Author Topic: get-meteoalarm-warning-inc.php  (Read 2214 times)
Offline Axelvold
« on: July 18, 2012, 01:23:48 PM »
I use this on my frontpage to display weather warnings, but suddenly today it stopped working and I cant figure out why.
Any suggestions?
script is attached.
Lars Magnusson
Axelvold / Sweden
55░ 57' 41" N / 13░ 6' 1" E
Offline Axelvold
Re: get-meteoalarm-warning-inc.php
« Reply #1 on: July 18, 2012, 01:57:42 PM »
I did find this change in the cache file.
They changed from this
<div class="warnbox wb1">
to this
<div class="warnbox awt nt l l2">
Could it be this that caused this script to stop working?
Lars Magnusson
Axelvold / Sweden
« Reply #2 on: July 18, 2012, 05:23:45 PM »
Yep, that and a few other changes in the meteoalarm.eu website.
I've updated the script to V2.08 - 18-Jul-2012 to address the issues.
V3 template users can use the update tool (18-Jul-2012, Base-World) to get the script.
V2 template users/standalone can download from the script page
Best regards,
Ken
Offline Axelvold
« Reply #3 on: July 19, 2012, 12:51:22 AM »
Thanks Ken
I just have one small problem, can't get characters like ┼ ─ Í to show up.
Lars Magnusson
Axelvold / Sweden
Offline Axelvold
« Reply #4 on: July 19, 2012, 02:28:58 AM »
the issue is resolved.
Did change ISO-8859-1 to utf-8
Lars Magnusson
Axelvold / Sweden
Offline jdee
    • Mayo Weather
« Reply #5 on: July 19, 2012, 03:03:30 AM »
thank you gents - I had the same problem.
« Reply #6 on: July 19, 2012, 12:34:38 PM »
Ah.. tis true.  The script defaults to converting the meteoalarm.eu output from UTF-8 to ISO-8859-1 for use in the template sets.
If you're running your non-template site in UTF-8, then changing
$charsetOutput = 'ISO-8859-1';        // default character encoding of output
to
$charsetOutput = 'UTF-8';        // default character encoding of output
will leave the output in UTF-8 for you.
Best regards,
Ken
Offline Cavaliere
    • Ombarcellonapg
« Reply #7 on: January 10, 2019, 06:33:33 AM »
Hi everyone,
I finally found the correct discussion for my problem, I can not display accented characters on the meteoalarm script, I tried to put both UTF-8 and also ISO-8859-1 wh
Resolved ;)
« Last Edit: January 10, 2019, 06:41:45 AM by Cavaliere »
Offline Cavaliere
    • Ombarcellonapg
« Reply #8 on: January 11, 2019, 02:34:22 AM »
Good morning guys,
I continue to have problems with the letters accented in Italian on this script. (Ŕ Ó ˛¨) why?
« Reply #9 on: January 11, 2019, 10:50:07 AM »
You are running the correct version of the script, and have the output set for UTF-8.
The problem comes from the source of the data at https://www.meteoalarm.eu/it_IT/0/0/IT018-Sicilia.html
They are reporting
Non ? richiesta alcuna attenzione speciale
on their page.  It's likely that someone at the meteoalarm or the Italian weather bureau used ISO-8859-1 instead of UTF-8 for posting that message.  The script cannot back-convert to remove their error.  Sorry...
Offline Cavaliere
    • Ombarcellonapg
« Reply #10 on: January 13, 2019, 03:57:11 AM »
They are reporting
Ok thanks so much so it's not a mistake that depends on the script, but on the meteoalarm site itself.
While I do not understand how to update the alerts for now in my region in Sicily I see an orange alert but the script does not report the image with the warning why?
« Reply #11 on: January 13, 2019, 05:05:24 PM »
It may have just been a cache issue -- I see on your page
inizio validit? dal 13.01.2019 12:00 CET fino a 14.01.2019 23:59 CET
Vento  Livello di pericolo: Giallo
english: Wind gusts >30kt BE AWARE, keep up to date with the latest weather forecast. Expect some minor disruption to outdoor activities italiano: Raffiche >30kt STARE (RIMANERE) ATTENTI. Tenersi aggiornati con le previsioni del tempo pi¨ recenti. Aspettarsi alcuni disagi minori per le attivitÓ all'aria aperta.
and the yellow caution image for alerts.
The default in the get-meteoalarm-warning-inc.php is 300 seconds (5 minutes) for the cache lifetime.
