Author Topic: The Amazing Blitzcam  (Read 736 times)
« on: August 04, 2014, 11:38:32 AM »
Just for complete silliness, I have my Raspberry Pi PiCam gazing at the RED display. It is a little fuzzy due to the proximity to the display. It is updated under cron at once/minute. My normal Linux box wgets it from the Pi then uploads it.
Oops, having some upload issues and the dreaded .jpg.NN problem...
Working on it...
« Last Edit: August 04, 2014, 12:12:09 PM by miraculon »
Offline Cutty Sark Sailor
Re: The Amazing Blitzcam
« Reply #1 on: August 04, 2014, 01:17:19 PM »
So, go fix it...
http://www.wxforum.net/index.php?topic=19044.0
This 'hiatus' is affecting folks strangely....
« Reply #2 on: August 04, 2014, 01:29:09 PM »
So, go fix it...
I have that lens laying around somewhere...
Another "move" victim.
I think that I got it working OK, seems that I had a bit of a snail-like race condition between the Pi and the Linux box. I put a sleep command in the get script on the Linux box to give the Pi a chance to finish up.
I am not much of a programmer, just a "monkey on the typewriter"...
« Last Edit: August 04, 2014, 06:49:09 PM by miraculon »
« Reply #3 on: August 04, 2014, 04:22:30 PM »
I found the lens, but it was a "-2". I found this suggestion for using "+2" reading glasses, or a clip-on macro lens for iPhone. I have the reading glasses propped up and it seems to help quite a bit.
http://www.raspberrypi.org/forums/viewtopic.php?t=43985
I'll figure out some kind of attachment method.
I removed the frame and cut each side of the lens so that they were flat. The lens turned 90° fit perfectly to the height of the PiCam. I hot melt glued it into place. The posted image is now using this +2 diopter reading glasses fix.
http://www.miraculon.net/amazing-blitzcam.html
Thanks Mike (Cutty) for the reminder and suggestion.
« Last Edit: August 04, 2014, 10:18:25 PM by miraculon »
