Author Topic: Weather34 template(non meteobridge versions)  (Read 75030 times)
Offline eddiegonzales
    • Weather in Felsted
Re: HOMEWEATHERSTATION Dashboard template
« Reply #675 on: April 19, 2019, 05:44:58 AM »
Hi guys
Great work!
I have noticed that even there has been a few updates. This parts keeps on being in Dutch rather than English
Please see attached picture
Offline wvdkuil
  • Wim van der kuil
« Reply #676 on: April 19, 2019, 07:06:28 AM »
. . . shortened . . .
 This parts keeps on being in Dutch rather than English. Please see attached picture
That part comes from the 1 hour forecast by DakrSky.
There is s separate selection for the DarkSky forecast language. It still seems to be Dutch in your case.
If you set that to the same language as your main language (English) , the texts will be in English.
After changing the setting in easyweathersetup.php you have to wait for the cache to be replaced. Max 1 hour.
Wim
Support for Leuven-Template & Scripts  at this forum
Support for the HWS-WD34-template for WD a.o.  http://wd34.weather-template.com/
Script sponsors https://support.leuven-template.eu/userlistScripts.php
Template sponsors https://support.leuven-template.eu/userlist.php
« Reply #677 on: April 20, 2019, 04:06:44 AM »
Hi Wim,
Thanks. I have changed the settings to match the dashboard language (english) but after many hours, the language is still Dutch, and i have also cleared the browser cache to be sure. But without luck :-)
BR
Stephan
Offline wvdkuil
  • Wim van der kuil
« Reply #678 on: April 20, 2019, 04:38:53 AM »
Hi Wim,
BR
Stephan
In your easyweather-settings you selected to use DarkSky for your forecast and for your current conditions.
But you forgot to request/enter a DarkSky API-key, and therefor the scripts can not load the forecast and will reuse the demo file (which is in Dutch)
You can always check which files are loaded and which not with https://www.valkaer.dk/w34_load_files.php?test
w34_load_files.php (59) METAR not loaded API=ADD YOUR API KEY
w34_load_files.php (69) DARKSKY not loaded API=ADD YOUR API KEY
w34_load_files.php (236) File not old enough (753/1800 seconds)https://api.weather.com/v3/wx/forecast/daily/5day?geocode=54.98,9.51&format=json&units=s&language=en-EN&apiKey=_API_SETTING_
w34_load_files.php (99) Environement Canada not use
w34_load_files.php (236) File not old enough (752/1800 seconds)https://earthquake-report.com/feeds/recent-eq?json
w34_load_files.php (236) File not old enough (152/300 seconds)https://services.swpc.noaa.gov/products/geospace/planetary-k-index-dst.json
w34_load_files.php (121) luftdaten sensor not defined
w34_load_files.php (129) purplair sensor not defined
w34_load_files.php (139) goverment aqi not defined
w34_load_files.php (236) File not old enough (1390/1800 seconds)https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=ISYDDANM23&day&month&year&graphspan=day&format=1&units=scandinavia
w34_load_files.php (236) File not old enough (9152/28800 seconds)https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=ISYDDANM23&graphspan=month&year=year&month=month&format=1&units=scandinavia
w34_load_files.php (236) File not old enough (28951/43200 seconds)https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=ISYDDANM23&graphspan=year&year=&format=1&units=scandinavia
If you request (there is a link for that in the line where you enter that key) and then add that key it will work.
Wim
« Reply #679 on: April 20, 2019, 05:03:53 AM »
Hi Wim,
Thanks. Now it works. I wouldn't have guessed that the Dark Sky would matter since i didn't "Activated" it. But now i have put in the key from Dark Sky that i have requested.
BR
Stephan
Offline nitrx
    • Apeldoorn-Oost The Netherlands
« Reply #680 on: April 20, 2019, 05:10:56 AM »
Is the a way to display lightningstrikes and distance from the WeatherFlow (if there are any ), I use realtime.txt and the station ID from weatherflow. http://apeldoornmeteo.nl/wd (I dont use weatherdisplay )
Ron
Cumulus software
Apeldoorn NL
http://www.apeldoornmeteo.nl
several languages
Offline wvdkuil
  • Wim van der kuil
« Reply #681 on: April 20, 2019, 05:34:13 AM »
Will be included in the July release, more or less the same as the Boltek block.
Wim
Offline nitrx
« Reply #682 on: April 20, 2019, 05:57:16 AM »
Great looking foward  [tup]
Ron
Cumulus software
Apeldoorn NL
several languages
Offline mkutche
    • GosportWx.com
Re: Weather34 template(non meteobridge versions)
« Reply #683 on: May 25, 2019, 07:01:56 PM »
I just noticed this is not picking up any data see screenshot. http://www.gosportwx.com/PWS/
Mike K.
WS2080 - Cumulus MX b3043
Gosport, Indiana
Gosportwx.com Gosportwx.com/PWS/ Gosportwx.com/j-template/ twitter.com/GosportINWX facebook.com/GosportINWX
Offline PaulMy
« Reply #684 on: May 25, 2019, 07:39:26 PM »
This is a WU issue as discussed here http://www.wxforum.net/index.php?topic=36954.25
Enjoy,
Komoka, ON  Canada
Offline mkutche
    • GosportWx.com
« Reply #685 on: May 25, 2019, 07:53:37 PM »
Enjoy,
ok so how do i fix it? because WU seems to be working on my end. just now the graphs
Mike K.
Gosport, Indiana
« Reply #686 on: May 25, 2019, 08:30:57 PM »
I did a push to the GitHub distribution of CU-HWS a few days ago that fixes the graph displays.
The changed scripts are:
index.php
jsondata/wuupdate.php
and new scripts added
chartswu/weekly*.php
If you installed via git clone, then just do a git pull to get the updates, otherwise, download the zip and extract all the 20-May-2019 changed files.
Offline mkutche
    • GosportWx.com
« Reply #687 on: May 25, 2019, 10:15:05 PM »
index.php
Thanks Ken! Been outta town and was like :O stuff wasn't working lolol
Disregard that last post i deleted it .. i had it set to metric instead of nonmetric. :P
« Last Edit: May 25, 2019, 10:45:22 PM by mkutche »
Mike K.
Gosport, Indiana
Offline MatteoPV
« Reply #688 on: July 05, 2019, 05:41:06 AM »
Do any of you have problems with the date shown at the top left ??? The site shows me the correct time but as a date it is back a month. Do you know how I can solve ???
Here is the link to my site, so you can check:
www.meteocamporamoso.it
Offline wvdkuil
  • Wim van der kuil
« Reply #689 on: July 05, 2019, 07:19:29 AM »
https://www.meteocamporamoso.it/pwsWD/index.php?lang=it  => shows Ven 5 Gui  => which is June =>which is incorrect
But https://www.meteocamporamoso.it/pwsWD/index.php?lang=en  => shows Fri 5 Jul  => which is July =>which is correct
Better check your language files carefully. The Italian person who made it switched the month June and July
# months
                             |Apr |Apr |
                             |Aug |Ago |
                             |Dec |Dic |
                             |Feb |Feb |
                             |Jan |Gen |
                             |Jul |Giu |
                             |Jun |Lug |
                             |Mar |Mar |
                             |May |Mag |
                             |Nov |Nov |
                             |Oct |Ott |
                             |Sep |Set |
Wim
edit as OP changed the links to the site
« Last Edit: July 05, 2019, 09:17:42 AM by wvdkuil »
Offline MatteoPV
« Reply #690 on: July 05, 2019, 09:11:49 AM »
I no longer made updates to the site, until recently it was fine. Then he went on to indicate 'off line' in the boxes whose info derive from my Davis and the date is strange. I made no changes. I tried to evaluate other languages ​​but the date is still incorrect as well as the update info remain on off line even if it is not so. I checked the wifilogger, the time and date are correct, every day I restart the wifilogger
Offline wvdkuil
  • Wim van der kuil
« Reply #691 on: July 05, 2019, 09:26:21 AM »
Yes the dates were fine for all languages up to May as most month names are translated correctly
But for June and July the Italian translations are in error or they are switched.
Please check https://www.meteocamporamoso.it/pwsWD/languages/lang_it.txt  lines 8 & 9
     |Jul |Giu |      <=  this is for July in English, but the Italian translation is incorrect
     |Jun |Lug |    <=  this is for June in English, but the Italian translation is incorrect
That should be
     |Jul |Lug |
     |Jun |Giu |
Really that is all, change 2 lines
Wim
Offline wvdkuil
  • Wim van der kuil
« Reply #692 on: July 05, 2019, 09:55:41 AM »
. . . shortened . . . Then he went on to indicate 'off line' in the boxes whose info derive from my Davis
. . . I made no changes.
. . . as well as the update info remain on off line even if it is not so.
I do not think that you are using Cumulus as weather-program. Probably you are using the  WifiLogger and its realtime.txt
Those files are not 100% compatible, so please switch to the latest version at http://wd34.weather-template.com/
The latest version is fully compatible with WiFilogger: check this user: http://184.66.2.246/weather34WD/index.php
It has also a setting for your date format which is M/D/Y and not D/M/Y as it should be according to the definitions for realtime.txt with Cumulus here: https://cumuluswiki.wxforum.net/a/Realtime.txt =>
Field # 1   Example  19/08/09   Description Date as 2 figure day [separator] 2 figure month [separator] 2 figure year
But your upload at https://www.meteocamporamoso.it/pwsWD/demodata/realtime.txt =>
07/05/19 15:30:05 32 42 17.3 4.3 4.8 271 0.00 0.00 1015.5 W 1 km/h C mb mm --- --- 2.60 141.40 . . . 00 0 0 0 0 0 0 0 0 0 0 It is now the 5th of July  But the scripts think your data is from the 7th of May.
Wim
« Last Edit: July 05, 2019, 10:01:39 AM by wvdkuil »
Offline MatteoPV
« Reply #693 on: July 05, 2019, 11:19:43 AM »
I downloaded the latest version but I wouldn't want to redo all the settings ???? Can I save the easyweathersetup.php file and put it in the new version?
Offline wvdkuil
  • Wim van der kuil
« Reply #694 on: July 05, 2019, 11:39:15 AM »
Yes, BUT !
Yes: You can copy the w34_settings1.php from the old to the new folder
But:
  • do not start the template
  • First run easyweather (with the old password)  and check the  "blue" coloured answers, those were not in the old file
  • Especially make sure that the date format of realtime.txt is set as the same as the dates in your realtime.txt  are not Day/Month/Year  but Month/Day/Year
Wim
« Last Edit: July 05, 2019, 11:46:13 AM by wvdkuil »
Offline MatteoPV
« Reply #695 on: July 05, 2019, 11:47:24 AM »
I thought of deleting all the files of the old site, then uploading those of the new one and then replacing the only w34_settings1.php file that I will have previously saved. Then I perform the procedure you described to me. I believe the basic password will always be the same
Offline wvdkuil
  • Wim van der kuil
« Reply #696 on: July 05, 2019, 12:05:12 PM »
That will work also, but you loose all past data.
Easier, just rename the old folder pwsWD to pwsOLD and upload the new pwsWD folder.
Remember also: when you copy w34_settings1.php you need to use your old password as it is contained in that script. The 12345 first-use password will not work
Wim
Offline MatteoPV
« Reply #697 on: July 05, 2019, 12:12:37 PM »
I do not understand ........ once renamed the folder, all the old part what is it ????
I have a question, if once I have uploaded the new site, the not yet fully regulated, someone runs it, what happens?
Offline MatteoPV
« Reply #698 on: July 05, 2019, 12:25:43 PM »
I think I understand what you mean. Rename the current site folder as you told me then load the new one. At this point I could open two windows of the old and new easyweathersetup files ........ at this point I can do the configuration of the new one from scratch, I copy paste the settings of before and then I adjust the new options
Offline wvdkuil
  • Wim van der kuil
« Reply #699 on: July 05, 2019, 12:27:41 PM »
[tup]
