Author Topic: What temp/hum does Ambientís WS-2902A & Falcon WS-8478A uses  (Read 183 times)
Offline jgentry
Iím just curious to what Ambient Weather uses for their temp/hum sensors. Iíve heard that they use the Sensirion SHT-30 for the WS-2902A. If thatís correct, what do they use for their Falcon WS-8478A?
Davis Vantage Pro2. SHT-75. WU: KXALJEMI2 & KALTHORS2. CWOP/APRS: C6353 & E6358
Re: What temp/hum does Ambientís WS-2902A & Falcon WS-8478A uses
« Reply #1 on: April 16, 2019, 02:22:04 PM »
Yes SHT30 for the WS-2902-ARRAY used in the WS-2000, WS-2902A, WS-1550-IP and WS-1900.
Nobody knows what is in the Falcon WS-8478A as nobody cares and nobody buys it.  :grin:
No but seriously...nobody buys it really.
In the last WU station analysis that I did (end of 2018) I found that in the US there were 9,363 combined WS-2902 and WS-2000 stations and only 94 WS-8478A stations...that is barely two per state or 1% of what the WS-2902A/WS-2000 sells and I think the WS-8478A was available first. No offense if you have a WS-8478A but I don't think that was a well informed decision. The pool sensor is the only reason I see people asking about the WS-8478A. But even still that doesn't seem to me like a good reason to get it. Get a separate pool sensor...or wait till Fine Offset comes out with more sensors which they are working on doing.
I don't recommend the WS-8478A even if it had a SHT31 that was better than what is in the WS-2902-ARRAY. It isn't the price that is the problem it is that it isn't a Fine Offset station and you don't get the advantage that comes with all the Ambient/Fine Offset stuff. Betamax was better but you couldn't rent movies. Better isn't always better if nobody else embraces it and develops supporting 3rd party hardware and software for it. There is no way I could do everything I do now with my Ambient station if I had a WS-8478A.
« Last Edit: April 16, 2019, 02:23:35 PM by galfert »
Offline jgentry
« Reply #2 on: April 16, 2019, 03:01:03 PM »
Gotcha. I was just checking them out and wasnít planning on getting them. Thanks for the info!
