Author Topic: Weatherlink Fullscreen Embed Changes  (Read 850 times)
Offline drew
    • Shoals Weather
« on: June 30, 2020, 10:13:04 AM »
Has anyone noticed that the wind direction beside the wind speed has changed to degrees instead of the letter direction? I cannot find a setting anywhere to change it back from degrees to the letter direction.
Also, they have added an Air Quality field. I cannot find any information on this. Hoping someone else knows what’s coming!
https://www.weatherlink.com/embeddablePage/show/1fcffde9ea1d4756940ac7ae0b5b011a/fullscreen
-Drew Richards
Re: Weatherlink Fullscreen Embed Changes
« Reply #1 on: June 30, 2020, 10:41:57 AM »
I see it on my station as well. Maybe there is a setting for this.
For the AQI, maybe there is a sensor coming?
Offline wvdkuil
  • Wim van der kuil
« Reply #2 on: June 30, 2020, 10:45:18 AM »
Check the AQ discussion here https://www.wxforum.net/index.php?topic=39840.0
« Reply #3 on: June 30, 2020, 10:52:25 AM »
I found something under "My Account >> Unit Measurements".
The last item on the list is Air Quality Index :: USA :: Edit
Follow the "Edit" link and it will take you to the pop-up page showing a variety of locations and an explanation off to the right. You can scroll through it.
From this, I don't think that there is a sensor, rather a look-up for the data. So far, it doesn't seem to be active.
« Reply #4 on: June 30, 2020, 10:55:11 AM »
I didn't find anything about the wind direction being in degrees instead of compass points...
(I meant this in terms of being able to restore the compass point settings, I do see the numeric direction assumed to be degrees in the banners and other screens...)
« Last Edit: June 30, 2020, 05:56:28 PM by miraculon »
Offline Mattk
« Reply #5 on: June 30, 2020, 05:06:46 PM »
Has anyone noticed that the wind direction beside the wind speed has changed to degrees instead of the letter direction?....
Well it has changed to a number (only) without any qualifier, no Deg symbol etc on any browser of mine. Are you seeing something different apart form the number?
Offline drew
    • Shoals Weather
« Reply #6 on: June 30, 2020, 06:00:43 PM »
Correct. Just a number. No degree symbol. Very confusing until I figured out what it was.
-Drew Richards
« Reply #7 on: July 01, 2020, 08:06:54 AM »
If anyone finds a way to restore the cardinal/ordinal nomenclature in lieu of the "degrees", I would be interested in knowing how to do this.
« Reply #8 on: July 01, 2020, 06:43:24 PM »
The wind direction seems to have reverted to the cardinal/ordinal scheme by itself. (N, NE, E, SE, etc...)
Offline Mattk
« Reply #9 on: July 01, 2020, 07:25:34 PM »
So it has, obviously had some assistance?
