Author Topic: Fall 2016  (Read 21193 times)
Offline WeatherHost
Re: Fall 2016
« Reply #100 on: October 22, 2016, 07:27:31 PM »
89 on the 19th
62 on the 21st
Must be October.
ICDHost, Webhosting:  https://www.icdsoft.com/c/webhost
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: Fall 2016
« Reply #101 on: October 22, 2016, 07:39:20 PM »
The night minimums here currently are around freezing point, it gets relatively cold after sunset, during the day it is around 10 (50F). I wonder if we get any snow this winter at all... last few winters we had practically nothing, it did snow but it never stayed on ground for too long, usually a few days at most.
Historically how much snow do you usually get?
I mentioned this in the other forum about climate change as well...
It really depends, at higher elevations in the mountains there is already plenty of snow now (about 2 inches).
I live in one of the lowest and warmest parts of the country and in addition in the second largest city, with significant heat island effect. Nevertheless, we do get snow regularly. However, when I was "young" (I mean like 10, so about 20yrs ago) we had snow for like 1-2 months straight and went sledging often. These days.... as I said previously, since I guess 2000 at least, there is maybe a few days with some very little snow on ground, but hardly anything. And it usually melts very quickly. In 2012 we had quite cold span, but it was also an anomaly... the winter was very warm and then suddenly in the mid February, it got extremely cold (well below freezing point, there was even a week when the daily maxium did not get over -10C) and that lasted even to beginning of March, but there was not much precipitation, so also no snow.
Offline corwyyn
  • Far, far east Mesa, AZ
    • Sleeping Saguaros Weather  Mesa, AZ
Re: Fall 2016
« Reply #102 on: October 22, 2016, 08:25:55 PM »
99.8 at 1:58pm, humidity in the 20% range.  Forecast shows a chance of showers the next couple of days so hopefully it will cool down.
Sent from my Nexus 6 using Tapatalk
Kevin
AD5VG
Blitzortung station 1042
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #103 on: October 22, 2016, 08:48:35 PM »
Thats more than our absolute maximum this year :D
Offline Scalphunter
Re: Fall 2016
« Reply #104 on: October 25, 2016, 01:25:43 PM »
Having an heat wave here. Woke up this morning and it was 11 degrees. Wind over night kept the temps up above the zero mark.
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #105 on: October 25, 2016, 01:58:24 PM »
C or F?
Offline ValentineWeather
    • LiVE WEATHER
Re: Fall 2016
« Reply #106 on: October 25, 2016, 02:12:16 PM »
C or F?
We still use the German physicist inventor of the mercury thermometer who also devised the temperature scale bearing his name.  Fahrenheit
Randy
Offline SLOweather
    • http://www.sloweather.com
Re: Fall 2016
« Reply #107 on: October 25, 2016, 02:37:16 PM »
Hey, since the metric crowd changed Celsius to Centigrade, maybe we should start referring to Fahrenheit as Fartigrade. ;)
C or F?
Offline Scalphunter
Re: Fall 2016
« Reply #108 on: October 25, 2016, 04:19:26 PM »
If I use C or Centigrade there be a lot of minus numbers now till spring.
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #109 on: October 25, 2016, 04:27:04 PM »
 :lol: :lol: :lol:
C or F?
Offline Scalphunter
Re: Fall 2016
« Reply #110 on: October 28, 2016, 01:33:02 PM »
Morning, well we finally got into the minus side of the temps column.  Minus 5 this morning under clear skies. Did have an brief warm up for couple days as downs lope winds brought warmer temps from compression.  Looking ahead in the forecast it looks like we are in another cool down cycle.  By the way Jac that -5 F.
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #111 on: October 28, 2016, 01:35:30 PM »
LOL, yeah, last time I checked the climate normals for your place so I sort of figured it out now :D
Btw... almost zero this night here too :D
0 C :D
    • LiVE WEATHER
Re: Fall 2016
« Reply #112 on: October 28, 2016, 03:13:25 PM »
Since our early October snow its been above normal here only 4 freezes this month. All that cold air is pooling well north and eventually start sliding south. Can't wait come on winter.....
Randy
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #113 on: October 28, 2016, 03:25:49 PM »
LOL, so looks like Im not the only one who likes cold, dark, windy :D
Re: Fall 2016
« Reply #114 on: October 28, 2016, 05:15:07 PM »
21 of the last 22 days over 90F. This may go down as our hottest Oct. on record.
Offline Scalphunter
Re: Fall 2016
« Reply #115 on: October 28, 2016, 08:06:19 PM »
The big push may well be in the bering as I write this . 966 mb and dropping. 75 knot winds for casted for Gambel and other areas. All that warm air will push this cold somewhere south.
« Last Edit: October 29, 2016, 01:37:04 PM by Scalphunter »
Offline WeatherHost
Re: Fall 2016
« Reply #116 on: October 28, 2016, 08:32:40 PM »
I maintain that seasons are shifting.  Warmer later into Fall, but cooler later into Spring.  October is the new September.
Re: Fall 2016
« Reply #117 on: October 30, 2016, 06:45:50 PM »
60's next week.  Halloween high of 61.
We have not hit 32 yet. May be one of the latest 32 on record
NWS Twin Cities ‏@NWSTwinCities  1h1 hour ago
Latest date Twin Cities has seen 32 or colder was 11/7/1900. Forecast through next week suggests this year may eclipse that mark.
Re: Fall 2016
« Reply #118 on: October 31, 2016, 03:44:05 PM »
It's official, hottest October on record for Tucson, and I'm sure plenty others too.
    • LiVE WEATHER
Re: Fall 2016
« Reply #119 on: October 31, 2016, 05:57:02 PM »
That is surprising.
Randy
Offline WeatherHost
Re: Fall 2016
« Reply #120 on: November 01, 2016, 11:04:30 AM »
Over 70 already this morning, though it feels quite a bit warmer.
Have only seen a few wooley worms so far, but they're taking on their normal colors.  The ones I've seen so far are black at both ends, brown in between with no banding.
Hearing rumors of a big chill by mid-month, maybe flipping to below or well below normal.
Re: Fall 2016
« Reply #121 on: November 02, 2016, 10:34:35 PM »
I was outside today in a short sleeved shirt. Walking around because I did not want to go inside.
60's all week Well above average.
November expected to be warm
Re: Fall 2016
« Reply #122 on: November 06, 2016, 02:09:17 PM »
First freeze of the season here hasn't happened and long range it still won't happen through Nov. 20.  Nov. 2 was the last day with high in the 80s, very near record.  But a TV weatherman said he expects no more 80s for the rest of the year.
« Last Edit: November 06, 2016, 02:10:50 PM by Bunty »
Also the 2nd home page using modified AltDashboard 6.95 at http://stillwaterweather.com/wx/2ndhome.php
    • LiVE WEATHER
Re: Fall 2016
« Reply #123 on: November 06, 2016, 02:46:42 PM »
Where does he get the long range? Found this computer model for comparison. http://www.weathertab.com/en/g/united-states/oklahoma/74074-stillwater/
Randy
Offline Jáchym
    • Meteotemplate
Re: Fall 2016
« Reply #124 on: November 06, 2016, 03:10:24 PM »
The weather here currently more or less what you would expect at this time of the day - mostly cloudy/overcast, today raining most of the day, daily max around 10 C (50F) and at night around freezing point.
Next week however a cold front is expected to arrive on Tuesday and temperatures dropping significantly below the average, at night as low as -8 C (17F), and snow even at the lowest elevations, which is rather unusual. We normally dont have temperatures too much below freezing point in the first half of Nov.
