Author Topic: Weather34 template(non meteobridge versions)  (Read 89399 times)
Offline MatteoPV
Re: Weather34 template(non meteobridge versions)
« Reply #700 on: July 06, 2019, 03:58:35 AM »
I uploaded the new template and the final result is exceptional !!! Both the PC and smartphone viewing is excellent !!!! There is the small translation bug of the month, but it's just a question of translation. I had noticed that leaving the computer on the template started, the green writing with the time of data update went off line after about 8 minutes and then went back green and with the update time after the 10 minutes I had set as an update. I solved by adjusting the wifilogger with a 5 minute update interval. I come up with a fantastic template, an excellent job.
Here's how it looks:
www.meteocamporamoso.it
It all seems to me to be properly regulated
Offline MatteoPV
« Reply #701 on: July 13, 2019, 01:08:18 PM »
Do I notice that there is an update to the template online?
Offline wvdkuil
  • Wim van der kuil
« Reply #702 on: July 13, 2019, 01:13:27 PM »
Yes, some minor adjustments at http://wd34.weather-template.com/
The list of updates is here: http://wd34.weather-template.com/updates_WD07.pdf
The topic you are now posting in, is for weather34/ templates.
The HWS-WD34 template only looks similar, but it is totally different in the internals.
Less confusion and your questions will be answered quicker if you post them => in this topic
Wim
« Last Edit: July 13, 2019, 01:19:36 PM by wvdkuil »
Support for Leuven-Template & Scripts  at this forum
Support for the PWS_Dashboard (HWS-template) for WD a.o.  https://pwsdashboard.com/
Script sponsors https://support.leuven-template.eu/userlistScripts.php
Template sponsors https://support.leuven-template.eu/userlist.php
Offline MatteoPV
« Reply #703 on: July 13, 2019, 01:29:32 PM »
Meanwhile, gracious as always, for the moment I won't update.
I wanted to ask you two things. Want to add to my Davis the UV sensor and the solar radiation sensor, this then got well from this template ????
I note that let template can have information on air quality. I registered on the site indicated, but then how does it indicate the quality of the air in my area?
Offline wvdkuil
  • Wim van der kuil
« Reply #704 on: July 13, 2019, 02:00:02 PM »
The realtime.txt has fields for the UV and the solar values.
You can specify  in easyweathersetup that you have your own UV/Solar and the template will use those values.
The nearest official station will be used if het has an open interface.  https://aqicn.org/ loads that data from all open official AQ stations and the scripts will get their data from  aqicn.org
You can check on their site which stations are near you, such as Milan => http://aqicn.org/here/
Wim
Offline MatteoPV
« Reply #705 on: July 14, 2019, 03:01:32 AM »
Thanks for the information. Known in the template demo that UV and solar radiation have no graph. Will they be implemented? The soil evaporation data will also be implemented ???
Offline wvdkuil
  • Wim van der kuil
« Reply #706 on: July 14, 2019, 05:03:55 AM »
@MatteoPV
Questa discussione in cui stai postando le tue domande è per weather34 / templates.
Il modello HWS-WD34 sembra solo simile, ma è completamente diverso all'interno.
Ci sarà meno confusione per te e per gli altri lettori e le tue domande riceveranno una risposta più rapida se pubblichi i tuoi messaggi in questa discussione sul forum  https://www.weather-watch.com/smf/index.php/topic=68132.new#new
@ALL
This discussion where you are now posting your questions, is for weather34/ templates.
The HWS-WD34 template only looks similar, but it is totally different on the inside.
There will be less confusion for you and other readers and your questions will be answered quicker if you post your messages  in this forum-discussion  https://www.weather-watch.com/smf/index.php/topic=68132.new#new
Wim
Offline MatteoPV
« Reply #707 on: July 15, 2019, 02:49:25 AM »
do I have to change templates?
Offline wvdkuil
  • Wim van der kuil
« Reply #708 on: July 15, 2019, 02:54:21 AM »
NO, You are using my template, HWS-WD34  which supports wifilogger
Support for the HWS-WD34 template is on another forum  https://www.weather-watch.com/smf/index.php/topic=68132.new#new
This topic is for the original weather34 templates who do not support wifilogger at this moment.
Wim
Offline MatteoPV
« Reply #709 on: July 15, 2019, 05:43:12 AM »
Ah ok, thanks
Offline wvdkuil
  • Wim van der kuil
Re: PWS_Dashboard template
« Reply #710 on: September 02, 2019, 10:16:56 AM »
. . . shortend . . .
Anyone have the latest Weather Display and Weather Flow versions?
Yes,  I started supporting WD in January.
There is currently a PWS_Dashboard which  supports WeatherDisplay-API, generic clientraw, generic realtime.txt ( Cumulus a.o.), WeatherUnderground-API, Weatherlink.com-v2 API, the old Meteobridge-realtime format.
And in Beta now also WeatherFlow-API with full history. Screenshot:
Demo WeatherFlow version: https://pwsdashboard.com/pwsWD/
Demo WeatherDisplay version: http://pwsdashboard.weather-template.com/pws07/
IMPORTANT: Although the PWS-Dashboard looks similar, this version is a complete rewrite
and
therefor not code-compatible with the  w e a t h e r 34/ versions.
Current version readme and support information at: https://pwsdashboard.weather-template.com/
WeatherFlow owners willing to beta-test the dashboard, please drop me an e-mail.
Wim
« Last Edit: September 02, 2019, 10:21:57 AM by wvdkuil »
