Author Topic: CURL in Cumulus  (Read 5755 times)
Offline nitrx
    • Apeldoorn-Oost The Netherlands
Re: CURL in Cumulus
« Reply #25 on: May 17, 2015, 10:34:17 AM »
yes, but remember, the actual script that will be executed is separate, which means that you can use any other way of trigerring it. This VBS script is only to run the other script at regular intervals, but it doesnt really matter which way you choose to do this. If somebody for example is familiar and have the possibility of doing it with a CRON job, then no problem. If somebody downloads the new Cumulus MX, which will be able to do it, again, it is ok. So this VBS would be only as a "back-up" for those that do not upgrade to Cumulus MX and for example dont have the possibility of setting up CRON job so often.
Aha ofcourse thanks for making it clear
Ron
Cumulus software
Apeldoorn NL
http://www.apeldoornmeteo.nl
several languages
