Author Topic: Weather Station Radiation Shield  (Read 833 times)
Offline Platokidd
  • top side land of Lincoln
« on: March 23, 2023, 12:14:35 PM »
Want to find a  Radiation Shield for my campsite station.
Ran across the link below on Amazon and have been kicking it around for some time now. This one doesn't have any reviews that I find, odd.
Anyone have this shield or know who the manufacture is would be great.
https://us.amazon.com/dp/B088W8D989/?coliid=I27AUI6OXF4OB8&colid=3GPJYW7H3VKMO&ref_=gv_ov_lig_pi_dp&th=1
« Last Edit: March 23, 2023, 12:26:38 PM by Platokidd »
Ambient
ECOWITT
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
Offline alanb
Re: Weather Station Radiation Shield
« Reply #1 on: March 23, 2023, 03:29:45 PM »
I use this inexpensive one to house ambient WH31E (temp/humidity) and WH31L (ligntning) sensors. It has worked OK for me. I do have it hanging on the branch of a tree, so it is mostly shaded.
https://us.amazon.com/dp/B01M64ISDE?ref=nb_sb_ss_w_as-reorder-t1_k0_1_7&amp=&crid=1Q4VWCOLKDTGB&amp=&sprefix=acurite
This link has a couple of pictures of the installed sensors in this shield: https://www.wxforum.net/index.php?topic=42649.
« Last Edit: March 23, 2023, 03:34:08 PM by alanb »
Offline Patt21
« Reply #2 on: March 25, 2023, 02:17:47 PM »
es I have had it for 1 year with a WH31 probe, it measures the temperature at +10cm from the ground. I painted the inside black and added spacers between the plates because not high enough to insert the Ecowitt probe. Product not qualitative, it protects from the rain and the sun, for the radiation I have doubts.... For an Ecowitt type probe it is necessary at least 8 plates high. There are no double plates at the top and bottom.
wh40/wh41/wh45/wn32p/wh31(3/wh51(3)/wh35/wn30(4)/wn34s/ws68/hp10/hp2550.
WH32ep barani shield (8m)
wh31ep 7714 davis (2m)
wh57 +shelter
wn30 (soil T° -50cm)
wn 30 (soil T° -10cm)
ws68 (8 m)
wh31 (+10cm)
wh31 (unshielded 1m80)
https://app.weathercloud.net/d0885729038#profile
https://www.awekas.at/fr/instrument.php?id=23272
https://smartmixin.io/app/stations/42866
Offline Patt21
« Reply #3 on: March 25, 2023, 02:26:01 PM »
n your opinion is to measure the temperature on the ground, +10cm or 0 cm, do you need a radiation shield? In my country I believe that Météo France recommends a probe without a shield to count the frosts on the ground.
wh57 +shelter
ws68 (8 m)
wh31 (+10cm)
Offline gszlag
  • ..have you calibrated your barometer today?
    • Michael's Bay - Manitoulin Island weather
« Reply #4 on: March 25, 2023, 06:51:06 PM »
Here's a 5cm AGL sensor with a shield:
https://www.lambrecht.net/en/products/temperature/grass-temperature-sensor-8241
However, somewhere, I am sure I saw a picture and description in possibly the UK of a similar ground surface sensor that was supposed to be placed such the probe was barely above the tips of the grass. As the story goes, meteorologists got tired of cutting the grass (specified height??) so the grass was eventually replaced by artificial turf. Can't recall if there was a radiation shield or not but I thought the probe was bare.
Unfortunately, I can't find/lost that link.
Ambient Weather WS-2000
Ecowitt WS3900 console
Ecowitt GW1000/GW1100
Ecowitt WS68: Anemometer, UV/solar
Ecowitt WH40: Rain gauge
Ecowitt WH57 Lightning sensor
Ecowitt WH32E: Outside T & H sensor
Stratus Rain Gauge (manual)
Raspberry Pi 3B+ (WeeWX/CumulusMX)
Raspberry Pi Zero 2W (WeeWX/MQTT/Belchertown)
Barometer wiki: http://meshka.eu/Ecowitt/dokuwiki/doku.php?id=barometer#barometer
http://weather.glenns.ca (pwsdashboard - live)
http://weewx.glenns.ca
http://glenns.ca/cumulusmx2/index.htm
Uploading to: AWN, ecowitt.net, Weather Underground, PWSweather.com, AWEKAS, Windy.com, WOW
Offline Platokidd
« Reply #5 on: March 31, 2023, 12:29:53 PM »
Went with this one from Davis. However, since I placed my order, they raised the price over $25 US dollars.
https://www.amazon.com/dp/B000WXKNM0?psc=1&ref=ppx_yo2ov_dt_b_product_details
Ambient
ECOWITT
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
PWS at 2 locations.
Offline Patt21
« Reply #6 on: April 04, 2023, 03:54:37 PM »
Thx to you, I was inspired by the MO and MF for the Temperature at + 5 cms: I fixed the probe under the plate above and removed all the other plates, the WH30 is at ground level protected from the rain and without radiation protection. [tup]
wh57 +shelter
ws68 (8 m)
wh31 (+10cm)
