Author Topic: rapid fire checked but updating every 10 minutes - Help !  (Read 2130 times)
Offline nycweatherman1
    • Glenn's Weather Page
« on: October 01, 2010, 08:41:05 AM »
Hi forum
I need your assistance..
Station ID : KNYNEWYO51
Station Location: Peter Cooper Village, NY
Rapid fire is checked off in weather underground settings page .. and still all records are being updated every 10 minutes ...Type says Normal instead of rapid Fire
How can I correct this???
Thank you
Offline wuhu_software
    • WUHU Software Yahoo Group
Re: rapid fire checked but updating every 10 minutes - Help !
« Reply #1 on: October 01, 2010, 09:10:45 AM »
It appears that you are using the VWS software. I would guess there is an option within VWS that you must set. The settings at the WU page do not matter when it comes to rapid-fire as far as I can recall.
Offline gadget_guy
« Reply #2 on: October 02, 2010, 06:30:48 PM »
If you are using VWS, the setting you need is under Wunderground in the menu.  Here is a screen shot.  About half way down on the left you will see the check box for Rapid Fire and the timer settings.
KVAMCGAH2 - Massanutten VA Davis
KVAMASSA2 -Massanutten VA Oregon Scientific
WA2ONG
Offline kray1000
  • Purveyor of wry
« Reply #3 on: October 02, 2010, 07:05:52 PM »
And if you are using VWS, in most cases you will need to restart the software for any settings changes to take effect.
