Author Topic: CORRECTED Problem Loading WeatherLink  (Read 3591 times)
Offline Sawwth
  • Well the Pole's up!
« on: April 02, 2008, 07:33:37 PM »
I tried to load 5.7.1 on my laptop. As soon as I started an error message poped up. Starts out;  C:\DOCUME-1\my name\locals\temp550dd319-FD90-4F39-BC47-E2DDEEAE498D\isrt.dll. Could not be installed. Access denied.
I cleared the message and proceded to load 5.7.1. Seemed to take.
Then tried to load Wonder Weather WuiWlink_1.dll. Seemed to take except when I went to read the Read me File I got Access denied. Tried to uninstall 5.7.1 and start over. Access denied.
 I must be missing some software or something. Any thoughts?
Decided not to us laptop....would only take ubs from data logger.
e machine laptop, wireless to DSL router
IE7 thru MSN prem
6510SER
« Last Edit: April 27, 2008, 08:05:55 AM by Sawwth »
Offline capeweather
    • http://www.capeweather.com
Chris
Cape Coral, Florida
Offline Sawwth
Re: Problem Loading WeatherLink
« Reply #2 on: April 03, 2008, 11:05:20 AM »
So far no luck. I might add that it's got SP2.
What if I remove XP home and reload?
Offline jruys
  • Yo
    • Highlands Ranch Weather
« Reply #3 on: April 03, 2008, 09:20:18 PM »
Make sure you are using an administrator account to install your software.  You probably are, but just in case...  If you are an administrator, go to the folders you are getting an access denied error and change the permissions on the folder to let any user read and write to the directory.  Hope this helps.
Offline Cienega32
    • East Mesa Weather
« Reply #4 on: April 06, 2008, 02:13:08 AM »
Are you getting a 'Windows setup (or maybe update)' file error as well as the 'Access denied' error?
« Last Edit: April 06, 2008, 02:14:42 AM by Cienega32 »
Pat ~ Davis VP2 6153-Weatherlink-Weather Display-StartWatch-VirtualVP-Win7 Pro-64bit
Offline Sawwth
« Reply #5 on: April 08, 2008, 07:10:28 AM »
No, just the error message I ststed. I'm going to do a ststem restore and if that don't help I'll run the restore cd's.
