I saw hundreds of signals at lightningmaps.org, but no strikes. I didn't bother to connect the ground, so it was mostly junk noise. There is so little activity at the moment, there was no chance to get a real strike. Although, the strike stats graph does show strikes, but the Network tab doesn't. Odd.
One interesting difference with this kit compared to Jim M.'s is that the GPS module supplied was the new GlobalTop Fox-1 unit, rather than the older PA6H. I wonder if they corrected the firmware/hardware bug that causes problems if too many sats are being tracked?
The pinouts on the new module are the same, but the notch on the module should not align with the white dot on the board silk-screen. New builders beware!
I could identify the ground pins on the new module by looking for the tiny bridges to the shield from the ground connection pins. I ohm'ed the board to find if the corresponding pads were at ground, indicating the correct orientation. Otherwise, it would have been easy to install the module backwards, which would be a very hard thing to correct once it was soldered down.
Don
EDIT: It appears the only feature difference is that the PA6H has an additional TTL interface for receiving RTCM position correction data from an RTCM receiver. The FOX-1 has only a single TTL interface for primary GPS data. This is inconsequential for our application.
