Author Topic: wxgraphic.php current conditions icons size  (Read 1535 times)
Offline naish666
« on: February 09, 2012, 05:01:34 PM »
Hello,
It's possible to change the size of the default current_conditions icons? (of the  wxgraphic.php)
The default size is 25x25 and I wanna change it.
Thank you
Re: wxgraphic.php current conditions icons size
« Reply #1 on: February 09, 2012, 06:40:12 PM »
The short answer is 'Yes'.. you can use icons other than the default 25x25 icons.  You'd need to create a matching set of icons to the ones already in the icons/ directory .. your choice of .gif (non-animated), .jpg or .png .. just make them all have the same (square) dimensions.
Then change wxgraphic.php code
// now let's create the image
switch (TRUE){
  case ($type == "banner"):
       // put the icon on the background
       if (isset($icon)) {
          imagecopyresampled($img, $icon, $banner_icon_x, $banner_icon_y, 0, 0, 25, 25, 25, 25);
       } // end if
       // write the text onto the 468X60 banner
       write_banner();
  break;
  case ($type == "banner_big"):
       if (isset($icon)) {
          imagecopyresampled($img, $icon, $banner_big_icon_x, $banner_big_icon_y, 0, 0, 25, 25, 25, 25);
      } // end if
       // write the text onto the 500X80 banner
       write_banner_big();
  break;
  case ($type == "avatar"):
       if (isset($icon)) {
          imagecopyresampled($img, $icon, $avatar_icon_x, $avatar_icon_y, 0, 0, 25, 25, 25, 25);
      } // end if
       write_avatar();
  break;
  case empty($type):
       if (isset($icon)) {
          imagecopyresampled($img, $icon, $default_icon_x, $default_icon_y, 0, 0, 25, 25, 25, 25);
       } // end if
       // write the text onto the default image
     write_default();
  break;
} // end switch
for the new dimensions.
Hope this helps..
Best regards,
Ken
Offline naish666
« Reply #2 on: February 10, 2012, 03:24:21 AM »
It's works.
Thank you very much.
