Author Topic: Meteotemplate cron job for Cumulus realtime.txt  (Read 1500 times)
Offline stefanbagnato
« on: June 29, 2016, 03:07:54 PM »
Hi All,
I am working on a getting the cron job for the data update from CumulusMX to Meteotemplate working.  Currently, the realtime.txt file is in C:\CumulusMX.  So, in the cumulus.php file in meteotemplate's update folder, I list the relative path as C:\CumulusMX\realtime.txt.  When I run the script/cron job, it throws an error:
Latest DB record timestamp detected: 1969-12-31 19:00:00
Latest cached timestamp detected: 1969-12-31 19:00:00
Smallest interval between uploads to database set to: 60 seconds.
Difference between latest db timestamp and cached timestamp: 0 seconds.
The difference between last db update and current data is not yet larger than the set interval. Current data is saved into temporary cache.
I went into myPHPAdmin and created a fake line of data.  When I reran the script, I get:
Latest DB record timestamp detected: 2016-06-28 20:40:00
Smallest interval between uploads to database set to: 300 seconds.
Difference between latest db timestamp and cached timestamp: -1467160800 seconds.
So, it knows there is something in the database, but still can't write anything anywhere including to the cache.  Next, I copied the latest realtime.txt into \wwwroot\update and set the path in cumulus.php to "realtime.txt".  I reran the script again, and it worked.
So, my question is, barring a permissions issue (my account has full access to C:\CumulusMX so I wouldn't think it would be..), what else might be the problem with my setup?
FYI, my station is a VP2, and I am using Server 2012 R2 with IIS on my personal server.
