Author Topic: Fire Danger  (Read 4453 times)
Offline 92merc
  • BismarckWeather.net
Re: Fire Danger
« Reply #25 on: February 25, 2017, 07:09:17 PM »
OK, looks like you added the CBI=0 there, I think it is ok now:
http://www.bismarckweather.net/fire.php
I'm happy with it.  Something quick and simple.  Thanks for the help.
Offline PaulMy
Re: Fire Danger
« Reply #26 on: February 25, 2017, 07:11:28 PM »
Yes that duplicate text and 0  now gone.  Great job on your conversion and your template =D>
Enjoy,
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Fire Danger
« Reply #27 on: February 25, 2017, 07:27:48 PM »
Glad it is working for you, you can more or less play around with the HTML the way you want. Make sure you leave the PHP part. It uses standard CSS so you can change the size of the font, colors etc.
Just one last thing, I have to correct you... Im not a coder, just a night-time hobby :)
Offline 92merc
Re: Fire Danger
« Reply #28 on: February 25, 2017, 07:53:35 PM »
Hey!  You can code better than I can.  :-)
Offline Jáchym
    • Meteotemplate
Re: Fire Danger
« Reply #29 on: February 25, 2017, 07:58:56 PM »
Yes, which means we are both non-coders :D
Offline 92merc
Re: Fire Danger
« Reply #30 on: February 27, 2017, 05:51:21 PM »
I got a reply from Mike over at GoSportWX.com.  He gave me the PHP file.  Inside I saw it required two javascript files I was able to grab off his site.  So rename each of these three txt files and plop them on your Saratoga script site.  Worked like a charm for me.
Offline 92merc
Re: Fire Danger
« Reply #31 on: February 28, 2017, 10:02:02 AM »
I noticed two of the Drought image locations were showing from 2015.  The image locations had changed.  So here's a new PHP for that file.
