Thru a series of events unrelated to WL, I ended up with a system lock up with nothing but desktop wallpaper but was able to 'task mgr' exit WL. From that point, WL would crash during the upload events. I ended up installing 5.8.2 (which I thought I had done already!) to no avail.
I tracked it down to whenever it generates any graphics for upload. Then to any graphic report. Then to the browse database function.
What I have is a browse display of only date and time of the archived data - no data. I'm assuming that whenever it tries to generate a graph or chart using that file, it crashes. Going into the edit screen of each record shows a full set of "clean" data values - it just doesn't display the headers or the values in the browse window.
(NOTE: My rain database was also goofy but clicking "NEW" rebuilt it)Ah HAH! GOT IT! Deleting the two DAT files (DataSets & DataLists) in the station directory did the trick. Opening them up with notepad showed them to be empty, for some reason, but still proper size. Would've been nice if they had a zero file size...
](https://www.wxforum.net/Smileys/default/eusa_wall.gif)
Letting WL rebuild the structures to a pair of new files cleared it up.
Soooo... if WL crashes after you totally whack out your system -
- check if it crashes during uploads or strip chart or plot displays
- 'browse' the database (notepad looking icon)
- if it shows only date and time, check an entry for data (double-click or go to edit)
- if data there, close WL and delete the two DAT files - "DataSets.dat" & "DataLists.dat"
I composed this while I was checking a few last things before I found the problem but I'll post it in case someone else should ever get jammed on this...EDIT: I forgot to mention that using the "Repair" feature of the 5.8.2 installer does not repair those files.
