Author Topic: NOAA WEATHER RADIO  (Read 153749 times)
Offline mikev
Re: NOAA WEATHER RADIO
« Reply #925 on: August 26, 2018, 07:11:25 AM »
Just wanted to note, since there's a desire for SSL, my KHB36 feed is now available via SSL as well. I've been wanting to get that done anyway. :)
http://stream.mikev.com/khb36.mp3
https://stream.mikev.com/khb36.mp3
Both HTTP and HTTPS are on the native ports (80 and 443), not alternates.
« Last Edit: August 26, 2018, 07:13:28 AM by mikev »
Offline ValentineWeather
« Reply #926 on: August 30, 2018, 01:50:03 PM »
If anyone wonders the The NOAA weather radio transmitters at Valentine, Mullen and Merriman will be down until further notice. This is due to a communications line outage. It is not known at this time how soon
the transmitters will be returned to service. #NEwx
NOAA Radio WXN82 : 162.450 MHz
Valentine, NE
Feed is still running because not sure when it's coming back. Over 4 hour outage so far.
Randy
Offline mikev
« Reply #927 on: August 30, 2018, 02:27:42 PM »
Manassas VA KHB36 is also down today, due to construction at the transmitter site. It will return Friday afternoon (8/31/18) at an unspecified time, according to the LWX forecast office public info statement. My stream is still up, though squelched due to no signal.
Offline Cutty Sark Sailor
  • Moderator
« Reply #928 on: August 30, 2018, 03:31:25 PM »
Man, it's the whole flippin' Midwest!
« Reply #929 on: August 30, 2018, 04:55:52 PM »
@NWSNorthPlatte
 6m minutes ago
NOAA weather radio transmitters at Valentine, Mullen, Merna, Bassett and Merriman will be down until further notice. This is due to a line outage. It is not known at this time when they will be returned to service.
Randy
Offline mikev
« Reply #930 on: August 31, 2018, 10:31:29 PM »
Manassas VA/KHB36 will now be down through Monday afternoon. Rather than stream silence, I'm going to take my stream down instead. Please don't remove me. :)
Also, Baltimore MD/KEC83 will be off-air from 11p 9/1 through 5a 9/2 for transmitter maintenance.
Edit to add: Actually, I came up with a more elegant solution instead. :) I created a text-to-speech MP3 containing the text of the public info statement from the NWS office, and it's just playing on repeat. I'm not sure they were thinking that Monday is a holiday though, when they did the statement... we'll see I guess!
« Last Edit: September 01, 2018, 07:12:19 AM by mikev »
Offline brandon86
« Reply #931 on: September 02, 2018, 12:14:31 PM »
Hey I have an idea, I'll if you want, record a message talking about the service outage, and so forth.  Remember if worse comes to worse that wng736 broadcasts for pretty much the same coverage area, except for some of the verginia counties.  So there is always an alternate transmitter in those situations.  But I can record a message that loops.
The offer is there if you want it.
If you do want me to do that let me know.
Offline SteveFitz1
    • Tyler Texas Weather
« Reply #932 on: September 06, 2018, 09:38:09 PM »
Are there currently issues with Noaa Weather Radio? When I load my WxRadio page, neither the radio controls or the map loads. It just says "Loading Map". I use Broadwave. I tried a friend of mine's site who also runs Broadwave and he has the same issue. So I tried loading the broadcast off the noaaweatherradio.org page and got an error "Source Not Found".
I found a couple of sites that did work, so I'm wondering if it's specific to those of us using Broadwave.
Is it just me or are others seeing this?
Steve
Offline 92merc
  • BismarckWeather.net
  • Moderator
« Reply #933 on: September 06, 2018, 10:16:17 PM »
In seeing the same thing.  I have a PI.  It's not the broadcast.  It's the player.  My phones and pc, different browsers.
Offline lddaly
« Reply #934 on: September 06, 2018, 10:18:08 PM »
We use wxradio.dyndns.org and the page does not load either. KEC56 162.400 is just broadcasting static at the moment anyway (tested on 2 other radios). We reported the KEC56 transmitter issue via http://www.nws.noaa.gov/nwr/outages/report.php. UPDATE: It is now listed as Out of Service.
« Last Edit: September 06, 2018, 10:42:17 PM by lddaly »
Offline NWROrg Team
  • Save A Life
  • Moderator
    • NOAA All Hazards Weather Radio
« Reply #935 on: September 07, 2018, 12:40:15 AM »
You folks using Ken's Saratoga scripts which interface with NWROrg main ....
The NWROrg host server underwent a major hardware and operating upgrade on Monday...
We had no options on the time or date this occurred.. We were 'told'... so, maxillary scripts will have to wait until their developers get free...  :roll:
the Main site, that updates all the Saratog Scripts, interfaces with QRA, etc, is now SSL. amd there are several script modifications being made.....and more in the auxillary scripts, such as your website scripts, and some of the admin suite scripts on site...
The main site... https://noaaweatherradio.org .. is in great shape... a couple of minor things to fixup, but she's working great so far even with the "Non-https" passive/display mixed content on a few pages, notably the non-https audio streams.,,, all that are 'active' are working as near as we can see right this moment... but a thorough check hasn't been made but ... checked a couple of Broadwave feeds, and yes, they're working as well as feeds from 'private' as well as WxRadioDynDns ... even though served as mixed content.. all this passive sourced only 'breaks' the 'secure' padlock on the site when accessed or loaded, but should pass through fine to all devices, except the scripts you're using will have to be modified, ...
The folks who furnish the Icecast servers, well,  it's up to them whether to go ssl or not...
FYI  NWROrg is certified through Comodo / Cpanel AutoSSL
« Last Edit: September 07, 2018, 12:52:56 AM by NWROrg Team »
  • Moderator
« Reply #936 on: September 07, 2018, 09:03:21 AM »
Did a quick look at Ken's WxRadios scripts...
I think this will get your website players back.. there may be some more, but haven't had time to look further:
NWR-radios-data.php
Add the "S" to the link in the following lines as shown:
Line 4
//Purpose: fetch and cache the https://noaaweatherradio.org/java/NWR-radio-data.js file
Line 37
  $fileName = "https://noaaweatherradio.org/java/NWR-radios-data.js";
Line 86
    $content = str_replace('https:\\/\\/noaaweatherradio.org\\/content\\/thumbnails\\/',$imagesDir,$content);
« Last Edit: September 07, 2018, 09:09:36 AM by Cutty Sark Sailor »
Offline mldenison
    • York, PA Weather
« Reply #937 on: September 07, 2018, 09:15:09 AM »
Good job!  Worked for me.
Windows 7 x64
Weather PC: Intel NUC
Davis Vantage Pro 2
Weather Underground: KPAYORK30
York, PA Weather (Saratoga)
York, PA Weather (Leuven)
York, PA PWS Station
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #938 on: September 07, 2018, 09:17:37 AM »
Same here.  Thanks, Cutty!
Regards, Jerry Wilkins
gwwilk@gmail.com
  • Moderator
« Reply #939 on: September 07, 2018, 09:36:20 AM »
couple of minor ones... and this may be all of 'em...
NWR-radios-inc.php are below:
So, the complete changes necessary, until I get more coffee anyway:
NWR-radios-data.php
Line 4
//Purpose: fetch and cache the https://noaaweatherradio.org/java/NWR-radio-data.js file  Line 37
Line 86
NWR-radios-inc.php
Line 165
These audio streams are graciously provided by personal weather website owners and others though <a href="https://noaaweatherradio.org/" target="_blank">NOAAWEATHERRADIO.org</a>.</p>
Line 183
see <a href="https://noaaweatherradio.org/" target="_blank">noaaweatherradio.org</a> website "How To?" page for details to submit an audio stream.
« Last Edit: September 07, 2018, 09:41:25 AM by Cutty Sark Sailor »
« Reply #940 on: September 07, 2018, 09:39:55 AM »
Thanks for the update.  I’ll do a release with the updates when my wife and I return from a Copenhagen to New York cruise on September 13th. We’re currently in Nanortalik, Greenland and the ship’s internet via satellite is very slow.
  • Moderator
« Reply #941 on: September 07, 2018, 09:45:34 AM »
Heh... enjoy.. relax... have fun... they scheduled this server upgrade just 'cause they new you were unavailable.  Fortunately we've got a few blind hogs rootin' for acorns, and once in awhile we get lucky... :twisted: Didja Kiss the Mermaid???
Offline mldenison
    • York, PA Weather
« Reply #942 on: September 07, 2018, 09:49:39 AM »
Uhoh.  Mine's working fine now.  But, I don't have a NWR-radios-inc.php.  What's up with that?
Windows 7 x64
Davis Vantage Pro 2
Offline tmabell
    • Mishawaka Weather
« Reply #943 on: September 07, 2018, 10:44:03 AM »
After the edits I'm getting a broken padlock due to the thumbnails icon being delivered over http. This occurs even with a secure stream. I'm still trying to nail down why.  I've tried changing the url's pointing to noaaweatherradio.org in NWR-radios-data.js to reflect https to no avail.
EDIT....I wonder if the file https://noaaweatherradio.org/java/NWR-radios-data.js needs to have some updates done as well? All thumbnail links in there point to http://noaaweatherradio.org,  lacking the https.
« Last Edit: September 07, 2018, 10:59:50 AM by tmabell »
  • Moderator
« Reply #944 on: September 07, 2018, 12:19:27 PM »
Couple of things going on here... I think... the standalone / saratoga script updates from a suite of scripts that run automatically... and should update anytime we make a station listing change on the main site... I don'[t remember how often they run with no manual updates entered... I think it might be hourly...
I did find one URL for one icon that I changed in one of the admin scripts... I'm a bit lost in there, so it may have to wait for KEN to return... I'm tracking another at the moment...
One other thing that will break a padlock, at least on main site, is clicking any audio stream that is NOT an ssl source... this stream would become 'passive' mixed content, and break the padlock...
i installed a noetification re "content" on the main page, last night, but have not yet added it any other site pages.. on the 'to do'...
Post here, WTom, if that resloves... I think I'm down to one png file floating possibly in one of the main site admin scripts...
arrrggghhh... Ken could find this in a picosecond... but us blind hogs... welll...   root, root.. there's gotta be an acorn somewhere...
Offline tmabell
    • Mishawaka Weather
« Reply #945 on: September 07, 2018, 12:33:57 PM »
I'll keep an eye on it but I can confirm that I was accessing a secure stream. I also noticed that my recent change involving my stream's url has yet to appear in that file. Whether that indicates a problem or not I can't say.  I'm in agreement with you that the best course of action is to let Ken wave his hand over his keyboard to magically fix it all in a heartbeat!
  • Moderator
« Reply #946 on: September 07, 2018, 01:03:24 PM »
I made the change many days ago on the main site..https://www.mymishawakaweather.com:8443/stream confirmed there...
Offline tmabell
    • Mishawaka Weather
« Reply #947 on: September 07, 2018, 03:51:44 PM »
Yes, I saw that you made the change right away. I just checked again and the page is secure now.  I'm not sure how everything works back and forth between systems but everything seems to work now
  • Moderator
« Reply #948 on: September 08, 2018, 03:58:48 AM »
Okay... this should fix the padlock on Ken's Saratoga Radio Script... if you caught the previous posts also... at least until a 'non-ssl' audio stream is selected.. that passive mixed content will break the padlock...
NWR-radios-inc.php
Line 55  "NatGeo"
Make the URL "https"
NatGeo' => array(
       'name' => 'NatGeo',
         'URL' =>'http://server.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer/tile/{z}/{y}/{x}',
I think that's the last...
 so summary up changes for the script Version 2.00 - 06-Aug-2018  currently provided by Ken,  which he'll re-qualify assuming he does return from some Nordic Fjord.
NWR-radios-data.php
Line 4
Line 86
NWR-radios-inc.php
Line 55  "NatGeo"
NatGeo' => array(
       'name' => 'NatGeo',
Line 165
Line 183
« Last Edit: September 08, 2018, 04:12:08 AM by Cutty Sark Sailor »
Offline tmabell
    • Mishawaka Weather
« Reply #949 on: September 08, 2018, 10:50:43 AM »
Good sleuthing Mike!  Thanks for that great catch!
