100-250$
Oregon Scientific, Lacrosse, Acu-rite, Honeywell, Fine Offset/Ambient
Slower wind updates, questionable accuracy and reliability, Most likely made in China.
300-400$
Davis's Vantage Vue
Best station for the money. Highly accurate, high quality parts which are replacable, made in the USA,
Only drawback is the sensor is an all in one unit which makes installation easy but means rain or wind aren't going to be at ideal height for best accuracy.
500-1000
Davis's Vantage Pro2, Rainwise MK-III-RTN
Vantage Pro2 is the most popular choice. It's sensor unit is flexible to most installation situations. This allows the anemometer to be up high (NWS standard 33 Ft 10m) but the rainfall temperature and humidity to be lower (NWS standard 2ft-5ft 0.7-2m). You can also add things like Solar and UV sensors.
Rainwise which is at the top of the range has the best quality construction and componets and also some of the best accuracy. However the MK-III-RTN has no rain gauge.
1000$-2500$
Davis Vantage Pro2 Plus with 24Hr fan aspirated radiation sheild, Rainwise, Texas Weather instruments, Weather Hawk, Maximum inst.
Best quality instruments with the best accuracy. These are the type used by colleges and in rough conditions where "lower" stations would fall apart.
Anything more are probably not designed for home/hobby use.
Hope this helps.
