Author Topic: Anemometer Kit 6332 v VUE ISS  (Read 4185 times)
Offline Flag
« on: April 09, 2011, 11:39:22 PM »
This is a pickup on a comment from the Davis weather page re using a VUE ISS as an anemometer only.
Wonder what the longevity is of using a VUE ISS as an anemometer only (in a remote setup) compared to a 6322 anemometer transmitter kit & VP2 anemometer?
Thoughts?
- VUE ISS is an all in one enclosure requiring no cabling
- VUE ISS could also be switched in a remote setup as a backup ISS for temp/hum/rain etc or used as a separate ISS to secondary loggers
- Cost is not all that much different/extra
- One downside of the VUE ISS (I see in any case) is no external power input
and doesn't have any historical maintenance availability/reliability (as yet)
Re: Anemometer Kit 6332 v VUE ISS
« Reply #1 on: April 10, 2011, 03:28:54 AM »
No real reason a priori to think that they would be any different. Obviously the Vue has only been around for 18 months or so and so we don't have any hard data on long-term performance in the field. But the few instances I've seen of premature wind speed failure in VP2 vs Vue in the first 18 months of use are pretty much similar in incidence.
To your list of pros and cons I would add:
Pro VP2: The anemometer can be mounted separately/higher than the 6332 so battery change will typically be easier on the VP2 (especially for anyone lucky enough to use a 10m mast in order to measure 'real' wind speeds).
Pro Vue: If the speed (reed) switch does start to go faulty then with the VP2 you typically need a new anemometer whereas with the Vue it's a simple and relatively inexpensive ($60) PCBA board change (that also actually gives you a new T/H sensor, though that won't be relevant in this example).
NB Whether the Hall Effect wind direction sensor in the Vue gives better longevity and better through-life accuracy obviously remains to be seen, but it's a possibility.
« Last Edit: April 10, 2011, 03:40:30 AM by johnd »
Littleport, Ely, Cambs UK
Offline Flag
« Reply #2 on: April 11, 2011, 04:18:03 AM »
Yes will be interesting to look back on VUE in 10 years time. Would be also interesting to hear about VP2 anemometer longevity. The best I have todate is a WMII style anemometer now running for 7 years in high range wind environment but they do require some mods do ensure reliability, especially wind direction.
