Author Topic: Reducing Interference Part 2  (Read 582 times)
Offline Nova
« on: November 01, 2014, 05:33:57 PM »
Image 1543 shows 1000 Hz 1mV peak-peak interference caused the the system display dimmer.  This noise goes away when the display brightness is set to 100%.
Has anyone been able to eliminate this noise without increasing display brightness to maximum?
Will full brightness shorten the display lifetime?
Joe
Offline W3DRM
    • Carson Valley Weather
Re: Reducing Interference Part 2
« Reply #1 on: November 01, 2014, 05:43:55 PM »
Joe,
This is a known issue with the LCD used in the Blitzortung RED systems. The recommendation from the developers is to set up your display settings so the display is at full-brightness and/or so it shuts-off after some period of time. I have mine set as shown below:
It shuts off after 60 seconds. There is a noticeable difference in signal noise between it being on and off.
--- RIPE Atlas Probe - 32849
« Reply #2 on: November 01, 2014, 08:03:31 PM »
I have mine set to 100% full time. The controller is out in the garage, and I have a Raspberry Pi cam aimed at it, so I want it on all the time. It is an LED backlight, so I expect a long life out of it.
I have not dug into the issue, but I suspect that some combination of a lower frequency and slower rise/fall times on the PWM might help. Also, if the grounding was poor for the return path of the PWM there might be a common-impedance cause for the noise. (ground ripple getting into the ADCs)
Offline W3DRM
« Reply #3 on: November 01, 2014, 08:47:18 PM »
It's the PWM that is the cause of the hash noise. From what I have seen on my station, it's really not that much but, in an effort to keep all noise at the lowest possible level, I simply have it set to time-out after 60 seconds. I see about 5mv with the LCD backlight on and about 2mv with it off. That is looking at the Signals page with the 5v sampling Enabled.
