Author Topic: Firmware 5.0 is out  (Read 1421 times)
Firmware 5.0 is out
« on: December 01, 2013, 08:34:40 AM »
Just installed it. Some interesting goodies, including the AS3539 support. Plus there is a GPIO feature that I need to ponder... :-k
Firmware Files
Firmware 5.0 / 2013-12-01
* NEW: 1PPS-sampling with 8.4MSps to check timings and 1PPS quality
* NEW: Live status display in web-interface
* NEW: Possibility to connect AS3935 lightning sensor via I2C (experts only)
* NEW: I/Os for own purposes (experts only !!!)
* minor changes in networking
* supports PCB-Id 2 (10.4)
* minor layout changes
* fix: reset ENC28J60 on error and no more ENC28J60 interrupt on error (fixes high CPU usage)
* fix: signal page timeout detection on refresh
* fix: some values on http remote config weren't updated
Greg
Offline W3DRM
    • Carson Valley Weather
Re: Firmware 5.0 is out
« Reply #1 on: December 01, 2013, 01:54:38 PM »
Greg,
My 5.0 install went fine. I'm looking to see what other goodies have been included in the new firmware update today.
One question - Under the Signals tab of the web display, there is a box labeled Signal Tools. Should the 1 PPS Sampling be enabled or does it matter?
Also, so far, my Live Signals section is blank. Guess that means it hasn't detected anything since the reboot...
--- RIPE Atlas Probe - 32849
« Reply #2 on: December 01, 2013, 05:17:53 PM »
I activated the 1PPS view for a few seconds. The waveform seemed to show the 1PPS pulse from the GPS.
Greg
Offline Jumpin Joe
    • Joe’s Weather
« Reply #3 on: December 01, 2013, 06:06:05 PM »
Thanks for the heads up Greg.
Update was flawless.
I thought Tobi or Egon had said that in the next update, this one, that the status was going to be included on the setting tab under the parameters so you could see your status when you click apply and not go back to the status tab to see if your status is normal.....  Was I dreaming?
Joe
« Reply #4 on: December 01, 2013, 06:29:28 PM »
Joe,
It is right at the top of each screen, between Blitzortung.org Controller and the Blitzortung logo.
Sometimes there is a lag before the screen refreshes and it shows up.
Not exactly what I was hoping for, but it is an improvement. I still would like to see a status "LED" right near the gain controls.
You need to scroll up after setting the gain. The best part about it is that you can see the status on the "Signals" 'scope tab.
Greg
Offline Jumpin Joe
    • Joe’s Weather
« Reply #5 on: December 01, 2013, 06:40:05 PM »
Yes, a status "LED" is what I was trying to say.
Joe
