Author Topic: Broadcast 14.01 P34  (Read 5132 times)
Offline bduren
    • Bastad Weather, Sweden
Broadcast 14.01 P34
« on: February 02, 2011, 03:18:46 PM »
Hello
I have got 2 new items below the temp meter in Broadcast display
Normals 0/0
Records 0/0
Never seen before
Can somebody explain
« Last Edit: February 02, 2011, 03:23:40 PM by bduren »
/Björn
Re: Broadcast 14.01 P34
« Reply #1 on: February 02, 2011, 06:43:22 PM »
I don't use VWS but I'll give it a try.
The Normals would probably be the average High and Low for the day and the records would be the highest and lowest temperature for that day.
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #2 on: February 02, 2011, 06:50:57 PM »
Hello
Normals 0/0
Records 0/0
Never seen before
That feature is to show the Normal Average and Record Temps. for that day as recorded by Wunderground.  As far as I am aware the feature is only supported in the US.
To get them off your broadcast.jpg image....  In VWS go to WUNDERGROUND > CLIMATE REPORT > UNCHECK "Display Station 1 on Broadcast Display"
If you are retrievning data in the Station 1 fields then there is not enough information being provided by the station so it defaults to 0/0.
Offline kray1000
  • Purveyor of wry
« Reply #3 on: February 02, 2011, 06:57:20 PM »
There was some kind of glitch at Weather Underground this morning.  I had all zeros on my broadcast display for the normals and records as well.
Offline bduren
« Reply #4 on: February 05, 2011, 01:40:00 AM »
So, now i get it
Thank you.
/Björn
