OK, I fixed one other issue with the temp/dew gauge (it always starts from zero after update).
But there is no point in releasing a fix if there are more problems, right now I know the WD option does not work. Im curious if Cumulus does. The problem is that unlike in other cases, here I cannot test it with someone´s clientraw, since it combines data from db with realtime, if these two dont match, its not going to work and produce nonsense, which does not tell me if it works
