This is just a minor change to the V3.04 release -- it adds two more images in ./ajax-images/ for display by the wxradio/radios script set.
The images can be downloaded
here, and the full script page (with full download) is available
hereAn 'upstream' fix was done today to the display of the SAME codes below the map so that a SAME code display will not wrap within the code, but only between codes (makes for a better display) -- no client script changes were needed for that.
