Author Topic: NOAA WEATHER RADIO  (Read 143130 times)
Re: NOAA WEATHER RADIO
« Reply #1125 on: December 12, 2019, 07:08:33 PM »
Sadly, no .. broadcastify switched to a rotating set of public URLs for streams just to prevent poaching of their streams.
Offline NWROrg Team
  • Save A Life
  • Moderator
    • NOAA All Hazards Weather Radio
« Reply #1126 on: December 12, 2019, 08:40:24 PM »
As stated by Ken, and previously by The Team.. ... these third party stream hosts don't appreciate using their bandwidth, expecially if they are revenue producing. It is certainly unfriendly to piggyback, a bit unethical, and may even be illegal in some instances. Stream hosting, site and server monitoring and maintainence is expensive, and we are very fortunate to have a donated IceCast host. otherwise we couldn't pull this project along... Doug C, Chris C, and Cutty provide most of the 'behind the scenes' server, domain and any licensing expense for some scripts, and media, and Ken, and others keep the site perking along with script updates etc....   and this is small potatoes compared to the Radio Reference Group (Broadcastify).
There is a simple solution.  Many encoders can stream to multiple servers.. multiple incidences of an encoder like BUTT can run, to several servers.. Some like SECaster can stream to multiple with one instance... many NWRORG stream providers point multiple streams... hardly notice it's going on.,.. we know one provider who has 6 running out of his cave, and who knows about Ken, Doug, many others... no biggie.
Offline chappelledpc
  • Moderator
    • Stonybrook South
« Reply #1127 on: December 12, 2019, 10:53:05 PM »
As mentioned in the previous post, I stream the three alternate Omaha, NE streams to different servers using an RTL SDR and DarkIce running on a Raspberry Pi 3.  The streams are:
http://wxradio.dyndns.org:8000/NOAA/KIH61.mp3 - Chris C’s server
http://audio9.broadcastify.com/xmhy7dv5ftj2.mp3 - Broadcastify
http://172.104.31.232:8000/NWROrgTestOmaha - Brandon’s server
The primary Omaha, NE stream is self-hosted using a Midland WR300 feeding a USB audio dongle on a Raspberry Pi 3.  It’s also running DarkIce and IceCast.    http://chappelleweather.com:8000/NOAA/KIH61.mp3
« Reply #1128 on: December 13, 2019, 12:53:10 PM »
Mine has a similar complexity for two radios:
Monterey (KEC49) audio from Midland 300 radio .. to 3 streams from Weather PC:
   local stream (http://saratogawx.dyndns.org:88/broadwave.mp3) via Broadwave
   wxradio:  (http://wxradio.dyndns.org:8000/KCASARATOGA/Saratoga.mp3) and Broadcastify via edcast
Monterey Marine (WWF64) is an RPi3 raspian/jessie RTL SDR with icecast/darkice and 3 streams:
   local stream:  http://saratogawx.dyndns.org:8001/Saratoga-WWF64.mp3
   wxradio: http://wxradio.dyndns.org:8000/Saratoga-WWF64.mp3 and broadcastify
Offline MchWxEnthusiast
  • That Guy
  • Nothing Much
« Reply #1129 on: December 14, 2019, 10:43:40 AM »
does the one for KEB98 stream exist?
Weather Radio Freq: 162.475 MHz
Weather Radio Loc:  Plainwell, MI
Transmitter Call Sign: WWF34
Streaming Status: NN
Offline Cutty Sark Sailor
  • Moderator
« Reply #1130 on: December 14, 2019, 12:17:00 PM »
Flagged currently as "Not Available"
Offline NWROrg Team
  • Save A Life
  • Moderator
Year End Station Audit
« Reply #1131 on: December 15, 2019, 12:44:30 PM »
Our "semi-annual' Listing cleanup:
Rather brutal, this time:  The following streams have been inaccessible >72 hours as of 11:AM EST12/15/20196.
These streams have been permanently REMOVED from the listing.
When you have resumed the stream,you MUST submit a NEW STREAM REPORT ( https://noaaweatherradio.org/addstream/addstream.html ) to be restored otherwise it WILL NOT be re-added.
**a few are "alternate" streams... If you aree a "primary" please chec your stream and the website if in doubt.
State     Call   City
AZ   WWF98   Prescott
CA   KEC57   Sacramento
DC   WNG736   Washington
FL   KEC86   Pensacola
GA   WXK56   Athens
GA   KEC80   Atlanta
GA   WXJ53   Cleveland
IA   KZZ52   Hancock
ID   WXK68   Boise
ID   WXK68   Boise
ID   WZ2520   Sun Valleyl
IL   KZZ55   Dixon
MO   KZZ37   Maryville
NC   WNG538   Linville
NC   KHB31   Winnabow
NE   WXN82   Valentine
ON   VBT629   Rosseau
OR   WNG674   Florence
TN   WNG554   Winchester
TX   WXK30   College Station
« Last Edit: December 15, 2019, 12:53:02 PM by NWROrg Team »
« Reply #1132 on: December 22, 2019, 04:17:48 PM »
For something different, while related, here is a photo of the tower site for the transmitter of the Stillwater, OK  NOAA station transmitter, 162.500 MHz.  It's about 3/4 of a mile east of the city limits near the Payne County Fairgrounds.  Power is 1000 watts.  It's located nearly in the center of the county, so serves the county well.  County population is a bit over 80,000.
« Last Edit: December 24, 2019, 12:20:32 PM by Bunty »
Offline NWROrg Team
  • Save A Life
  • Moderator
« Reply #1133 on: December 24, 2019, 09:44:15 AM »
Season's Greetings!
We might have had this ready in time for the Chubby Chimney Sweep's arrival, but it hasn't quite worked out...
... but we'll give you 'shareholders' in the NWROrg community a look at an alternate page we're considering.
https://noaaweatherradio.org/wxradio-3/radios.php
Play a bit, and check it on your various devices and browers and give your thoughts...
Yes, the "Adjunct/Auxillary" streams do NOT display a 'coverage map' . and a feew other smaller things...
This is built upon the NWROrg site script suite V3 developed by Doug, Ken, et all...for stand-alone, or Saratoga Templtes...
Offline n2jtx
    • My Website
« Reply #1134 on: December 24, 2019, 12:49:11 PM »
It is quite annoying as KWO35 in New York City is back on the air from the Empire State Building. They are in test mode running low power at the moment and the coverage where I am, even with an outdoor antenna, is fuzzy. However, someone much closer to the station is feeding them on Broadcastify at https://www.broadcastify.com/listen/feed/25412/web. The audio is crystal clear, much better than what I receive OTA, but unfortunately it suffers from the rotating URL's. Unrelated, I did notice there is a 70 second time lag between the broadcast and the stream.
« Last Edit: December 24, 2019, 08:08:18 PM by n2jtx »
Offline ValentineWeather
    • LiVE WEATHER
Re: Year End Station Audit
« Reply #1135 on: December 24, 2019, 04:10:32 PM »
State     Call   City
AZ   WWF98   Prescott
CA   KEC57   Sacramento
FL   KEC86   Pensacola
GA   WXK56   Athens
GA   KEC80   Atlanta
GA   WXJ53   Cleveland
IA   KZZ52   Hancock
ID   WXK68   Boise
ID   WXK68   Boise
IL   KZZ55   Dixon
MO   KZZ37   Maryville
NC   WNG538   Linville
NC   KHB31   Winnabow
NE   WXN82   Valentine
ON   VBT629   Rosseau
OR   WNG674   Florence
North Platte has officially said 5-6 weeks so puts it after Jan before the tower is repaired.
NE   Valentine   162.450   North Platte, NE   WXN82   OUT OF SERVICE
Randy
Offline dupreezd
« Reply #1136 on: December 24, 2019, 05:46:17 PM »
Season Greetings
Good job on the Alternate page, I like it.
Plusses are.
  • SAME codes for your area.
  • Propagation.
  • Alerting Area.
Dries
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
Offline dupreezd
« Reply #1137 on: January 11, 2020, 07:24:46 AM »
Now this is a very impressive peak listeners total. Most probably last night storm.
CWOP - FW0717
Blitzortung 2100
Offline lddaly
« Reply #1138 on: January 11, 2020, 09:36:38 AM »
Receiving nothing but static from the KEC56 NWR transmitter this morning.  #-o I reported the outage last night.
Offline colonieweather
    • Colonie Weather Online
« Reply #1139 on: February 09, 2020, 10:48:10 AM »
Sorry if this has come up in this section of forum already, but has there been talk of adding an SSL certificate to the wxradio.dyndns.org domain?  Getting mixed content notification in browser where link to my stream is on my site.  Not a big deal, just curious.
-Chris
Davis Vantage Pro 2 Plus
WeatherLink v6.0.5
colonieweatheronline.com
Wx Underground - KNYCOLON3
APRS/CWOP - EW0288
Offline NWROrg Team
  • Save A Life
  • Moderator
« Reply #1140 on: February 09, 2020, 12:25:54 PM »
-Chris
Yes, but only to the point where we recognized that the Icecast server is an expensive donation from Crushed Box Software, who is kind enough to bear all the expense and registrations.  The Main website page uses an onload floater disclaimer re: mixed content. [ You are not allowed to view attachments ]
Offline NWROrg Team
  • Save A Life
  • Moderator
QRA feature
« Reply #1141 on: February 10, 2020, 07:09:08 AM »
While we DO NOT monitor stream connections and listener traffic for many reasons,
Doug has added a 'snapshot' to the main QRA web access page, for those who
use our primary IceCast server.  Others are 'out of luck'..
IF you provide a NOAA All Hazards Weather Radio stream,
IF you use the NWROrg IceCast Server WxRadio.DynDns
and
IF you are subscribed to
Web Access QRA Data
QRA Monitoring Tools -- Secure link sent via Email
"Stream Started":  Last periodic IceCast Reset
or, Last stream reconnect after an 'offline'
« Last Edit: February 10, 2020, 05:51:51 PM by NWROrg Team »
« Reply #1142 on: February 21, 2020, 02:14:04 PM »
What happened? It seems the entire network is down.  From what I can tell it's not on my side.
Offline 92merc
  • BismarckWeather.net
  • Moderator
« Reply #1143 on: February 21, 2020, 02:31:23 PM »
What's not working?  My stream is still up and running.
  • Moderator
    • Stonybrook South
« Reply #1144 on: February 21, 2020, 02:43:53 PM »
Same for me.  I can't seem to find anything that's not working.
Offline tmabell
    • Mishawaka Weather
« Reply #1145 on: February 21, 2020, 02:45:17 PM »
It seems that mine is still up but I host my own.  I do not go through the Icecast server.  I spot-checked and found Indianapolis not working.
Offline SteveFitz1
    • Tyler Texas Weather
« Reply #1146 on: February 21, 2020, 04:36:04 PM »
It may be the script on your site that's not working. I can access your NOAA station (as well as others) from the script on the my site: https://www.tylertexasweather.com/wxradio.htm
Steve
« Reply #1147 on: February 21, 2020, 04:57:58 PM »
Sorry, I spoke up too soon.  Everything is now working here.
Offline tmabell
    • Mishawaka Weather
« Reply #1148 on: February 22, 2020, 08:48:36 AM »
This issue seems to be transient in a way.  After some checking and comparing browsers I have found something interesting.  Using the latest iteration of Chrome (mine is: Version 80.0.3987.116) results in many streams not loading.  Using Edge as Firefox they all work as they should.  At first guess, Chrome is the culprit.  Unfortunately, this isn't the first or the last time that Chrome updates cause problems.
Offline SteveFitz1
« Reply #1149 on: February 22, 2020, 09:01:45 AM »
I can confirm there is an issue with Chrome. I loaded my WxRadio page on Chrome on my desktop just now and it worked fine. That was with version 79.0.3945.130. I then updated Chrome to 80.0.3987.116 and now I get 'Failed to Load Audio Stream'.
Steve
