Author Topic: Help with WD bad data  (Read 838 times)
Offline txweather.org
    • Texas Weather
« on: July 02, 2019, 03:46:52 PM »
somehow Weather Display is getting a bunch of bad data and I do not know how to delete or understand where is getting it from...
https://www.txweather.org/wxrecordsalltime.php
You can see the negative numbers and testtags is also reflecting that data https://www.txweather.org/WDL/testtags.php?sce=view
Weather Display is setup to get data from my Meteobridge Nano SD and the data in the history does not reflect -52.... Makes no sense.
Please help.
Offline AWL
    • Ardmore Weather Live
Re: Help with WD bad data
« Reply #1 on: July 02, 2019, 06:52:42 PM »
Did you just start using WD? (if not disregard post) If so it may sort it out after midnight.
Doug
    • Texas Weather
« Reply #2 on: July 02, 2019, 07:54:18 PM »
Doug
Yes, But curious why after midnight?
Is there a schedule job that needs to run?
Offline AWL
« Reply #3 on: July 02, 2019, 08:04:29 PM »
I notice some things update then.... Like for instance the NOAA daily report. I see on your records page the warmest/coldest day is now showing good data? Same thing will happen on the first day of every month.
Doug
