Author Topic: Dayfile  (Read 1274 times)
Offline Guillaume_67370
    • METEO OFFENHEIM
Dayfile
« on: October 17, 2016, 05:34:10 PM »
Hello,
I noticed a problem with my Dayfile.txt
Data are no more in the right column
What can I do ?
Find attached
On the other side on my file of September when i will have a look into Cumulus dat from 17 of September to end of September aren't in the table and if i have a look under my PC C;/Cumulus/data/Septe2016.txt all data are in the fle
I try to close and open again Cumulus but no correction ???
Thanks for your help
    • METEO OFFENHEIM
Re: Dayfile
« Reply #1 on: October 17, 2016, 06:05:05 PM »
When i go into edit-> dayfil.txt it work correctly on the right column but when i go into view data logs->load -> dayfile.txt, it doesn't work ????
Offline PaulMy
Re: Dayfile
« Reply #2 on: October 17, 2016, 06:14:28 PM »
It looks like you were trying to open dayfile.txt in the View tab data log feature which is for the monthly log files.  As that view screen indicates: This viewer is not suitable for dayfile.txt.  Use the dayfile.txt editor instead (in the Edit tab)
« Last Edit: October 17, 2016, 06:20:41 PM by PaulMy »
    • METEO OFFENHEIM
Re: Dayfile
« Reply #3 on: October 17, 2016, 06:22:00 PM »
It looks like you were trying to open dayfile.txt in the View tab data log feature which is for the monthly log files.  As that view screen indicates: This viewer is not suitable for dayfile,txt.  Use the dayfile.txt editor instead (in the (Edit tab)
Thanks for your quick reply Paul !!!
And about my file of September what do you mean ?
Into Cumulus i can only see data until 16/09 23:13 (find attached) and when i go on file sept2016log.txt under my computer it goes until end of September...
Offline PaulMy
Re: Dayfile
« Reply #4 on: October 17, 2016, 06:40:57 PM »
I notice that your September log appears to be as Sept16log.txt where usually the Cumulus log files are like Sep16log.txt (only 3 letters of the month name).  Is it possible you have an extra/temporary Sep log file?  Are the other months' log files the same issue?
    • METEO OFFENHEIM
Re: Dayfile
« Reply #5 on: October 18, 2016, 12:25:50 AM »
Problem solved !!
It was a blank line on my file on 16-09 after 23:13
« Last Edit: October 18, 2016, 12:35:37 AM by Guillaume_67370 »
Offline PaulMy
Re: Dayfile
« Reply #6 on: October 18, 2016, 10:00:09 AM »
Glad you got it fixed.
Enjoy,
