Author Topic: Davis VP2 Plus FARS in Cochranville, PA  (Read 2055 times)
Offline Kfritz22
« on: July 21, 2020, 04:40:36 PM »
Just installed my new station yesterday.  Right now the anemometer is at about 12' but will soon go up to 33' once the new mast comes in.  That'll get some guy wires to make it sturdy.  So far, working great!
Ken
Davis 6153 VP2 Pro Plus with 24hr FARS
Weatherbridge/Meteobridge 4.4
WU: KPACOCHR7
CWOP: N3WAX-1
Offline droiddk
Re: Davis VP2 Plus FARS in Cochranville, PA
« Reply #1 on: July 21, 2020, 05:01:57 PM »
Nice install!
Offline tshattuck
    • Your Local Weather - Clay, NY
« Reply #2 on: August 07, 2020, 05:57:22 PM »
Nice installation. Can't wait to see your 33' mast setup.
Offline alexstaar
« Reply #3 on: October 31, 2020, 01:44:19 AM »
Do you report to CWOP or WU?
-Alex
Davis 6153 VP2 with 24-hour FARS/
Davis 6250 Vantage Vue
WU: KNJMOUNT68/KSCGREER81
CWOP: FW5135/EW6390
www.uah-mcthornmoracres-weather.com
« Reply #4 on: October 31, 2020, 04:51:45 AM »
Looks good but just curious what the crossbars are for. Aesthetic?
Offline Kfritz22
« Reply #5 on: November 08, 2020, 12:45:38 AM »
Updated - New mast, up to 33 feet.
alexstarr - CWOP, WU, Ambient, WeatherLink, and PWSWeather
ocala - the crossbars are to support the mast mount, but I made them a bit wider for adding additional sensors later - like air quality, that sort of thing.
Ken
WU: KPACOCHR7
CWOP: N3WAX-1
Offline tweatherman
« Reply #6 on: November 08, 2020, 12:57:17 AM »
Heads up...watch out for deer running into the guy wires like what happened to mine and brought my tower down.
tweatherman
« Reply #7 on: November 08, 2020, 05:07:59 AM »
Gotcha. Looks like you have some wide open spaces there for some good wind data. Mine is at 33ft but still blocked in certain directions. :-(
tvweatherman would tying some kind of ribbons on the guy wires at about 4ft help with the deer situation.
Offline havtrail
    • Haverford Weather Station
« Reply #8 on: November 08, 2020, 05:37:27 PM »
I used stiff 8 ft. yellow plastic guy wire guards like this:
https://www.linemen-tools.com/Guy_Guard_Markers_s/301.htm
I found a local contractor/municipal supplier, went there and bought 3 for about $8 each, avoiding shipping. They are molded with a split down their length, so you can pop them onto a guy wire that is already attached at both ends. Good to have when you're cutting grass, too!
What type of mast do you have, and how can you lower or tilt it down for anemometer maintenance?
Rich K.
Onset HOBO RX2102 Cellular
Offline Kfritz22
« Reply #9 on: November 09, 2020, 01:23:25 AM »
Good suggestion.  I'll look into those - I was going to do a few streamers, done those before with other guy wires, but the sleeves are cleaner.
The mast is custom made - the bottom 20 feet or so are 2" 0.25 wall aluminum, the top section is 1.5" welded inside the 2" section.  It's bolted to the wood support with standoff mounts, so just have to detach the guys and unbolt it and step it down.  It's fairly light, so easy to just lift up and down.
Ken
WU: KPACOCHR7
CWOP: N3WAX-1
Offline tshattuck
« Reply #10 on: November 09, 2020, 09:14:09 PM »
Nice setup.  [tup]
Glad to see you were able to get the 33' height for the anemometer. It's nice to have the room to do so.
Offline alexstaar
« Reply #11 on: November 23, 2020, 02:30:47 AM »
Awesome! I work at the local NWS office in Mount Holly, NJ. We ingest all CWOP data and send it out via PNS statements during high impact events for heavy rain, high winds, etc., so I'll keep a look out for your station ;)
-Alex
CWOP: FW5135/EW6390
