Author Topic: US National Temperatures map PHP script  (Read 14506 times)
Offline dnavarrojr
    • Weather Center
« on: November 03, 2013, 02:15:53 PM »
I have a script that generates a current U.S. map with national temperatures on it.
The script has an option for saving the map to a folder on your web site (I run a CRON job every 15 minutes to update the map).
The base map is from Google Maps and I mess with the contrast a bit to bring out the color in the map.
The cities and weather stations are specified in an array:
$cities = [
  [ 'name' => 'Topeka',         'station' => 'KTOP' ],
  [ 'name' => 'St Louis',       'station' => 'KSTL' ],
  [ 'name' => 'Los Angeles',    'station' => 'KLAX' ],
  [ 'name' => 'San Francisco',  'station' => 'KSFO' ],
  [ 'name' => 'Las Vegas',      'station' => 'KLAS' ],
  [ 'name' => 'Seattle',        'station' => 'KBFI' ],
  [ 'name' => 'Tulsa',          'station' => 'KTUL' ],
  [ 'name' => 'El Paso',        'station' => 'KELP' ],
  [ 'name' => 'Dallas',         'station' => 'KDFW' ],
  [ 'name' => 'Houston',        'station' => 'KHOU' ],
  [ 'name' => 'Salt Lake City', 'station' => 'KSLC' ],
  [ 'name' => 'Salem',          'station' => 'KSLE' ],
  [ 'name' => 'Miami',          'station' => 'KMIA' ],
  [ 'name' => 'Denver',         'station' => 'KBKF' ],
  [ 'name' => 'Detroit',        'station' => 'KDET' ],
  [ 'name' => 'Chicago',        'station' => 'KORD' ],
  [ 'name' => 'Omaha',          'station' => 'KOMA' ],
  [ 'name' => 'Billings',       'station' => 'KBIL' ],
  [ 'name' => 'Atlanta',        'station' => 'KATL' ],
  [ 'name' => 'Minneapolis',    'station' => 'KMSP' ],
  [ 'name' => 'New York City',  'station' => 'KNYC' ],
  [ 'name' => 'Washington, DC', 'station' => 'KIAD' ],
  [ 'name' => 'Bismarck',       'station' => 'KBIS' ],
  [ 'name' => 'Bangor',         'station' => 'KBGR' ],
  [ 'name' => 'Raleigh',        'station' => 'KRDU' ],
  [ 'name' => 'Amarillo',       'station' => 'KAMA' ],
  [ 'name' => 'Nashville',      'station' => 'KBNA' ],
  [ 'name' => 'Jacksonville',   'station' => 'KJAX' ],
  [ 'name' => 'Boise',          'station' => 'KBOI' ],
You can replace the logo file with your own.  The only changes you HAVE to make are to the $image_folder and $font_folder variables.  Point them at where you store your image base, logo files and font file.
http://weather.wibwradio.com/usa-temps-map.zip
Let me know if you have any questions, suggestions or comments.
Dave Navarro, Jr. - The Weather Center
https://weathercenter.us
Offline cospringswx
    • Colorado Springs Weather
Re: US National Temperatures map PHP script
« Reply #1 on: November 03, 2013, 02:30:05 PM »
Any way to add your location to the map?
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline dnavarrojr
    • Weather Center
« Reply #2 on: November 03, 2013, 05:39:27 PM »
Sure, just modify the array and add your city/station.
Offline dnavarrojr
    • Weather Center
« Reply #3 on: November 03, 2013, 05:42:07 PM »
Oh, wait.. You want to add your personal weather station?
You'd have to add it manually.  My script only supports official stations on NWS.
Are you on Weather Underground?  If so, I could modify the script to support any station on WU.
Offline cospringswx
« Reply #4 on: November 03, 2013, 06:12:20 PM »
Ryan
Davis Vantage Vue
« Reply #5 on: November 03, 2013, 06:15:53 PM »
someone could make that a map of forum members from WU
Offline cospringswx
« Reply #6 on: November 03, 2013, 08:05:22 PM »
My map is here http://www.hayskansasweather.com/images/usa-weather-base2.png
Is this path correct?
$image_folder = '/hayskansasweather.com/images/';
$font_folder  = '/hayskansasweather.com/images/';
Ryan
Davis Vantage Vue
Offline dnavarrojr
    • Weather Center
« Reply #7 on: November 03, 2013, 10:50:59 PM »
Only if that's the physical location of your web site.  I don't know how things are on your back end.
I'll update the code to "do the math" on the file locations.
Offline SteveFitz1
    • Tyler Texas Weather
« Reply #8 on: November 04, 2013, 01:07:56 PM »
Dave,
I changed the $image_folder and $font_folder variables as you recommended and I get this error:
Parse error: syntax error, unexpected '[' in /home/stevefitz1/tylertexasweather.com/usa-temps-map.php on line 78
And this is line 78
$cities = [
Any suggestions?
Steve
Offline cospringswx
« Reply #9 on: November 04, 2013, 01:42:58 PM »
Dave,
And this is line 78
$cities = [
Any suggestions?
Steve
Me too!  http://www.hayskansasweather.com/usatemps.php
Ryan
Davis Vantage Vue
Offline Andy G
    • SunPrairieWeather.com
« Reply #10 on: November 04, 2013, 02:44:07 PM »
Once you can accept the universe as being something expanding into an infinite nothing which is something, wearing stripes with plaid is easy.
~Einstein
Davis VP2 24 FARS
Offline dnavarrojr
    • Weather Center
« Reply #11 on: November 04, 2013, 03:19:39 PM »
Dave,
And this is line 78
$cities = [
Any suggestions?
Steve
What version of PhP are you running?
Offline dnavarrojr
    • Weather Center
« Reply #12 on: November 04, 2013, 03:46:26 PM »
Okay, I am running the latest version of PHP which supports the array syntax of:
$ar = [ ];
However, earlier versions do not.  So I'll rewrite the array to work with earlier versions of PhP.
Offline dnavarrojr
    • Weather Center
« Reply #13 on: November 04, 2013, 03:52:51 PM »
Re-download the script from the original link.  Hopefully that fixes everything.
Make sure you edit the MAP, LOGO and FONT variables if you are not using "maps/" or "fonts/" to store your files in those folders.
Offline SteveFitz1
« Reply #14 on: November 04, 2013, 05:29:25 PM »
Dave,
Your updated version worked for me. Thanks very much.
I'm on PHP 5.3.27. Based on the error in the array, I suspected you had possibly written for PHP 5.5.
Steve
Offline cospringswx
« Reply #15 on: November 04, 2013, 05:37:17 PM »
Dave,
Steve
Post a link to your page Steve. I'm running PHP 5.2.14.
Ryan
Davis Vantage Vue
Offline SteveFitz1
« Reply #16 on: November 04, 2013, 05:55:08 PM »
Here ya go, Ryan.
http://www.tylertexasweather.com/usa-temps-map.php
All I changed was just the directory entries.
Steve
Offline cospringswx
« Reply #17 on: November 04, 2013, 06:09:16 PM »
Here ya go, Ryan.
Steve
Guess I got it on here http://www.hayskansasweather.com/usa-temps-map.php but with no data? How are you updating yours Steve? Can you post what you changed?
« Last Edit: November 04, 2013, 06:16:38 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline blizzardof78
    • Ohio Weather
« Reply #18 on: November 04, 2013, 06:47:19 PM »
Any way of doing this with humidity, pressure, wind speed, and so on? Boy if there was and I could figure out what in sam hill to do to make it work  #-o I'd drop my subscription to my current service in a minute!
Offline Maumelle Weather
    • Maumelle Weather
« Reply #19 on: November 04, 2013, 07:26:09 PM »
Hi Dave,
Thanks for the script. Have it working here: USA Temps
GR2AE, GR3, Cumulus
    • Maumelle Weather
« Reply #20 on: November 04, 2013, 07:26:51 PM »
Ryan,
Please check your directory settings in the script for the map background. I'm almost guessing the info is there, but without the background being there, its hard to check that.
GR2AE, GR3, Cumulus
Offline cospringswx
« Reply #21 on: November 04, 2013, 07:30:09 PM »
John post your settings here if you don't mind. How are u updating it?
Ryan
Davis Vantage Vue
    • Maumelle Weather
« Reply #22 on: November 04, 2013, 07:33:11 PM »
Hi Ryan,
Here ya go:
$map_base  = $dirbase . 'images/usa-weather-base2.png';
$logo      = $dirbase . 'images/usa-logo.png';
$outfile = "usa-temps-map";
$text_font = $dirbase . 'fonts/franklin_medium_condensed.ttf';
$font_size = 11;
Currently I'm updating it manually, but will probably set up a cron to it every 15 minutes or so.
GR2AE, GR3, Cumulus
Offline cospringswx
« Reply #23 on: November 04, 2013, 08:48:45 PM »
What do you have for this line? My usa-temps-map.php file is in the root.
[code$dirbase   = dirname(__FILE__) . '/';      // current folder where PHP file is installed]
« Last Edit: November 04, 2013, 09:05:28 PM by hayskswx »
Ryan
Davis Vantage Vue
    • Maumelle Weather
« Reply #24 on: November 04, 2013, 09:03:49 PM »
Hi Ryan,
This line is right above the map base line in the new version of the script. Around line 67 or so.
GR2AE, GR3, Cumulus
