OK, so here are the params sent using SS gauges:
"wlatest"
"wspeed"
"wgust"
"wgustTM"
"windTM"
It is sort of hard to guess what is what, so if you could help me and tell me which clientraw/realtime fields I should use for these (also possible to use the db of course for max etc.)
There are several wind speed and direction data in the realtime.txt. Field numbers:
6 [5] Wind speed average
7 [6] Latest wind speed reading
31 [30] Today's high wind speed (average)
33 [32] Today's high wind gust
41 [40] 10-minute high gust
8 [7] Wind bearing (degrees)
12 [11] Wind direction - N or E, or W, etc
47 [46] 10-minute average wind bearing (degrees)
52 [51] Wind direction (average) - N or E, or W, etc.
For the Wind speed gauge:
for digital box "wspeed" Wind speed average Cumulus 6 [5]
for needle "wlatest" Latest wind speed reading Cumulus 7 [6]
for red highest speed indicator "???" Today's high wind gust Cumulus 33 [32]
for speed range highlight "???" Min to Max ???
For the Wind direction gauge:
for Current digital box "w...." Wind bearing (degrees) Cumulus 8 [7]
for Average digital box "w...." 10-minute average wind direction (degrees) Cumulus 47 [46]
for needles ?? could use Wind direction and Wind Direction (average) N, E, S, etc.
I see it can get pretty complicated, just have to determine what you can and want to display.
Hope this helps.
