Author Topic: Any participants with RED connected to a wifi client?  (Read 1791 times)
Offline meteo-melin
    • Weather station Mélin
« on: August 07, 2015, 07:57:37 AM »
Hello,
One of my stations will be moved to a place where it is not possible to connect it with a wired connection.
I'm currently trying to make it works by connecting it to a wifi AP set in client mode.
Unfortunately this is very noisy as you can see on the signal graph: http://www.lightningmaps.org/blitzortung/europe/index.php?bo_page=statistics&bo_show=station&bo_sid=680&bo_station_id=675
Do you have any suggestions to have it running better?
Thanks a lot.
Clement
Clément
Weather station Davis VP2 : http://www.meteomelin.be
Blitzortung stations: 252, 680, 733. Region 1
Re: Any participants with RED connected to a wifi client?
« Reply #1 on: August 07, 2015, 11:24:46 AM »
I'm using a Cisco RE1000 in WiFi extender mode in the garage -- the RED board is connected to the ethernet port on it and it's working fine (except for the occasional change of IP address when DHCP lease expires).  I, too, couldn't run a physical cable to the location.  I'd also tried a pair of power-line ethernet extenders, but got better results with the RE1000 (higher throughput).
« Reply #2 on: August 08, 2015, 09:09:43 PM »
I am running a GridConnect industrial AP configured as a client. I have my Blitzortung controllers out in the garage where it gets quite cold in the winter. This AP was rated for -30°C, which is why I bought it.
Was the station quiet before you added the WiFi client? Can you try a different power supply for the AP? Maybe it is a noisy supply. I can't think of any particular reason that the WiFi link should introduce noise unless the AP has poor EMI characteristics.
Offline meteo-melin
« Reply #3 on: August 09, 2015, 02:34:55 AM »
Thank you four your answers.
Yes the station was (is) working pretty good with a wired connection.
Currently the interference levels stay the lowest possible. They do not reach level such 70 or 80 sig/s.
Il'll try to find an other power supply.
Clément
Offline meteo-melin
« Reply #4 on: August 13, 2015, 05:06:17 AM »
Sadly, I had no 9V/DC 1A power supply. I'm waiting it to arrive.
I also ordered some ferrites.
Clément
Offline meteo-melin
« Reply #5 on: August 14, 2015, 08:09:28 AM »
Unfortunately, the new power supply and the ferrites do not solve the problem.
It appears that those interferences are transmitted through the ethernet cable.
Indeed, with the AP powered on but not connected to RED, everything runs smoothly. Immediately after plugging in the ethernet cable from the AP, the detector goes in interference mode.
Clément
« Reply #6 on: August 14, 2015, 08:21:51 AM »
Are you using STP or UTP Ethernet cable? If it is UTP, you might try STP (shielded).
Offline meteo-melin
« Reply #7 on: August 14, 2015, 09:36:53 AM »
Tried with FTP cable... still the same.
Interference is about 50sig/s.
Note that the RJ45 port on the AP is unshielded.
EDIT: ](*,)
« Last Edit: August 14, 2015, 10:25:34 AM by meteo-melin »
Clément
Offline Joel
    • PWS Lobbes
« Reply #8 on: August 15, 2015, 04:16:17 AM »
What happens if you insert a switch between the RED controller and the AP ?
Offline Maumelle Weather
    • Maumelle Weather
« Reply #9 on: August 15, 2015, 08:22:34 AM »
I have a 25ft. STP cable running from my Red controller to my Airport Express AP. Also, please make sure the controller is properly grounded. This was of my major headaches on interference/noise levels.
GR2AE, GR3, Cumulus
Offline meteo-melin
« Reply #10 on: August 15, 2015, 08:24:34 AM »
At first, I thought it would help but this is not the case. The signal rate stays at about 40sig/s.
After a good night, I asked myself: "Is that problem so complicated? Is it really a power supply or hardware matter?"  #-o
Back to basics: I simply switched from automatic mode to manual mode, set proper gains and thresholds and the station is back on duty (at least for now...).
Clément
