Author Topic: weewx, raspberry pie & LaCrosse TX22u  (Read 1865 times)
Offline sebviel
« on: June 05, 2017, 09:12:44 PM »
Hi everybody,
It's my first time posting on this forum, I'm a little bit newbie with weather stations but I'm using a Lacrosse wind sensor (TX22U) hardwired on the serial port of a raspberry pie and I would like to know if somebody already tried this kind of setup or as designed a specific weewx driver to interface the TX22U and it's own serial command.
Thanks and can't wait to see your suggestions...
Seb
Offline mwall
Re: weewx, raspberry pie & LaCrosse TX22u
« Reply #1 on: June 06, 2017, 07:07:34 AM »
if someone has already written a driver for the TX22U, i would encourage him/her to post a link to it with some of the other contributed drivers on the weewx wiki:
https://github.com/weewx/weewx/wiki
if you have the serial commands and any programming experience, it should take an hour or two to write a driver.  start with a simple driver such as texas weather instruments driver:
https://github.com/matthewwall/weewx-twi/blob/master/bin/user/twi.py
or the maxbotix driver (just the driver part, not the service part):
https://github.com/weewx/weewx/wiki/maxbotix
if you do not have the serial commands, then you'll have to create a serial sniffer (a physical tap on a serial cable - just a bit of soldering and a second serial connector), watch the serial traffic, then decode the commands and data.
post any questions and progress at the weewx development site:
http://groups.google.com/group/weewx-development
m
