Author Topic: Records from Datalogger missed  (Read 1125 times)
Offline PANDY weather
  • PANDY weather
« on: October 17, 2013, 08:25:30 AM »
Hello
Just to put you in the picture, I usually use Weatherlink as my default software, but I also I download all my data on Cumulus once a week, however I've just had an issue where my data hasn't downloaded on to Cumulus.
While using Weatherlink the serial port I was using (com 6) stopped working so I had to change over onto an unused serial port (com 7) and once I opened Weatherlink and sorted out the communications Weatherlink worked fine. Today however, I opened Cumulus and when I did this a box appeared stating I didn't have any communication, so I opened the station and updated the com pot information to (com 7), but when I did this Cumulus only downloaded the present data file from the data logger, data between now and the last time I opened Cumulus was not downloaded. Has anyone got any suggestions as to how I might correct this issus, thanks for your help.
PANDY weather.
Offline Guillaume_67370
    • METEO OFFENHEIM
Re: Records from Datalogger missed
« Reply #1 on: November 29, 2013, 08:15:02 AM »
Hello,
Do you use Virtual VP?
Because you can't work with 2 different software without Virtual Vp.
Regards
