the various green dots. Once I select another location, it always shows the Pocatello, ID section of the map. The wx story and header do change with each different selection. Not sure if it's me or not. I've tried it on Chrome and Firefox and get similar results.
Offline gwwilk
« Reply #117 on: March 02, 2018, 10:28:51 AM »
I think it has to do with file permissions, but I haven't solved the problem yet.
gwwilk@gmail.com
Offline W3DRM
    • Emmett Weather
« Reply #118 on: March 02, 2018, 11:21:11 AM »
Jim's update worked for me, except for the Reno sector. Others appear to be working just fine but not Reno, that still gives me the broken image icon... And, the map shows the correct selection so not sure what the issue is with Jerry's. It could be file permissions as he indicated.
Offline jmcmurry
  • Jim McMurry
« Reply #119 on: March 02, 2018, 02:41:42 PM »
I just tried Reno and it worked fine for me.
As for the overlays on the US map working, are you using wscache as your cache?  I had to go to that to fix something, but I don't remember what the problem was when I did that.  I used to be able to remember things.
- Jim
Offline W3DRM
    • Emmett Weather
« Reply #120 on: March 02, 2018, 03:14:50 PM »
- Jim
The Reno image is working now. I don't know what "wscache" is...
Offline jgillett
« Reply #121 on: March 02, 2018, 03:51:34 PM »
Created by wxStory_inc.php - $ws_cachefolder = './wscache/'; Also $wfomaps = './wsimages/';
It's loaded with stuff!
« Last Edit: March 02, 2018, 03:53:50 PM by jgillett »
W7JKG
Offline W3DRM
    • Emmett Weather
« Reply #122 on: March 02, 2018, 04:14:55 PM »
Yes, I see them now. Both of them are loaded with files. I also have another folder named "wsmainimages". It has one file in it named WS_map.png. That same file is also located in the wsimages folder. They appear to be identical.
Offline jgillett
« Reply #123 on: March 02, 2018, 04:33:43 PM »
Interesting - I don't have the "wsmainimages".
W7JKG
Offline W3DRM
    • Emmett Weather
« Reply #124 on: March 02, 2018, 10:47:14 PM »
It's a mystery to me too. I suspect it might be a remnant of an earlier installation although all of the image files have a date of 1/6/2018 which is about the time I installed the Weather story routines. I don't have the original files I downloaded so can't go back to them to see if there was a sub-folder in them.
However, this brings up a question regarding the map of the US which shows the wfo's who participate in the weather story program. Who maintains this image file and how does it get updated when wfo's come on-line or drop-off the program?
