Author Topic: Brief introduction Ecowitt HP10  (Read 4801 times)
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
Re: Brief introduction Ecowitt HP10
« Reply #25 on: November 02, 2022, 12:24:50 PM »
Hi!
Previously, it was possible to access photos and timelapse videos at Ecowitt.net that were up to 30 days old.
But now there is only a holding time of 7 days - older photos/videos are apparently deleted automatically.
I don't know if this is only a temporary problem and have asked Ecowitt about this.
I think 7 days is clearly too short. What do you think?
Regards, Oliver
Offline Rover1822
« Reply #26 on: November 02, 2022, 12:29:01 PM »
Oliver, what is the interval between images in the time lapse?
Also, is there a time stamp on the individual streamed images?
I'm not buying one, just curious
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline olicat
    • FOSHKplugin
« Reply #27 on: November 02, 2022, 12:40:27 PM »
Hi!
5min interval (configurable: 5, 10, 15, 20, 25, off).
In addition to the name of the camera on the left, the date/time is also displayed on the right.
Regards, Oliver
Offline Rover1822
« Reply #28 on: November 02, 2022, 12:56:48 PM »
Nice image of, darkness :)
I can imagine the conundrum on their end for storage of the images, unknown potential # of users , etc.
I only store 24 hours for mine at most in my custom set up with a a beach camera (need to go work on that, time, time , time , I don't have)
But I store 1 minute intervals, and offer a 4 hour lapse and a 24 lapse , from the same image storage that is a FIFO. What I do for the 24 hour is skip X number of images on the playback, to make the view shorter, the 4 hour runs at file storage time. So I store 1440 images in a FIFO rotation.
I feel their pain on the time lapse
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Platokidd
  • top side land of Lincoln
« Reply #29 on: November 03, 2022, 05:00:59 AM »
Hi!
Regards, Oliver
Think I was the 2nd or 3rd in the U.S. to have the HP10, or at least that share public on the ecowitt  map. Yes they shorten the images length to 7 days. You can download the images or days. Cheap camera with nice footage and easy to setup.
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
Offline box
« Reply #30 on: November 03, 2022, 12:22:26 PM »
How do you store FIFO - is that an option with the software you use or the NAS/storage device? Or a cron job/script?
Offline Rover1822
« Reply #31 on: November 03, 2022, 12:33:07 PM »
Please understand this is not using the HP10. Just a security cam. I use an NVR software (Blue Iris) , I think Zone minder could do the same. But this is a custom setup with a generic security cam that is ONVIF capable. Not related , again, to the capabilities of the HP10
I was just curious on how Ecowitt.net was doing their time lapse,
As far as the HP10, for me, the only advantage would be to post to Ecowitt.net. That is only for me, for others, all they need.
« Last Edit: November 03, 2022, 12:40:02 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline box
« Reply #32 on: November 03, 2022, 12:44:06 PM »
Ah, thanks
Offline Rover1822
« Reply #33 on: November 03, 2022, 12:47:55 PM »
I would be interested in the HP10 if it supported standard protocols . Better would be the ability to upload my own images to Ecowitt.net from my existing cams. But I get it.
Edit: It would take a lot of server side work on their end to accept images from generic cams even if they set the parameters for someone to send, like resolution, frequency and file size. There would be a bunch of error checking for each cam upload, and increased support time. So if you limit it to your own device, you get multiple wins. 1) You get the revenue from the cam sale 2) You don't get the headache of some numb nuts like me trying to upload from a generic system and trying to support it as you own the ecosystem.  Pretty much why I think WU dropped the whole web cam thing, and I get it.
« Last Edit: November 03, 2022, 01:05:40 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline BaseLine
« Reply #34 on: November 06, 2022, 08:27:31 AM »
Wow, the curvature is quite bad. But not uncommon with that quality camera.
My security cam that I use is not much better , about the same price, with more functions.
EW's HP10 has a super cheap 180 and yours has a 80 deg "lens". Of course 180 looks horrible. 180 looks bad even with a good lens.
150 seems to be max.
Sun cooked nothingburger of climate change hysteria with a side order of peak-oil nonsense fries.
Offline olicat
    • FOSHKplugin
« Reply #35 on: January 01, 2023, 05:51:35 PM »
Hi!
I have now published my current solution for my own webcam images and time-lapse videos here.
Maybe it will help someone for their own solution.
Oliver
Offline zoomx
« Reply #36 on: January 02, 2023, 04:09:45 PM »
Looking inside the firmware binary I found that it is definitively and ESP32 that seems programmed using Arduino ESP32 core, maybe the Arduino IDE.
Offline Nate R
« Reply #37 on: September 20, 2023, 01:26:50 PM »
I haven't found an answer anywhere....does this camera work below 0 deg C, or does it shut off at cold temperatures?
-Nate
Offline Gyvate
« Reply #38 on: September 20, 2023, 02:46:30 PM »
someone has to find out by experiment - officially its temperature range for operation is 0 °C thru +50 °C.
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpec Rad02
WIKI http://meshka.eu/Ecowitt/dokuwiki
Offline Nate R
« Reply #39 on: September 22, 2023, 04:34:54 PM »
OK, I guess I'll be that someone.  [tup]
Ordered a GW2000 and a WH32 as well as an HP10 to try out the Ecowitt system. I'll report back how the camera does in cold weather.
Offline Platokidd
« Reply #40 on: September 23, 2023, 07:02:20 AM »
Got the HP-10 in September 2022. It worked well during the winter months here in Chicagoland. Even in temps below freezing down to -9F (-22c).
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Nate R
« Reply #41 on: September 24, 2023, 06:23:05 PM »
Thanks, good to know!
Got my GW2000, WH32 and my HP 10 today, so I'll get them tested this week, and then hook them up at my cabin.
Offline Nate R
« Reply #42 on: October 04, 2023, 08:37:08 AM »
I've got my HP10 set up, and currently set to 20 minute intervals to conserve power. (on a battery system...will be grid connected soon.)
I'm finding the EcoWitt generated daily video to be.....odd. When I go to view the timelapse video, it starts out fine, but then gets very pixelated and blurry by the middle of the day or so. If I look at the individual images/photos, they are clear. The video is just as clear to begin with.
Has anyone noticed this? When I look at other cameras on the map, it doesn't seem to happen to the effect I'm seeing on my own, not even close.
Thoughts? Is this an artifact of using 20 minutes instead of 5? Why would it do this?
https://www.ecowitt.net/home/index2?id=152666
Offline G.Brown
« Reply #43 on: October 13, 2023, 11:51:38 AM »
Thing I notice when I've been mucking around with my HP10 is that it is always quite warm - having tried all 3 available lenses - the heat sink on the back of the lens is always going to keep it above freezing and may even stop snow build up ...haha famous last words....
Offline olicat
    • FOSHKplugin
« Reply #44 on: October 13, 2023, 11:58:03 AM »
Hi!
What do you mean with "available lenses"? Which lenses are available and where?
Oliver
Offline G.Brown
« Reply #45 on: October 13, 2023, 12:03:54 PM »
well the third is the one that it comes with but here are the other two.
https://www.ebay.co.uk/itm/154631011999?var=454711871442
The smallest one pictured needs a spacer - I just used the rubber grommet out of a gland.
Offline Rover1822
« Reply #46 on: October 13, 2023, 12:08:24 PM »
That appears to be a complete element (Ebay) not a lens , maybe I saw it wrong
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline G.Brown
« Reply #47 on: October 13, 2023, 12:13:44 PM »
? well it comes with a ribbon connector if that's what you mean.
Offline Rover1822
« Reply #48 on: October 13, 2023, 12:19:41 PM »
yep, that is what I meant. Differentiates it from a lens, which I would think of as an augmentation or add on , well lens. That unit looks like you have to tear the unit apart and run the connector. A lens augmentation, for something like this , I would expect to be something like a stick on item, similar to what they sell for cell phones. That is an element replacement , I believe
Sorry, bit of a camera buff.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline G.Brown
« Reply #49 on: October 13, 2023, 12:27:17 PM »
top one is what it comes with, other ones lens is slightly thinner but I didn't have any problems with heat disipation, I suppose you should really pack it slightly to match,  there seems to be some sticky heat disiptive tape on the heat sink.
Third one is in my camera at the moment and is the best for close up - I intend pointing it at my bee hive....
