Hi guys,
there is one new block and most importantly, many updates of current blocks/plugins. Something I intended to do long time ago....
New Block - CalculatorAs a little Javascript exercise I made a simple weather calcultor. If functions as a normal calculator, but to make it a bit more interesting I also added some weather-related functions (unit conversions) and it is also possible to directly copy the result to clipboard.
DEMO:
http://www.meteotemplate.com/template/indexBlockDemoNarrow.php?block=calculatorBlock update - Interactive GraphThe interactive graph is now much better optimized for the light theme.
Plugin updatesAll the following plugins are now
translatable (where possible) and there are also some
bug fixes for a few.
- earthquakes
- evapotranspiration
- contact
- cloud calculations
- snow
- unit conversions
- WxSim
- eclipses
- year normals
- year comparisonPlease note - I have already added all the strings for the new translations. There is over 200 of them. Just a little note though - originally the system was inserting your submitted translations automatically, but this did not prove to be a good system as I often had to manually correct things and in the end it took me more time checking it than if I inserted each translation manually.
This means that I now do it all manually one by one and so please be patient. As there is now many new strings for many languages it can take me a little while before the translations you submit are available for download. I will try to do it as soon as possible, but this is just so you know that upon submitting it, it will not immediately appear in the language files.
Enjoy
Jachym
