my bad wow, i just figued this out. go into Veiw and then goto color tables settings and then choose or click the table you wana change and then to the right place the updaed color table in there. But i would love to see more Color tables as i miss them and ever since Grlevelxstuff went ofline i cant find any no more. So please share. Thanks
Here are the ones I'm using, some copied, some created. The one for base reflectivity does a good job showing none precipitation (outflow boundaries, etc.) in shades of grey and slate, and the other colors seem to do a better job indicating the actual intensity.
Base Reflectivity: fade_reflectivity(2).pal
Base Velocity: Pueblo_BV.pal
Storm Relative Velocity: Pueblo_SRV.pal
Echo Tops: new_echotops.pal
Duh, ".pal" files are not permitted...the ".txt" equivalent is attached.
![Brick wall ](*,)](https://www.wxforum.net/Smileys/default/eusa_wall.gif)
My main radar page:
http://www.lfweathercenter.com/fullradar.php
