Author Topic: Add-InWx  (Read 26403 times)
Offline virusdunil
    • Station Meteo Hebertville
Re: Add-InWx
« Reply #100 on: March 27, 2015, 05:52:31 PM »
I use VSPE...a virtual com port software...
VSPE is reading com1 and create a virtual port
WD is connected to com port 2
Other software on com3 is reading from com port 2
Cabled Vantage pro2 + Solar / Stevensen screen
Weather Display latest version + Boltek PCI-NexStorm-StormVue NGX / NSDisplay
http://www.meteolacstjean.com/weather28/index.php
Meteotemplate : http://www.meteolacstjean.com/hebert/index.php
Offline Josiah
  • Add-InWx Software Author
    • Add-InWx
Re: Add-InWx
« Reply #101 on: March 27, 2015, 06:01:58 PM »
OK,
Just to make sure I understand what is going on, When WD is connected to com port 2 and VWS is connected to com 3, everything works correctly. But when you switch VWS for Add-InWx you start losing graph data.
Is this correct?
Offline virusdunil
Re: Add-InWx
« Reply #102 on: March 27, 2015, 06:07:55 PM »
yes my friend...thats what happened....Now WHY :?:
i really dont have any clue to give you  :???:
just to be shure,ill reboot my system and give it another try  ;)
Offline virusdunil
Re: Add-InWx
« Reply #103 on: March 27, 2015, 06:19:53 PM »
Both are up and running now...
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #104 on: March 27, 2015, 06:27:08 PM »
Ok, thanks for confirming that.
I don't think rebooting your system will help.
What I think might be going on relates to how Add-InWx retrieves station data.
As I'm typing this I just had an "doh" moment.
Here's what I believe is going on and how to fix it.
VSPE doesn't marshall traffic between programs, so if one program requests station data then the other requests station data while the console is responding to the first request, something has to happen. I would think that one request would not get filled and thus the one program doesn't see valid station data.
Here's how you fix it,
Switch VSPE for VirtualVP, VirtualVP is designed to handle multiple programs requesting data from the station at the same time. That should fix the problem.
EDIT:
I'm glad that they are both running now, But I still think you should use VirtualVP instead of VSPE. Come to think of it, this might also solve the problem you had earlier with WeatherLink.
Offline virusdunil
Re: Add-InWx
« Reply #105 on: March 27, 2015, 06:40:07 PM »
i wanted to try virtual vp but...expired licence..... :???:
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #106 on: March 27, 2015, 06:51:11 PM »
That's a Bummer...
I suppose it isn't possible to put it into a Demo mode then.
Or you might want to take a look at this page.
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #107 on: April 03, 2015, 02:47:09 PM »
Hey Guys,
News Update,
I've finally put up a dev blog. Check it out here.
I was holding off publishing the blog site until I had something on it. After all, there is no sense in putting up a website that has no content. :grin:
I've also got a status update for Add-InWx, you can find it on the new dev Blog.
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #108 on: April 28, 2015, 07:52:12 PM »
It's hard to believe that it's been almost a month since something was posted here. Time goes by so quickly.
Anyway, I Just added a new Blog post to the Dev Blog. You can find it here.
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #109 on: June 06, 2015, 01:58:54 PM »
Wow, Its been quite awhile.
Here is another update on development.
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #110 on: July 07, 2015, 08:34:18 PM »
Another update,
It looks like its turning into monthly dev status updates. :-(
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #111 on: August 13, 2015, 01:21:17 PM »
Well... Here's another update. This time its a Software Update.
Version 1.0.2.3 Beta is now available!
You can find the Download link on the website - AddinWx.net
Change Log:
 - Settings are now saved when the Options Window is closed instead of when the program is closed.
 - Stations are now setup to Re-connect and use the new settings when the Options Window is closed.
 - Fixed a bug that was causing the Station settings to be loaded after the Stations were told to open a connection.
 - Changed how the station's Update method is called. Instead of keeping a thread in a constant Loop, its now setup to create a new thread at a specified interval. This will help prevent threads remaining open when the program has been closed.
 - Window State (Windowed, Fullscreen, Maximized) is no longer remembered when Add-InWx is closed. Window location however is and you can still set the Window Startup mode in the Options.
This is a Hold-Over update to fix a few things while I'm getting ready to start a Beta for the new Windows 10 based version, which should be ready within the next couple of months. When its ready I'll announce it here and on the Dev Blog along with more details.
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #112 on: December 21, 2015, 08:07:00 PM »
For those that are watching this thread,
I am not dead nor have I abandoned the project. In fact, I have just released a new version of AddInWx, this one is for Windows 10.
Seeing as it is a completely new rewrite, I decided to start a new forum thread for it. That thread is located here: http://www.wxforum.net/index.php?topic=28176.0
I've also posted the announcement on the dev blog, which is located here: http://www.blog.addinwx.net
And one more thing...
MERRY CHRISTMAS!
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #113 on: August 23, 2020, 09:36:19 PM »
Hi guys,
I've recently started to receiving requests from people to resume supporting this program. Although It has been a few years since Iíve touched the code for it, it occurred to me that I never found out how much of an impact this software has made.
If you can spare 5 to 10 minutes of your time, I would really appreciate you filling out this survey. The survey is not designed for just those who have used the software. But anyone who meets one or more of the following:
  • You are currently using the software.
  • You have used the software in the past.
  • You looked at, or thought about using, the software and decided not to use it.
  • You attempted to install or use the software and decided not to use it.
Here is the survey: https://forms.gle/FMpfM9zMsZLUsTtm6
Thank you!
« Last Edit: August 23, 2020, 09:37:53 PM by Josiah »
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #114 on: October 08, 2020, 02:51:57 PM »
Hey all!
After some consideration, I have decided to open-source this software application! The Github repo is located here: https://github.com/Josiah-B/Addin-wx
Feel free to reach out if you have any questions, or if you would like a meeting to go over the source code.
Thank you!
Offline Garth Bock
  • Table Rock Lake Weather
Re: Add-InWx
« Reply #115 on: October 08, 2020, 05:51:38 PM »
I am using it and really like it. I am working on a project that will use it.
Offline Garth Bock
Re: Add-InWx
« Reply #116 on: October 08, 2020, 05:52:51 PM »
Hey all!
Thank you!
I went to the link and it's not there.
Offline Josiah
    • Add-InWx
Re: Add-InWx
« Reply #117 on: October 08, 2020, 06:09:29 PM »
Hey all!
Thank you!
Whoops, had the repo set to private... Try it now.
What kind of project are you working on?
Offline Garth Bock
Re: Add-InWx
« Reply #118 on: October 08, 2020, 08:31:28 PM »
Will send a pm about it.
